T8SG Plus 3-way switch (D)
16 Sep 2020 13:46 #76789 by Ssayer
T8SG Plus 3-way switch (D) was created by Ssayer
I'm obviously not searching correctly as this has probably been asked a million times before, but I'm missing something and can't find help via the search here...
Switch D is a 3-way switch and I have tried everything that I can think of. No matter what I try, in the 3 positions, 1 position shows up one way and the other 2 show up the other direction. My desire is to have D0 show up as -100, D1 show up as 0, and D2 show up as +100 when I check the mixer output. So... what do I need to change? Thanks much!
16 Sep 2020 13:55 #76790 by vlad_vy
Replied by vlad_vy on topic T8SG Plus 3-way switch (D)
For example, you can use 3 pages with complex mixer, curve = fixed, mux = replace, switch = D0 (D1, D2) and scale will be -100 (0, 100).
16 Sep 2020 14:33 - 16 Sep 2020 19:34 #76791 by Ssayer
Replied by Ssayer on topic T8SG Plus 3-way switch (D)
Ok, got it. Thank you. :)
Last edit: 16 Sep 2020 19:34 by Ssayer.
05 Oct 2020 18:10 - 05 Oct 2020 18:11 #76850 by tomy03ful
Replied by tomy03ful on topic T8SG Plus 3-way switch (D)
My problem is i want a channel which consists of one 2-way and one 3-way switch. Jumper t8sg v3, switches G and H
For example:
switch G0 + H0 is 1000
switch G1 + H0 is 1200
switch G2 + H0 is 1400
switch G0 + H1 is 1600
switch G1 + H1 is 1800
switch G2 + H1 is 2000
Or something like that. I don't want to use 2 channel for 2 beeper (2 positions) and led mode (3 positions).
Last edit: 05 Oct 2020 18:11 by tomy03ful.
Time to create page: 0.269 seconds
