HOTEN X voltage sensor issue
01 Sep 2022 04:46 #78070 by jfitz66
HOTEN X voltage sensor issue was created by jfitz66
Would anyone know why I am getting the low voltage alarm on my devo 10 with my Hoten X regardles of how low I set the alarm voltage. The last time I used my Hoten was a few years ago but it worked just fine then. Voltage is set to 7.2 Transmitter is running devention firmware
Voltage of battery reads 8.3 in sensor view but still getting alarm.
I have changed nothing. Also seem to have same issue with the ladybird whichnis set to 3.6
Thanks to anyone that can help. I do have other devo 10 transmitters, some with devention and some with deviation. Have not tried moving the model file to a different transmiiter with devention or setting it up on one running deviation.
06 Sep 2022 22:49 #78087 by Gerry
Replied by Gerry on topic HOTEN X voltage sensor issue
Could be that your batteries sag badly under load if they are getting old.
Also I found that using voltage telemetry with my ladybird or super cp would significantly reduce flight times.
FFS (Forever Fixing Stuff)
06 Sep 2022 23:08 #78088 by jfitz66
Replied by jfitz66 on topic HOTEN X voltage sensor issue
Thanks for the reply. Batteries are all new and alarm sounds even with fully charged batteries without the motors running. Since this happens with both my hoten x and both ladybirds I have to assume its a transmitter issue. I have other Devo 10s i can transfer model files too. Just haven't gotten around to it yet.
14 Sep 2022 09:44 #78089 by teeshirt24h
Replied by teeshirt24h on topic HOTEN X voltage sensor issue
thanks you!
websiite: teeshirt24h.comteeshirt24h.com
Time to create page: 0.081 seconds
