flashing
23 Jan 2025 02:24 #78621 by davidjek1
flashing was created by davidjek1
how to flash with factory firmware and what software do I need?
23 Jan 2025 15:05 #78622 by hexfet
Replied by hexfet on topic flashing
23 Jan 2025 16:52 #78623 by davidjek1
Replied by davidjek1 on topic flashing
Thank You HexFet for your reply that helped and now I will need to research the interface to get it done.
25 Jan 2025 18:34 #78625 by hexfet
Looks like the manual is available at ori-rc.com/download/walkera/Manual%20of%20DEVO-7.pdf . Last page has firmware install instructions.
If the PC is not detecting the 7e USB there's a driver utility called zadig which may help. It's open source and you can search google to download. Searching this forum for messages with zadig may also help.
25 Jan 2025 20:50 #78626 by davidjek1
Those instructions are for a Devo 7 not 7e. Thanks anyway.
26 Jan 2025 16:02 #78628 by hexfet
My bad. Never had a 7e :)
Here's a link www.manualslib.com/manual/3394995/Devent...Devo-7e.html?page=73
Not much there other than putting it in dfu mode. Good luck!
26 Jan 2025 18:08 #78629 by davidjek1
Thanks for the help. You can stop looking, I've contacted Walkera and I will be working with them now.
Time to create page: 0.060 seconds
