T8sg V2 carbon
- Oxley
12 Apr 2025 09:46 #78655
by Oxley
T8sg V2 carbon was created by Oxley
Hi I have been given a t8sg V2 carbon. It seems all is not well. I can't recover the old models I click on one of them and the transmitter instantly turns off.I try to enter a new model with spectrum protocol DSMX and I can't configure a cut off switch. After binding the throttle is running flat out. I try moving throttle gimbal and nothing happens. It has a deviation T8sg -v2-plus -V5xx-2018-04-19 program in it. I don't know whether updating the firmware will help. If there is an update.
13 Apr 2025 03:27 - 13 Apr 2025 03:28 #78656
Replied by hexfet on topic T8sg V2 carbon
Sounds like a corrupted filesystem to me. Try reformatting the USB drive and restoring the files from a backup if you have one, or copy the files from the 2018-04-19 build.
The latest build is on the test builds page under [hexfet]nightly_build.
Last edit: 13 Apr 2025 03:28 by hexfet.
- Oxley
13 Apr 2025 12:14 #78657
by Oxley
Replied by Oxley on topic T8sg V2 carbon
I found that in the channel monitor section , mixer out put. There was no recognition when the gimbals were moved. But when it was turned to stick input there was correct movement when gimbals were moved.
I also found all
I also found all
- Oxley
13 Apr 2025 12:18 #78658
by Oxley
I also found all channels were set to Complex. I changed all gimbals to simple. I also change switches to none.
Time to create page: 0.177 seconds
- T8sg V2 carbon
