Help with Walkera Master CP after crash
16 Jan 2026 18:34 #78807 by themadsinger
Help with Walkera Master CP after crash was created by themadsinger
Had a crash which took out one of the servos so replaced them all with metal gear ones.
Having problems getting it set back up. I centred servos and set the servo arms so they were in the right place for the swash plate to be pretty much level but when I fire up the controller the "neutral" position moves the one servo down (but a significant amount) so the swash plate is no longer level annd that servo will be much closer to the one limit. I have tried binding as a fresh model to see if that is the issue but does not make a difference. Any suggestions? Would adjusting the screws on the receiver helpwith this?
17 Jan 2026 16:55 #78809 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Help with Walkera Master CP after crash
Perhaps you should try the following.
Remove the linkage from the servos to the swashplate. Swap two servo connectors on the receiver and observe whether this behavior remains with one servo or whether the other servo behaves in the same way. This could help identify the cause.
