Problems with DevoDfuSe ver. 1.5 with Win7 x64
- kosem
16 Oct 2012 14:28 - 17 Oct 2012 05:19 #2285
by kosem
Problems with DevoDfuSe ver. 1.5 with Win7 x64 was created by kosem
Hi team!
I can't display the DevoDfuSe window.
Everything is installed correctly, the driver is recognized but I can't launch the application. It won't be displayed but rather be "hidden" in the background. When I launch the app I see Windows undocked taskbar "moving" like when a new icon goes there and...nothing.
- STM32DFU recognizes the driver
- I've tried to run the app in compatibility mode (WinXP) and with Admin rights.
- The program won't run regardless if the device (DEVO 6S) is connected or not.
On my wife's Vista laptop it works flawless.
Any help would be very appreciated!
FYI, WIN7 Event viewer:
Faulting application name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Faulting module name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Exception code: 0xc0000005
Fault offset: 0x000065bf
Faulting process id: 0x1768
Faulting application start time: 0x01cdab8ac02b5276
Faulting application path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Faulting module path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Report Id: fdde72eb-177d-11e2-adfb-5404a62c5e85
Last edit: 17 Oct 2012 05:19 by kosem.
- kosem
19 Oct 2012 16:34 - 19 Oct 2012 16:34 #2334
by kosem
Replied by kosem on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Last edit: 19 Oct 2012 16:34 by kosem.
- NewJocker
22 Oct 2012 11:15 #2373
by NewJocker
Replied by NewJocker on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Hi.
I'have the same problem. On my 1st PC (win 7 64b), dfuse won't launch. But on another pc (same win 7 64b) it's rock!
Maybe a software conflict.
Try another pc.
Try another pc.
- j35u5fr34k
28 Oct 2012 01:20 #2450
by j35u5fr34k
Replied by j35u5fr34k on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Hi I have the same exact issue. It seems that there is no fix. I resorted to using an older Windows XP computer and I was able to get it work on that PC. Good Luck.
- kosem
28 Oct 2012 21:11 #2460
by kosem
Very bad support from Walkera.
Thanks anyway guys.
Thanks anyway guys.
- CmdrKeen
28 Oct 2012 22:37 #2462
by CmdrKeen
Replied by CmdrKeen on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I had the same problem with Dfuse 1.5 from Walkera.com.
But I came across Dfuse 1.4 and now it works fine.
www.derspielstein.com/shop_content.php/c...ntion-Upgrade-Center
I am sorry, it is a german website, but it contains the 1.4 Dfuse-tool:
www.derspielstein.com/soft_up/soft_file_1315373997456_en.zip
and quite a collection on firmwares for the Devos
- kosem
01 Nov 2012 22:12 #2591
by kosem
A very warm thanks for your help!
It works fine for me too.
Greetings from Paris
- Hexperience
01 Nov 2012 22:35 - 01 Nov 2012 22:41 #2592
by Hexperience
Replied by Hexperience on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Just for the sake of gathering more info. I have Win7 64bit and 1.5 works fine for me. I have Intel 64bit... wonder if any of the problems are on AMD 64bit?
.... Actually, now that I think about it... I may have used the x86 driver when I installed. I'll check the driver version and see what I'm using. Just says 3.0.1.0 I can't see which folder it installed from.
Last edit: 01 Nov 2012 22:41 by Hexperience.
- j35u5fr34k
02 Nov 2012 00:33 #2593
by j35u5fr34k
I don't think the driver is part of the issue since I can't start defuse even with the tx unplugged.
- RandMental
02 Nov 2012 12:23 #2611
by RandMental
Replied by RandMental on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I could not get it to run on my Intel based PC, Win7 32bit. Decided (for other reasons) to upgrade(?) to WIN7 64bit. It was one of the first items I installed and it rusn without any issues. I guess that supports the notion that it is a sofware clash.
Come to think about it, its been 3 weeks since I last used it and have since installed all my ussual softwware - better check it is still working!
- j35u5fr34k
12 Nov 2012 02:45 #2862
by j35u5fr34k
Some users reported reverting to 1.4 fixed their issue.
- robertleong
23 Nov 2012 00:22 #3102
by robertleong
Replied by robertleong on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I am on AMD Athlon 64 X2 processor, Windows 64-bit, opens normally.
- clearprop88
06 Jan 2013 17:11 #4742
by clearprop88
Replied by clearprop88 on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I read the posts in the log.
I can't get DevoDfuSe to run on my computer.
I have;
WINDOWS 7 Home Edition
Service pack 1
64 bit OS
Intl i7 CPU
I tried the 1.4 version from the German site, but that doesn't work either.
It downloads Ok, and unzips OK, but when I try to run DevoDfuSe it just hangs up.
Any ideas?
I have;
Service pack 1
64 bit OS
Intl i7 CPU
Any ideas?
- clearprop88
06 Jan 2013 20:13 - 07 Jan 2013 16:19 #4744
by clearprop88
I got the DevoDfuSe tool working in another computer.
This computer has Windows 7, but it's the starter edition.
Also when I download the zip files from the Walkera site I get a notice that says that the zip SW is not free, and that I get a 30 day trial for the SW.
Last edit: 07 Jan 2013 16:19 by clearprop88. Reason: correction
- gapi
25 Jan 2013 16:18 #5507
by gapi
Replied by gapi on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I want to add v1.4 solved mine too but am too chicken chit to try v1.5. Anyone do the v1.4 first and then get the v1.5 working?
- martin
01 Apr 2013 15:32 #8366
by martin
Replied by martin on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Still no solution for this? Going back to v1.4 wouldn't work for me, since it's too old to support my TX.
- blackmoon
01 Apr 2013 17:49 - 01 Apr 2013 17:51 #8378
by blackmoon
Replied by blackmoon on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Rev 1.7 available from walkera
walkera.com/en/updater.php
Note I don't use 7 so I haven't tested it.
Last edit: 01 Apr 2013 17:51 by blackmoon.
01 Apr 2013 17:52 #8379
Replied by rbe2012 on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
It is and it works fine for me on XP and Win7 (both updates from 1.5).
The download link is here: DFuse 1.7
Time to create page: 0.261 seconds
- Problems with DevoDfuSe ver. 1.5 with Win7 x64
