USART on Trainer Port
- MatCat
26 Nov 2012 20:11 #3254
by MatCat
USART on Trainer Port was created by MatCat
Ok I remember being told not too long ago that the trainer port is actually a USART, if this is the case I plan to develope this into something useful. At this stage I would like to ask what would like to be seen out of trainer port USART functionality?
I have my own private goals which will be available on my own repo once it is setup, however I do want to contribute to the codebase so that another feature can be available.
One of my main goals for myself is two way communication, telemetry in, radio control information out (for things such as UHF radios, etc), would also allow for fairly easy implementation of control input as well, such as a joystick to offer a secondary analog interface.
Some of these ideas will require some simple external hardware of course, which I personally will maintain some information on for those interested, but for now the purpose of this thread is to ask what would be best for the codebase with traner port USART?
26 Nov 2012 20:22 #3256
Replied by PhracturedBlue on topic USART on Trainer Port
Deviation has a 'PPM' protocol that will output channel data via the UART, suitable for a simulator like Phoenix. It is otherwise just like any other protocol supported by Deviation. Output is 3.3V and is basically unbuffered (there's just a resistor between the UART port and the MCU as I recall)
- MatCat
26 Nov 2012 20:43 #3258
by MatCat
Replied by MatCat on topic USART on Trainer Port
It is using the actual USART pins for the PPM output? I will probably have to add an option in UI to configure it between options then like PPM out, PPM IN, Bi-Directional USART
- MatCat
26 Nov 2012 20:45 #3259
by MatCat
Is the MCU 5v logic tollerant?
26 Nov 2012 20:57 #3261
No we don't actually use the UART for that. It is enabled for debug output of printf when PPM is not selected though.MatCat wrote: It is using the actual USART pins for the PPM output? I will probably have to add an option in UI to configure it between options then like PPM out, PPM IN, Bi-Directional USART
I don't believe so. You'd need to check the specs though.Is the MCU 5v logic tollerant?
- MatCat
26 Nov 2012 21:41 #3262
by MatCat
I will experiment when I get home tonight, oh on the trainer port itself which base of the connector is what (TX,RX, etc etc)?
Ok I see, yeah I have been studying the datahseet a bit on it, not really an issue it's easy to do logic level conversion on the other piece of hardware anyway.PhracturedBlue wrote:
- suvsuv
28 Nov 2012 08:23 #3333
by suvsuv
Replied by suvsuv on topic USART on Trainer Port
I would like to let the trainer port connect to a bluetooth module, then 3rd parties can develop android/ios/wp8 apps via the bluetooth.
28 Nov 2012 14:11 #3348
FYI, the CC2500 (which is one of the modules used by many RC systems) is a bluetooth module. I'm not sure if the STM32 has enough horsepower to drive it that way, but it is possible that it could.
Time to create page: 0.247 seconds
- USART on Trainer Port
