Devo7e work
08 Feb 2013 13:05 - 08 Feb 2013 13:06 #6151 by cmpang
Replied by cmpang on topic Devo7e work
got a very primitive spectrum analyser today and started to perform some test on the Devo 7e's power measurement.
Before any mod on the 7e, I have compared its output with my Devo 10 setting to 100mW output and found that the 7e is about 10dB down..
After shorting the diode and perform some measurement again against the Devo 10, I've got the following screen captures for you all to analyse.. (I've taken 4 captures for each transmitter so that you can average out the data)
Last edit: 08 Feb 2013 13:06 by cmpang.
10 Feb 2013 04:24 - 10 Feb 2013 04:24 #6190 by cmpang
thank you PB for his great effort to benefit the community here..
put in a VL911 transmit modue, able to bind the 911 without problem.
One issue is that the 7e cannot memorise the last selected model after powering off. Every time I switch the Tx on and it stay on a particular model ..
anyone get the same?
With the diode shunt mod, I love the 7e better than the Devo 10 for its smaller size, easy to carry around with my tiny birds..
Last edit: 10 Feb 2013 04:24 by cmpang.
10 Feb 2013 06:30 #6194 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
When reporting bugs, please make sure to tell me the hg version you are running. The code is under heavy development and bugs may be fixed in newer releases.
10 Feb 2013 08:03 #6196 by cmpang
PhracturedBlue wrote: When reporting bugs, please make sure to tell me the hg version you are running. The code is under heavy development and bugs may be fixed in newer releases.
sorry for that.
It was on the ea9ee2c4a03d, right now switched to the b76ac7445568 and get the same result..
10 Feb 2013 08:08 - 10 Feb 2013 08:22 #6197 by cmpang
further to that, I have made changes to Mode 1 and the 7e is not able to register after powering off... changes to model icons do work tought..
checking the file system found it didn't write to the tx.ini file..
making changes to the tx.ini file manually via USB works
Last edit: 10 Feb 2013 08:22 by cmpang.
10 Feb 2013 09:37 #6200 by dehalo
Replied by dehalo on topic Devo7e work
Used to have the same problem
Had to set batt_critical=4400 in the tx.ini
(was set higher by the emulator)
10 Feb 2013 10:55 #6202 by Xermalk
Replied by Xermalk on topic Devo7e work
Make sure you have a correct tx.ini file
My devo 7E would not save anything until i used a tx.ini from the devo 10.
10 Feb 2013 11:43 #6203 by cmpang
I have put a tx.ini from my devo 10 and the 7e was able to recongise the settings. In fact, I am able to fly my vl911 with the devo 10 file now. The issue remains that the 7e seems not able toupdate the ini file.
10 Feb 2013 12:25 #6204 by dc59
Replied by dc59 on topic Devo7e work
cmpang wrote: I have put a tx.ini from my devo 10 and the 7e was able to recongise the settings. In fact, I am able to fly my vl911 with the devo 10 file now. The issue remains that the 7e seems not able toupdate the ini file.
Devo10's tx.ini file can NOT be used at 7E directly,
Please check it :
www.deviationtx.com/forum/7-development/...evo7e-work?start=200
From #5484
10 Feb 2013 12:38 - 10 Feb 2013 12:39 #6205 by Xermalk
Mine is saving changes just fine with a devo 10 tx.ini.
But then again i use a tx.ini for the same revision of the code.
I simply just think that it cannot handle a tx.ini with invalid values and just skips saving.
Last edit: 10 Feb 2013 12:39 by Xermalk.
10 Feb 2013 13:14 #6206 by PhracturedBlue
The tx.ini that is in the filesystem.zip has no default battery voltage set, so it should initialize properly whne the tx is first booted. If you copy the tx.ini from another tx you will absolutely have issues though.
10 Feb 2013 14:02 #6209 by cmpang
PhracturedBlue wrote: The tx.ini that is in the filesystem.zip has no default battery voltage set, so it should initialize properly whne the tx is first booted. If you copy the tx.ini from another tx you will absolutely have issues though.
strange that not able to find the filesystem.zip nor the txt.ini in the deviation-devo7e-b76ac7445568.zip nor in the deviation-devo7e-ea9ee2c4a03d.zip
btw, which version is the latest? ..5568 or the .... a03d?
10 Feb 2013 14:06 #6210 by cmpang
set the critical battery voltage to 4400 and the txt.ini issue is gone.
thanks everybody for your find help.
10 Feb 2013 14:08 #6211 by PhracturedBlue
you should use the one from the devo10 filesystem.zip (but not from a real tx)
I would use the build from here:
www.deviationtx.com/forum/builds/1380-de...89f1f-devo12-support
I am going to try to setup an easier way to find the latest builds so you don't need to guess though.
10 Feb 2013 14:31 #6212 by cmpang
PhracturedBlue wrote: you should use the one from the devo10 filesystem.zip (but not from a real tx)
get it. Many thanks PB... :)
10 Feb 2013 15:08 #6213 by SadSack
Replied by SadSack on topic Devo7e work
Maybe give this ago www.deviationtx.com/forum/7-development/...tx-build-environment least you'll have the newest build with file system and very simple to use.
10 Feb 2013 17:23 #6215 by PhracturedBlue
I have enabled a nightly-build system.
You can find recent builds here:
These are recommended for the devo7e and devo12 at this time
www.deviationtx.com/repository/Deviation...ases/Nightly-Builds/
10 Feb 2013 19:06 #6218 by Xermalk
PhracturedBlue wrote: I have enabled a nightly-build system.
PB, you might want to add the filesystem to the Devo 7E make/build script.
New users would only go an install whats in the zip and completely miss that you need more files. Its not that intuitive that you need to grab files from the devo 10 build.
11 Feb 2013 04:27 #6242 by cmpang
Hello PB,
I noticed that in your DEVO-7E Hardware Connections document, there are two switch inputs (B5/C7 and B5/C9) are not being used. Any chance that we can added two more channels if we can do a bit of soldering?
11 Feb 2013 05:53 #6244 by cmpang
and the soldering shouldn't be difficult, no need to solder on the SMT.. :)
Time to create page: 0.629 seconds
