Devo7e work
18 Feb 2013 09:53 #6512 by FDR
Replied by FDR on topic Devo7e work
MacGyverek wrote: I asked about change/write something on *.ini file for change a gui to standard gui. There is any options fot do this??
It is in the ini file, but the whole config is different then...
  • rbe2012
  • rbe2012's Avatar
18 Feb 2013 10:00 #6513 by rbe2012
Replied by rbe2012 on topic Devo7e work
Use
mixermode=Standard
or
mixermode=Advanced
outside of sections.
18 Feb 2013 10:18 #6514 by FDR
It's not enough!
It should be based on the "Heli/Standard GUI" template (heli_std.ini)...
18 Feb 2013 10:28 #6515 by domcars0
Replied by domcars0 on topic Devo7e work
I think that if you pick up a model.ini file for a model configured in 'Standard Mode', it is not possible to change it to 'Advanced Mode' and vice-versa. You have to reconfigure it ...
18 Feb 2013 10:31 #6516 by vlad_vy
Replied by vlad_vy on topic Devo7e work
MacGyverek wrote: Where is this build for download?? I can't found this in Nightly builds. Maybe problem is with my OS.
Right now build a80935a2970e there is at Nightly builds.
18 Feb 2013 10:33 #6517 by FDR
Partially true:
Actually you can change it to advanced mode and even can change it back, but you cannot change a generic advanced model config into a standard one without resetting it.
A standard model config can always be changed to advanced...
18 Feb 2013 13:15 #6519 by domcars0
FDR wrote: A standard model config can always be changed to advanced...
Yes :woohoo: .. good to hear as I prefer the advanced mode :P
18 Feb 2013 13:27 #6520 by FDR
You probably won't like the results though, because it will be unnecessarily complex...
19 Feb 2013 00:05 #6545 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
Is the "emu" version a stand-alone interface that can be tested in windows, to get familiar with the whole system without flashing a TX? If so, is there anywhere for download without needing to build it? I've searched around and didn't come across anything that defined what the emulator is as such.
The 7E is my only devo TX, and my first "real" programmable TX, so am a bit hesitant at wiping it and starting from scratch in an environment I am not familiar with, without any pre-built config (Super CP)
19 Feb 2013 00:07 #6546 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
RoGuE_StreaK wrote: Is the "emu" version a stand-alone interface that can be tested in windows, to get familiar with the whole system without flashing a TX? If so, is there anywhere for download without needing to build it? I've searched around and didn't come across anything that defined what the emulator is as such.
Download it from the nightly build section. also get the Devo10 filesystem, as you'll need that.
It is as you say a fully functional Windows interface to show you how the Tx will function. You can configure your models with it and transfer those configurations to your actual Tx as well. It is built from the same code, and should be visually identical to the real thing.
19 Feb 2013 00:26 - 19 Feb 2013 00:26 #6547 by RoGuE_StreaK
Ah, didn't see the emu build further down the page; had downloaded the normal build and didn't find an emu inside :silly:
Last edit: 19 Feb 2013 00:26 by RoGuE_StreaK.
19 Feb 2013 14:10 #6583 by macue
Replied by macue on topic Devo7e work
I need help, i broke my Devo7e. This is what i've done:
1 - I installed the deviation-devo7e-848e6ada8ca7.zip, through DfUse without a problem
2 - rebooted the Devo7e and a new drive appeared on my computer, so i formated it and loaded the filesystem files
3 - rebooted the Devo7e and i am greeted with a blank screen :unsure:
4 - No difference if i try to reinstall the deviation firmware.
i think i messed up the filesystem files. Now i cant use the transmitter at all and i cant get into the transmitter's drive where I copied the files.
i also discovered that i cant rollback the firmware coz walkera doesnt have it on their site. Do i now have a cool new paper weight?
i know i've messed up but please note that this is my first post, so be kind. :)
  • rbe2012
  • rbe2012's Avatar
19 Feb 2013 14:20 #6584 by rbe2012
Just to be sure: you took the Devo10-fs to fill the new drive?
19 Feb 2013 14:20 #6586 by FDR
Can you turn it on in USB mode and do you see the filesystem on the computer?
You have to see a few directories (language, media, modelico, models, protocol, template, moduls) and the tx.ini file, plus the optional errors.txt file in the root of the USB drive.
You also need to copy the protocol (*.mod) files into the protocol directory...
19 Feb 2013 14:22 #6587 by vlad_vy
To install:
1) install the dfu,
2) install the filesystem (Devo 10),
3) copy the 'protocol' directory to the Tx.
Possible you miss something?
19 Feb 2013 14:26 #6588 by PhracturedBlue
Also hold 'Ent' to get to the filesystem screen.
It pops up automatically the 1sttime, but after that, you need to hold ENT during power-on to get it.
19 Feb 2013 15:14 #6589 by macue
hello guys, i made a mess of it the first time around, i didnt use the Devo10 filesystem and i didnt even copy over the right filestructure.
Once i held "ent' on power on the USB drive appeared and i was able to copy the correct filesystem and other files to the transmitter. It now looks like it works. :-)
thanks a lot for your help guys.
19 Feb 2013 20:29 #6595 by domcars0
Welcome to the Magical World of DeViation :woohoo:
20 Feb 2013 12:20 #6629 by Krejzi
Replied by Krejzi on topic Devo7e work
I have an issue with devo 7e and Blade nanoCPX.
I don't know if this because of wrong .ini file, or something else.
When i'm flying sometimes heli losing connections and after 1 or 2 second restore the connection, its really annoying.
I just want to know if this my bad or bugs in soft.
Soft downloaded today from Nightly-Builds.
.ini files downloaded from another topic about nanocpx.
Time to create page: 1.605 seconds
