Devo7e work
26 Feb 2013 16:31 #7093 by sbstnp
Replied by sbstnp on topic Devo7e work
Seba-Wan wrote: Hello guys,
I've read the all work, sincerely congratulations! But..
I want the maximum devo 7e range, so i don't understand the following things to reach the goal:
1- Short the diode. That's clear :)
2- I have to change the module (example for a7105? or only with the diode mod its enough?
3- Change the antenna?
4- I have to install deviation firmware mandatory? In that case, wich value(mw) is correct?
5-With all things and some ones you recommend me, how far can i go with the DEVO 7e?
Thanks!!
1. Absolutely.
2. Add the a7105 if you want FlySky support, see point 4 too.
3. No
4. I think the diode mod works for stock firmware as well. Deviation is just more powerful.
5. Depends on what you fly. Small models tend to become invisible at a certain point.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
  • rbe2012
  • rbe2012's Avatar
26 Feb 2013 17:21 #7098 by rbe2012
Replied by rbe2012 on topic Devo7e work
Xermalk wrote: ...7E got its own filesystem zip file?
Or atleast rename the Devo10 one to Devo10+7E...
This looks like a good idea. File a ticket on bitbucket!
26 Feb 2013 17:40 #7100 by FDR
Replied by FDR on topic Devo7e work
...just like the DEVO 6, which uses the filesystem of the DEVO 8.
28 Feb 2013 00:18 #7148 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
Has anyone tested the official firmware from the Chinese part of the Walkera site? Main question being whether it's in English...
28 Feb 2013 01:20 #7150 by Mullson
Replied by Mullson on topic Devo7e work
Witch languish would you like it to be?
28 Feb 2013 01:23 #7151 by RoGuE_StreaK
English. Just checking whether the firmware on the Chinese part of the site is in English or Chinese...
28 Feb 2013 01:29 #7152 by Mullson
So you are a sceptic?
28 Feb 2013 01:35 #7153 by RoGuE_StreaK
WTF? It's a serious legitimate question; I don't want to install a firmware that leaves me with an unusable TX, the only TX I have compatible with my Super CP!
28 Feb 2013 01:43 #7154 by Mullson
But why would you want to change back?
28 Feb 2013 07:56 #7155 by RW9UAO
Replied by RW9UAO on topic Devo7e work
help, how to turn on telemetry in dsm2/dsmX mode?
28 Feb 2013 08:08 - 28 Feb 2013 08:09 #7156 by vlad_vy
Replied by vlad_vy on topic Devo7e work
Press protocol button (DSM2 or DSMX) and switch on telemetry. By default it disabled (for DSM2 and DSMX).
Last edit: 28 Feb 2013 08:09 by vlad_vy.
28 Feb 2013 08:20 #7157 by RW9UAO
thank you, Vlad, it real hidden and not clear.
28 Feb 2013 08:37 #7158 by Xermalk
Replied by Xermalk on topic Devo7e work
Its most likely in chinese. Just like my tx was when i got it.
But as you can change language in the menus it doesn't really matter.
28 Feb 2013 22:51 #7175 by RoGuE_StreaK
Thanks Xermalk; so if the interface is in Chinese, you'd just have to remember the steps "ENT, third down, ENT, ENT" then hopefully you would see "English" written in English as a choice?
I have all my settings written down for the 7E version of Devotion, now that some sort of official firmware is available as a backup I'd like to try to make the jump to Deviation, but I would like to be able to revert if I want to have a fly and still haven't nutted out the Deviation settings; or more accurately, figured out how to drive the mixer system. While the EMU is helpful, until you physically try it with the bird then you don't know for sure if you've got everything right. Being my only Devo TX, and having only very limited time for experimentation, I may need to jump back and forth a few times before I get a useable setup.
01 Mar 2013 06:57 #7189 by cmpang
Replied by cmpang on topic Devo7e work
FDR wrote:
....The trim buttons, just like the other controls (like switches and sticks) can be assigned to do more then one thing.
By default they are assigned to work as trims for the sticks, but they could be assigned to be independent "analogue" inputs on their own too....
enlightened by FDR's quote ... think about it and it is an excellent idea.. However, the current release seems don't have any means to assign the trim button to any output channels.
One possible way is to employ 4 internal soft toggle switch that is to be turned on/off by a pair of associated Trim buttons.. and in the Mixer page to be able to assign to any output channels.
In this way, the tiny 7e would become a plain 12 channels transmitter (now is 8 after doing the two switch mod). Wouldn't it be wonderful ....?
01 Mar 2013 08:49 - 01 Mar 2013 09:01 #7190 by Mullson
cmpang wrote: enlightened by FDR's quote ... think about it and it is an excellent idea.. However, the current release seems don't have any means to assign the trim button to any output channels.
You can:
Mixer, right, right, right, right and on 10 and 7e Model menu, Trims. Then change the input to a Ch or virtual Ch and decide step.
Than you can build any kind of curve setup.For example you can use it as a 1 off 2 or as a free dial nobb. Realy nice if you know you wont need to trim your heli on that stick input.
A pair of toggles found for a nice price:
www.aliexpress.com/item/free-shipping-2p...s-Q11/539870178.html
Have you moded any builds for the switches yet?
Last edit: 01 Mar 2013 09:01 by Mullson.
01 Mar 2013 09:08 #7191 by Mullson
RoGuE_StreaK wrote: WTF? It's a serious legitimate question; I don't want to install a firmware that leaves me with an unusable TX, the only TX I have compatible with my Super CP!
Sorry If I offended you. Just made a little joke :woohoo:
I thought you understood that you can decide it yourself when I sed "Witch languish would you like it to be?" :)
01 Mar 2013 09:52 #7192 by cmpang
You can:
yes I followed your setting and able to get an anologe switch with the Trim.. althought using it as a toggle switch is a bit not convenient.. anyway better than none...
the toggle switch should be ok for the switch mod..
I am currently not able to build a dfu..I am now using the version from suv and it worked flawlessly..
01 Mar 2013 10:16 #7193 by Mullson
Is your tx volt meter stable? If so was it also stable with last build?
I use one of the trims for gyro with steps of 20. And am thinking of setting up a fmode like Compex whit 4modes two up and two down.
01 Mar 2013 11:27 #7195 by cmpang
Mullson wrote: Is your tx volt meter stable? If so was it also stable with last build?
yes the TX Volt was wandering up and down while moving the thottle stick, but got stable now...
Time to create page: 0.692 seconds
