Devo7e work
24 Mar 2013 15:27 - 24 Mar 2013 20:43 #8044 by heliaddict
Replied by heliaddict on topic Devo7e work
Can anyone confirm if current nightly build for Devo7e is working correctly for them please?
I replaced Devo7e module with WK-21201RF module. Not sure if this has made any difference? I could bind with the early release (deviation-devo7e-b76ac7445568) so assuming it's a problem with the current nightly build.
Last edit: 24 Mar 2013 20:43 by heliaddict.
25 Mar 2013 07:47 #8060 by dc59
Replied by dc59 on topic Devo7e work
heliaddict wrote: Can anyone confirm if current nightly build for Devo7e is working correctly for them please?
Some Taiwan & China friends have same problem!
I think it's F/W bug,not from WK-21201RF module,please use early release deviation F/W.
25 Mar 2013 07:58 #8061 by dc59
Hi PB,
I fonud a mistake at ModuleInstallation.pdf about V911 module pin connection.
V911 module GND & Vcc should be swapped, please confirm it again.
Thanks.
25 Mar 2013 09:28 #8063 by heliaddict
Thanks for your reply! The latest release I can find that will let me bind is deviation-devo7e-ea9ee2c4a03d. But there is a problem with this as well with low contrast which can't be adjusted under LCD settings. Hopefully there will be an official release soon:)
  • rbe2012
  • rbe2012's Avatar
25 Mar 2013 11:15 #8065 by rbe2012
Replied by rbe2012 on topic Devo7e work
dc59/heliaddict:
If you feel you see an error in the actual build you should file a description at bitbucket to make sure that it will be corrected ( PBs issue tracker ).
25 Mar 2013 15:39 #8072 by heliaddict
rbe2012 wrote: dc59/heliaddict:
Wasn't sure if this was a fault in the build so wanted to confirm if anyone else had problems. Have submitted issue on bitbucket now.
25 Mar 2013 23:55 #8084 by Nibborg
Replied by Nibborg on topic Devo7e work
Same problem here. Doesn't bind.
Also, auto bind don't start on power on.
On the model page all protocols shows 'Re-init' button, no one shows 'Bind' button.
Previous F/W binds Ok.
The tx just arrive two days ago... no hw mods yet! :)
28 Mar 2013 21:04 #8216 by martin
Replied by martin on topic Devo7e work
Has anyone successfully tried going back to the original firmware, now that it is available?
28 Mar 2013 21:38 #8222 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
suvsuv identified the typo that was preventing binding. I have applied it and it will be in the next nightly.
28 Mar 2013 21:59 #8223 by martin
Speaking of typos, the first post in this thread says: "Latest experimental build: 2012-01-22". I almost didn't read any further the first time I came here, thinking that development for 7E had stopped over a year ago. :)
29 Mar 2013 01:47 #8233 by RW9UAO
Replied by RW9UAO on topic Devo7e work
i am. burn original firware after deviation and deviation again. all good.
29 Mar 2013 16:02 #8251 by heliaddict
PhracturedBlue wrote: suvsuv identified the typo that was preventing binding. I have applied it and it will be in the next nightly.
Latest nightly build working great thank you.
29 Mar 2013 21:43 #8255 by Nibborg
Thanks a lot, suvsuv & PB!
It binds without problems now.
Just a question. I dont know if i made some mistake...
I'm using the vertical left trim button for adjust the giro on a SuperCP. I adjusted the min/max values on the channel 7 for 100 and -100, but using the trim i can adjust up to 300 or more (and -300 too)!
Maybe i need to do some other adjusment to get the giro in the limits of 100/-100?
30 Mar 2013 10:50 - 30 Mar 2013 10:51 #8275 by cmpang
Replied by cmpang on topic Devo7e work
heliaddict wrote: ...I replaced Devo7e module with WK-21201RF module.....
I also want to try out different Devo modules, where do you get your WK-21201RF...?
Last edit: 30 Mar 2013 10:51 by cmpang.
31 Mar 2013 08:40 #8331 by farad
Replied by farad on topic Devo7e work
I tried the most current nightly build and I can't see the graphs on any screen.
31 Mar 2013 10:11 #8335 by sbstnp
Replied by sbstnp on topic Devo7e work
farad wrote: I tried the most current nightly build and I can't see the graphs on any screen.
Replace the filesystem too.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
31 Mar 2013 11:51 #8338 by heliaddict
www.ehirobo.com/shop/Walkera-Parts-Walke...nfo.html?language=pt
31 Mar 2013 14:38 #8340 by cmpang
thx
01 Apr 2013 13:31 - 01 Apr 2013 13:32 #8359 by RandMental
Replied by RandMental on topic Devo7e work
Devo 7e RF power modification
With reference to the Diode bridge mod inside the Devo7e RF module and various tests done, I have compared the Devo8s at 150mW and the modified devo7e in a controlled environment. The results below indicate that the 7e mod does take the standard Devo7e to a fixed 150mW output. (please ignore the absolute value of the graphs, I did not use a calibrated antennae on the Spectrum Analiser)
www.deviationtx.com/forum/7-development/...-work?start=240#6083
www.deviationtx.com/forum/7-development/...-work?start=220#6151
From the attached spectrum graphs you can see the levels are virtually the same, testing was over a 5 meter range, using the standard TX antennas.
PB's Diode modification
Devo8s with Devention Firmware set to 150mw
Devo7e with Devention Firmware
Last edit: 01 Apr 2013 13:32 by RandMental.
01 Apr 2013 15:57 - 01 Apr 2013 16:02 #8367 by cmpang
do you all recall that there was a time that the movement of the thottle stick would interfer with the Tx's battery voltage reading ?
I admit that I didn't realize the problem by that time beacuse I am flying in mode 1 and so I mistakely moving the right hand stick instead of the left hand stick which you mode 2 guys referred as thottle...
Not until today a very very bad news on my 7e... I was flying my WL911 and found that I was not able to cut the heli's power despite I have fully down my thottle... it was only later that I found not only the voltage reading but also the thottle (right hand stick) was interferred by the elevator (left hand stick).. it started to happened today.. it was fine for the past months and I fly everyday..
Refreshing with different fw versions and still get the same..and so my last move is to go back to the Walkera factory version 0.1 and got the same problem..
so it is not the deviation and the interferrence must came from hardware . I recalled PB has mentioned he must apply software filters on the analogue inputs in order to stabilised the samples input...
nevertheless, I will do my best to tackle the problem and hopefully, it is only an isolated hardware defect on my 7e ..
ps. the symptom is like a mixing is applied to the right vertical stick from the left vertical stick,.. and it happens about 50% of the time.. sometimes come, sometimes gone.. and it comes and go without needing a Tx power reset
Last edit: 01 Apr 2013 16:02 by cmpang.
Time to create page: 0.422 seconds
