Error building emulator on mac os X
- Pixel166
03 Feb 2013 21:55 #5976
by Pixel166
Error building emulator on mac os X was created by Pixel166
I'm trying to build the emulator on mac os X, and I have this error :
I've search on Google, on the forum, without finding any solution.
I know the cross compiling environnement doesn't help for the emulator, but I just want to say that I successfully compile (on mac os X) the devo6 dfu file
Any idea to help me ?
Thx
+ Compiling 'target/common_emu/fltk.cpp'
target/common_emu/fltk.cpp: In function ‘void CLOCK_Init()’:
target/common_emu/fltk.cpp:461: error: ‘CLOCK_REALTIME’ was not declared in this scope
target/common_emu/fltk.cpp:461: error: ‘timer_create’ was not declared in this scope
target/common_emu/fltk.cpp:466: error: aggregate ‘itimerspec in’ has incomplete type and cannot be defined
target/common_emu/fltk.cpp:466: error: aggregate ‘itimerspec out’ has incomplete type and cannot be defined
target/common_emu/fltk.cpp:472: error: ‘timer_settime’ was not declared in this scope
make: *** [objs/emu_devo8/fltk.o] Error 1I've search on Google, on the forum, without finding any solution.
Thx
04 Feb 2013 07:43 #5982
Replied by rbe2012 on topic Error building emulator on mac os X
I am not sure but might it be necessary to give the parameter "make TARGET=emu_devo8 WINDOWS=1" on MAC also? If not: which version (commit) did you compile?
- Pixel166
04 Feb 2013 08:10 #5983
by Pixel166
Replied by Pixel166 on topic Error building emulator on mac os X
I will try this this evening, but I'm not sure it will end up in a good compilation, because if I understand correctly the Makefile, here is the code that uses WINDOWS=1
It seems it won't help too much for my problem, but I will try it.. as I haven't any other solution for now.
About the version (commit), I try with a lot of them (even the last one), but the code where it makes an error don't change accross all the versions, so the error is still there
ifdef WINDOWS
#CROSS=i586-mingw32msvc-
FLTK_DIR = /usr/local
ifdef CROSS
FLTK_DIR = /opt/fltk-w32
PORTAUDIO_DIR = /opt/portaudio-w32
LFLAGS += -mno-cygwin
CFLAGS += -mno-cygwin
endif
LFLAGS := -L$(FLTK_DIR)/lib -L$(PORTAUDIO_DIR)/lib $(LFLAGS) -lole32 -luuid -lcomctl32 -lwsock32 -lgdi32 -lcomdlg32 -lportaudio
CFLAGS += -I$(FLTK_DIR)/include -I$(PORTAUDIO_DIR)/include -DWIN32
EXEEXT = exe
ODIREXT = -w32
else
LFLAGS := $(LFLAGS) -lrt
ifndef SOUND
CFLAGS += -DNO_SOUND
else
LFLAGS := $(LFLAGS) -lportaudio
endif
endifIt seems it won't help too much for my problem, but I will try it.. as I haven't any other solution for now.
04 Feb 2013 09:22 #5984
I admin I am not a specialist concernign Makefiles, but the emulater is made esp. for Windows - so the WINDOWS=1-part will integrate some necessary things.
If I compile the emulator (on Windows XP) without this argument, I also get errors (file not found).
target/common_emu/fltk.cpp:28:19: schwerwiegender Fehler: FL/Fl.H: No such file or directory
Kompilierung beendet.
make: *** [objs/emu_devo8/fltk.o] Error 1- RandMental
04 Feb 2013 12:10 #5994
by RandMental
Replied by RandMental on topic Error building emulator on mac os X
Hi Pixel
May I ask why you want to build the emulator on a Mac? Even if you are succsfull by crosscompiling it on a MAc for Windows, you will need to copy the .exe file to a Windows PC to run it.
Without WINDOWS=1, you cross compile for the STM32 processors in the Devo TX
Adding WINDOWS=1 you compile for Windows for a Intel 586 processor, and the Windows operating system.
- Pixel166
04 Feb 2013 12:37 #5995
by Pixel166
Hi RandMental,
I want to compile the emulator on my Mac, because I own a Mac, and don't have Windows. So I don't want a cross-compilation for windows, but I want a mac executable, to be launched on mac OS.
In my first most, I say I successfully compile the devo6 dfu file (with the cross compilation environnement), not the emulator
I have an Ubuntu at work, and I don't need the WINDOWS=1 to compile the emulator.
04 Feb 2013 13:48 #5997
Replied by PhracturedBlue on topic Error building emulator on mac os X
Well, we have 2 timer systems available:
1) A unix compliant one using signals and timers
2) A windows specific implementation because Windows isn't POSIX compliant
So you definitely do not want to use WINDOWS=1 (unless you compile with and run in Wine)
But MacOSX should be POSIX compliant, so the normal build should work.
Try adding:
#include <sys/time.h>
near the other includes and see if that helps.
you might also do:
find /usr/include -name "*.h" | xargs grep CLOCK_REALTIME
To see which file it is included from.
Try adding:
you might also do:
04 Feb 2013 13:53 #5998
Could this difference cause the emulator's sound issue on Windows:
www.deviationtx.com/forum/7-development/...r-s-sounds-are-false
Replied by FDR on topic Error building emulator on mac os X
PhracturedBlue wrote: Well, we have 2 timer systems available:
04 Feb 2013 16:45 #6005
It is unlikely this would affect sound. the sound code in the emulator is completely unrelated to the timer code in the emulator (though on the actual TX they are tightly related)
- Pixel166
04 Feb 2013 17:07 #6007
by Pixel166
returns nothing.
find /usr/include -name "*.h" | xargs grep timer_t
return nothing.
After some searchs with Google, it seems mac os uses BSD time instead of POSIX time
returns nothing.
return nothing.
05 Feb 2013 13:51 #6051
It is nice that 'POSIX' doesn't actually mean anything here
It looks like you can use setitimer
here is a setitimer implementation for you:
replace the code in fltk.cpp with that.
If it works let me know. It seems to be ok on Linux too so I can just make the change.
void CLOCK_Init()
timer_callback = NULL;
signal(SIGALRM, _ALARMhandler);
struct itimerval in;
in.it_value.tv_usec = 100 * 1000; //100msec
in.it_value.tv_sec = 0;
in.it_interval.tv_usec = 1000; //1msec
in.it_interval.tv_sec = 0;
setitimer(ITIMER_REAL, &in, NULL);
}replace the code in fltk.cpp with that.
- Pixel166
05 Feb 2013 20:17 #6062
by Pixel166
It's nearly good.
The compilation passed this previous error, but now, I have an error with 32b/64b libraries (as I understand)
The error seems to be a bad version of libfltk.a, but if I check, it's an x86_64 version. I don't understant
Undefined symbols for architecture x86_64:
"_objc_msgSendSuper2", referenced from:
-[FLWindow initWithFl_W:contentRect:styleMask:] in libfltk.a(Fl_cocoa.o)
-[FLView init] in libfltk.a(Fl_cocoa.o)
... CUT ...
"_CGRectUnion", referenced from:
Fl_Graphics_Driver::clip_box(int, int, int, int, int&, int&, int&, int&)in libfltk.a(fl_rect.o)
"_CGRectEqualToRect", referenced from:
"_CGContextAddArc", referenced from:
Fl_Graphics_Driver::circle(double, double, double)in libfltk.a(fl_vertex.o)
Fl_Graphics_Driver::arc(int, int, int, int, double, double)in libfltk.a(fl_arci.o)
Fl_Graphics_Driver::pie(int, int, int, int, double, double)in libfltk.a(fl_arci.o)
"_CGGetActiveDisplayList", referenced from:
screen_init() in libfltk.a(screen_xywh.o)
"_CGDisplayBounds", referenced from:
"_CGDisplayScreenSize", referenced from:
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make: *** [emu_devo8.elf] Error 1The error seems to be a bad version of libfltk.a, but if I check, it's an x86_64 version. I don't understant
05 Feb 2013 21:02 #6064
I'm not sure how to help you with that. I'd agree that your libfltk does not seem tobe compatible with the rest of your system though.
You can try building it yourself, it is reasonably easy to do.
- vanwadiver
12 May 2013 22:57 #9903
by vanwadiver
Replied by vanwadiver on topic Error building emulator on mac os X
It looks like it's been a while since this topic was last addressed... Were you able to build the emulator for the MAC OSX environment?
I'd be interested in any tips on how you succeeded in building it, if possible.
Thanks..
Thanks..
- Pixel166
13 May 2013 07:05 #9916
by Pixel166
No, I can't build the emulator on mac os X. But to be honnest, I give up very little time after the last post of this topic
- vanwadiver
13 May 2013 13:08 #9921
by vanwadiver
Ah well... perhaps I'll give it a try someday if I have some spare time....
- Lyndros
04 Sep 2015 20:04 #37448
by Lyndros
Replied by Lyndros on topic Error building emulator on mac os X
nobody succeed on that? I hate using the virtual machine for development...
05 Sep 2015 00:50 #37454
Replied by mwm on topic Error building emulator on mac os X
Well, that last post was 2+ years ago. You might give it another try, as my tweaks to the Makefiles so I can build on my BSD boxes have been merged.
One thing you'll want to do is create a bin specifically for building deviation firmware and emulators. The makes fail if cc isn't gcc like it is on FreeBSD, and OS X seems to do the same.
- Lyndros
05 Sep 2015 09:34 #37465
by Lyndros
I tried with the script supplied and everything some of the links include in the build-osx.sh are dead I replace them for working ones.
On the other hand it looks like the 2011 version of portaudio it is a nightmare to compile with MacOS SDK 10.10 anyhow I downloaded the latest stable portaudio and compile it ... but now another nightmare ... so I will keep going with my virtual machine
On the other hand, stupid question I fixed some typos in the spanish translation but I can not create pull request to deviation main repo, any clue?
05 Sep 2015 14:55 #37466
I answered your mail on bitbucket as well, but doing things here is better as others can help so you might get an answer faster, and then everyone can see the answer.
What are you doing, and what's going wrong? The more detail, the better. With that, we might be able to sort out what's wrong.
Time to create page: 0.436 seconds
- Error building emulator on mac os X
