Developing a universal module
06 Apr 2014 09:09 #22165 by SeByDocKy
Replied by SeByDocKy on topic Developing a universal module
Another question, I don't know where to plug CSN on the AVRasp ? VCC or GND ?
06 Apr 2014 13:04 #22169 by PhracturedBlue
Replied by PhracturedBlue on topic Developing a universal module
SeByDocKy wrote: ...or if I return the PCB, I see a square pin in 1 position. Usually, such square is designing the ground ? It means that it's reversed as you wrote ?
square pin is always pin1, it is not always ground.
06 Apr 2014 13:05 #22170 by PhracturedBlue
SeByDocKy wrote: Another question, I don't know where to plug CSN on the AVRasp ? VCC or GND ?
Do not hook up CSN on the programmer, it is not needed for programming
06 Apr 2014 13:13 #22171 by PhracturedBlue
SeByDocKy wrote: My USBasp is delivering 5V so ... I will program it first in order to not cook RFchips. It should be highlighted in red IMHO. By the way, I am trying to make a video for a step by step procedure.
This doesn't seem to be possible in the Wiki, but I bolded it
06 Apr 2014 13:24 #22172 by SeByDocKy
Ho sorry, good to know :)
06 Apr 2014 19:10 #22174 by SeByDocKy
Ok flashing Ok...
Remark :
Need to use the pin 1: 3.3V even with a USBasp working @5V
07 Apr 2014 00:12 - 07 Apr 2014 00:12 #22181 by Pattaya01
Replied by Pattaya01 on topic Developing a universal module
Just for the record (and this may be a stupid question):
If I do NOT install the universal module, and load the latest SW (nightly), I do not need to change anything, my TX will just perform normally and there are no settings (hardware.ini) I need to think of, right?
Last edit: 07 Apr 2014 00:12 by Pattaya01.
07 Apr 2014 01:19 #22182 by PhracturedBlue
if you have no modules installed, install the hardware.ini that comes with the firmware.
if you have modules installed (but not the universal module) you need to properly configure hardware.ini
07 Apr 2014 02:41 #22185 by anarchy
Replied by anarchy on topic Developing a universal module
pb
what are the chances of me getting a replacment for the stock cyrf in my devo 7e or even a uni mod to put in it i had a misshap with the range mod or even point me in the right direction for a tut on makin a uni mod with something that will get me back devo dsm
07 Apr 2014 03:04 #22188 by PhracturedBlue
you might be able to find an original Walkera module here:
www.ehirobo.com/walkera-wk-devo-s-mod-de...-upgrade-module.html
You likely need to find a 5V source (switched) on the Devo7e to use this module at full-power. I'm sure it is there, but I'm not sure where it is.
I have shown that the 'BuyChina' module will bind with Devo/DSM, but have not range-tested it.
www.buychina.com/items/2-4g-module-cyrf6...m-module-uuruunslkhi
You should not need a MultiMod to use this module.
Or you can order an AWA24S and a MultiMod (the AWA24S cannot be used without the multi-mod) from here (again not range-tested, but it does work):
www.digikey.com/product-detail/en/AWA24S/748-1003-ND/1687150
07 Apr 2014 11:22 - 07 Apr 2014 11:39 #22197 by SeByDocKy
Ok, I finished the multi-module. I am planning to connect it on my fresh Devo10. My multi-module have only 3 RF chips (Don't have the CYRF).Two questions :
1) P1 pinout to Devo10
P1 (view from top)
7 5 3 1
8 6 4 2
with 7 = GND, 5 = MISO, 3 = Reset, 1 = +5V
8 = CSN, 6 = SCK, 4 = MOSI, 2 = +3.3V
For the devo 10, I need VDD, GND, TMS, TCK, SCK, MOSI, MISO and optionnally NRESET (If I want to relash Hex file with my devo).
So
P1 ====> DEVO 10
2:+3.3V | VDD
3:Reset | NRESETTCK
4:MOSI | MOSI
5:MISO | MISO
6:SCK | SCK
7:GND | GND
8:CSN | TMS ? TCK ?TMS
2) For Hardware.ini
just adding "enable-multimod = A13" ?
EDIT : just found the information
"If the 'Universal Module' is being installed, 'CSN' should connect to the 'TMS' pin, and 'RESET' should connect to the 'TCK' pin"
EDIT 2 : "The Reset pin only needs to be connected if you plan to program the AVR via your transmitter. In this case, connect the 'Reset' pin to the 'TCK' pin of the Devo transmitter" should be also be written in the DevoModule8Install page
Last edit: 07 Apr 2014 11:39 by SeByDocKy.
08 Apr 2014 16:35 #22248 by anarchy
HEY JUST A BTW I ORDERED A THE UPGRADE MODULE FROM EHIBRO.COM EVEN THOUGHT IT SAID OUT OF STOCK AND SENT AN EMAIL SAYING THAT THERE WERE LOTS OF PEOPLE ON A FORUM I WAS A MEMBER OF LOOKING FOR THIS WHEN WOULD IT BE BACK IN STOCK I HAD AN EMAIL BACK IN LESS THAN A DAY AND THE MODULE IS ON ITS WAY SO I WOULD TELL YOU ALL TO ORDER AWAY FROM THERE
09 Apr 2014 13:45 - 09 Apr 2014 13:45 #22266 by RandMental
Replied by RandMental on topic Developing a universal module
Hi All
I have been absent from the site for a while and noticed a lot of progress on the Multimodule. Although I have all three modules installed with a small toggle switch in the battery compartment to toggle between the CC2500 and nrf24L01 modules, the better way would be to replace these with Multimodule
My Question - I noticed there is talk about a V1.3 and V1.4 module, but only the V1.3 can be ordered from oshpark.com/shared_projects/Df3iWl1J .
Do I need to and where do I get the V1.4 PCB, or is the V1.3 still the "better" PCB to get?
regards
RM
Last edit: 09 Apr 2014 13:45 by RandMental.
09 Apr 2014 15:23 #22269 by PhracturedBlue
I haven't fully vetted the v1.4 board which is why it isn't available now. The only functional difference is the support for the 'BuyChina' CYRF6936 module (probably irrelevant for all Devo Transmitters)
The v1.3 is the recommended board.
Note that your current setup won't actually work with nightly builds because we check for the presence of modules on startup, and one of your modules will always fail to detect.
11 Apr 2014 18:40 #22350 by SeByDocKy
Banggood have in stock all RF chips for the multi-module. Jacky from BG followed my advices to stock them :)
www.banggood.com/new-arrivals-c-1729-0-28-6.html
Price are good
12 Apr 2014 17:29 - 12 Apr 2014 17:30 #22366 by WheresWaldo
Replied by WheresWaldo on topic Developing a universal module
SeByDocKy wrote: Banggood have in stock all RF chips for the multi-module. Jacky from BG followed my advices to stock them :)
Price are good
Thanks for this info, I wasn't looking forward to disassembling my Devo10 and removing the nrf24L01 module. This way I just ordered all the modules I wanted in one shot and will populate the multi-module board before swapping it out with my current setup. Besides I need more time to get ready since I am building a FPV quad and ground station at the same time.
Last edit: 12 Apr 2014 17:30 by WheresWaldo.
13 Apr 2014 20:42 - 13 Apr 2014 20:43 #22385 by SeByDocKy
Ok First try to switch on with the multimodule ... I was very optimistic, because it was the first time I switch on also my new devo 10.
I had "Missing CYRF6936" error msg.
In the hardware.ini, I just uncomment "enable-multimod = A13". I have 3 RFchips installed on my multi-modul, the A7105-500, the nRF24L01+ and the CC2500. I am wrong with my hardware.ini ?. I guess there is a soldering problem somwhere.... Luckily, I can remove it more or less easily.
Last edit: 13 Apr 2014 20:43 by SeByDocKy.
13 Apr 2014 20:46 #22386 by PhracturedBlue
you didn't post your hardware.ini. please do so
13 Apr 2014 20:59 #22387 by SeByDocKy
PhracturedBlue wrote: you didn't post your hardware.ini. please do so
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
13 Apr 2014 21:06 #22388 by SeByDocKy
I feeling there is a problem with my multi-module, coz my devo10 don't boot completly. Displaying the error msg with the CYRF and reboot. So first, I will remove the multi-module to check if the TX is ok.
Time to create page: 0.275 seconds
