Developing a universal module
06 May 2014 04:10 #22929 by briareos7777
Replied by briareos7777 on topic Developing a universal module
With the latest deviation code, is this the correct hardware.ini? :
[modules]
enable-cyrf6936=S0
has_pa-cyrf6936=1
enable-a7105=S1
has_pa-a7105=1
enable-cc2500=S3
has_pa-cc2500=1
enable-nrf24l01=S402
has_pa-nrf24l01=1
enable-multimod=A13
06 May 2014 13:23 - 06 May 2014 13:23 #22932 by PhracturedBlue
Replied by PhracturedBlue on topic Developing a universal module
That is correct if you relocated the cyrf module to the multimod board.
If you did not relocate the cyrf module, you should comment out the 'enable-cyrf6936' line. If you are using an AWA24S or 'ChinaBuy' CYRF6936, the commands are different.
Last edit: 06 May 2014 13:23 by PhracturedBlue.
06 May 2014 13:37 #22934 by SeByDocKy
Replied by SeByDocKy on topic Developing a universal module
PhracturedBlue wrote: That is correct if you relocated the cyrf module to the multimod board.
Hi PB,
Regarding the wiki of the MM, it should be great to give indications on wich connector you have to install the specific RF chip (U1, U3, etc...)
Regarding the hardware.ini, why the nRF24L01 is associated with "S402" ? For the A7105, this chip is connected to U1, for the CC2500 to U3... Can you explain the nomenclature ?
06 May 2014 15:25 #22942 by PhracturedBlue
Good point. I'll update the wiki. The 'U#' has nothing to do with the 'S#'.
The S# represents the switch position:
CYRF6936 = 0
A7105 = 1
NRF24L01 = 2
CC2500 = 3
The # is actually in hexadecimal. the least-significant byte represents the switch position (how CSN is connected). the upper byte is a control byte (in the case of the NRF24L01 it indicates how the CE pin is controlled). so 'S402' can be interpreted as 'CE on pin 4, CS on pin 2'. We do something similar for the 'BuyChina' and 'AWA24S' modules which require different controls.
Having explained that, it is irrelevant to the end user. What is needed is just documentation on what values are needed to control the module.
08 May 2014 14:01 - 08 May 2014 14:34 #23011 by midelic
Replied by midelic on topic Developing a universal module
I've noticed that, on V1.3 version XL2500 socket U7 is reversed...antenna going in opposite direction.Not very convenient IMO all antennas should point in the same direction...plus is going over the module edge.
Last edit: 08 May 2014 14:34 by midelic.
09 May 2014 09:42 #23061 by midelic
I was thinking why connect nrf24L01 CE pin to Attiny pin......?Why not keep CE pin high all the time,,,put a 10-20K resistor from CE pin to 3,3V(Vcc).It will be less complicated.
12 May 2014 15:36 #23158 by robca
Replied by robca on topic Developing a universal module
SeByDocKy wrote: Banggood have in stock all RF chips for the multi-module. Jacky from BG followed my advices to stock them :)
www.banggood.com/new-arrivals-c-1729-0-28-6.html
Price are good
Is there a link to the individual modules? Looks like Banggood "what's new" changes over time, and the link above now points to unrelated items
I ordered my previous modules from eBay, but it's really hit or miss (lots of sellers put every keyword in the description, and it's easy to get a module without PA or with the wrong chip). I like Banggood, so I'd like to buy my new set of modules there
12 May 2014 16:02 #23159 by victzh
Replied by victzh on topic Developing a universal module
This search is pretty exact: www.banggood.com/buy/4ghz-module.html
Funny it's better than www.banggood.com/buy/2.4ghz-module.html
13 May 2014 02:09 - 13 May 2014 12:43 #23167 by aMax
Replied by aMax on topic Developing a universal module
Be aware, this 2.4G-NRF24L01 (SKU099478) might look like this.
www.bilder-hosting.info/viewer.php?id=arx1399946310k.jpg
No U.FL and a short antenna. BG now has a third try... :whistle:
Edit: I added an external link for bigger picture size.
Last edit: 13 May 2014 12:43 by aMax.
13 May 2014 06:14 - 13 May 2014 06:19 #23173 by blackmoon
Replied by blackmoon on topic Developing a universal module
Man! just bought two of them :( I don't want a fixed antenna because fitting the MM into the 7E is already a pita, even with a ufl one...
And I only see a "decoupler" on the antenna where is the whip ?
Does this even work like that ?
Last edit: 13 May 2014 06:19 by blackmoon.
13 May 2014 06:26 #23174 by SeByDocKy
I ordered this module at BG ...
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
They are perfect ...
13 May 2014 08:47 #23180 by jesmail
Replied by jesmail on topic Developing a universal module
With the latest code, I tried the EMU for Devo 8.
Since I have no module installed
I set the H/W ini file to
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
; enable-multimod = A13
When it starts up I get module error , missing modules
nrf24l01
multimod
13 May 2014 09:14 #23181 by SeByDocKy
jesmail wrote: With the latest code, I tried the EMU for Devo 8.
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
nrf24l01
multimod
with MM, there are some change in .ini
has_pa-nrf24l01=1
13 May 2014 11:16 #23183 by jesmail
That is part of the problem, I did not have the MM module and would like to get it working without it.
I tried adding the
has_pa-nrf24l01=1
still get same errors.
Thanks for the help.
13 May 2014 13:08 #23187 by aMax
I ordered this one.
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
The problem seems to be " modified for".
Now they claim that this board looks like as it is advertised.
The second resend will show if it is true.
13 May 2014 14:35 #23191 by HappyHarry
Replied by HappyHarry on topic Developing a universal module
that is the correct one from bg, it is indeed as is shown in the picture and has a pa and an lna
16 May 2014 16:52 #23286 by SeByDocKy
I am Happy :)
My new tentative to build the MM is a succeed ... :)
All the 3 modules are working :)
I did some videos during the building ...
16 May 2014 18:08 #23289 by PhracturedBlue
I learned something recently. the nrf24L01 really is sensitive to +5V. I had accidentally programmed my board with a 5V programmer with modules installed. Everything worked fine on the bench, so I put it down to being lucky and moved on. When I went out the other day to actually test it outside I found the range was basically gone. This is a non PA module used for indoor flying, and I couldn't even go 15 feet with it anymore.
So...Don't program the Universal module with a 5V programmer with any modules installed :)
Time to create page: 0.248 seconds
