Makefile: "access denied - ." on cp -prf... line
05 Apr 2013 11:18 - 05 Apr 2013 11:56 #8555 by RandMental
Hi Guys
I get the following " access denied - . " error when running the build under Eclipse. It is however not an Eclipse problem, as I get the same when running the build outside the Msys shell.
Any ideas on which path or access rights I need to set to get the cp command in the makefile to execute correctly? All else work fine and the .elf file gets build. I am running Win7 x64.
.PHONY: $(LAST_MODEL)
$(LAST_MODEL): model_template.ini tx_template.ini $(FONTS)
@echo " + Copying template files for $(FILESYSTEM)"
mkdir -p filesystem/$(FILESYSTEM) || true
cp -prf filesystem/common/media filesystem/$(FILESYSTEM)/
cp -prf filesystem/common/template filesystem/$(FILESYSTEM)/
cp tx_template.ini filesystem/$(FILESYSTEM)/tx.ini
echo 'empty' > filesystem/$(FILESYSTEM)/errors.txt
13:03:06 **** Incremental Build of configuration Default for project DevoPB-Ec ****
make
+ Copying template files for devo8
Access denied - .
File not found - -NAME
C:\MinGW\bin\xgettext.exe: no input file given
Try `C:\MinGW\bin\xgettext.exe --help' for more information.
Access denied - .
13:03:14 Build Finished (took 8s.888ms)
Last edit: 05 Apr 2013 11:56 by RandMental.
05 Apr 2013 12:44 #8558 by PhracturedBlue
Replied by PhracturedBlue on topic Makefile: "access denied - ." on cp -prf... line
I'll check it, but try running make with VERBOSE=1
at least we can see what is going on.
05 Apr 2013 12:57 #8560 by PhracturedBlue
I verified that everything is ok on my end when compiling in Windows. So we'll have to see what exactly it is complaining about.
  • rbe2012
  • rbe2012's Avatar
05 Apr 2013 13:11 #8562 by rbe2012
I have seen similar errors a time ago when my eclipse environment (Windows XP) was not fully configured (was a question of the correct PATH variable). I do not really remember what did the trick, but I think I have tried to write the absolute path in "util/extract_strings.pl" line 25 before find ("/bin/find"?) and line 70 before "head".
I can not look on my notebook now to see the path I use actually.
05 Apr 2013 13:34 #8563 by RandMental
Replied by RandMental on topic Makefile: "access denied - ." on cp -prf... line
PhracturedBlue wrote: I'll check it, but try running make with VERBOSE=1
Hi PB, I did use VERBOSE, it then only lists the full statement before the error:
and then the Access denied error
By breaking this long command into smaller one line pieces and adding echo statements in between, I could confirmed the error is given after the first cp -prf..... line.
In trying to solve the access error, I have now broke something else and get errors under MSys as well. Let me first get building under Msys up and running again before you waste further time on this.
  • rbe2012
  • rbe2012's Avatar
05 Apr 2013 14:18 #8564 by rbe2012
RandMental,
as said above my problem was similar. I could break it down to the path variable where something weird was taken before the msys-directories were searched (I believe it was python but not sure). So any other command was taken (maybe cp?) and this implementation did not understand / interprete the same options as the wanted one or did something unexpected - I don't remember.
But maybe controlling and perhaps correcting the path in your environment can help.
05 Apr 2013 21:15 #8599 by RandMental
Thanks Rbe, I have noticed the order of the paths is critical, swapping them around created many other errors. I also suspect a wrong command gets picked up from the wrong directory.
09 Apr 2013 15:37 #8792 by RandMental
I can again compile and build under MinGW, this is Verbose under Eclipse:
17:33:38 **** Incremental Build of configuration Default for project DevoPB ****
make TARGET=devo8 VERBOSE=1
mkdir -p filesystem/devo8 || true
cp -prf filesystem/common/media filesystem/devo8/
cp -prf filesystem/common/template filesystem/devo8/
cp tx_template.ini filesystem/devo8/tx.ini
echo 'empty' > filesystem/devo8/errors.txt
mkdir filesystem/devo8/models 2> /dev/null || true
echo 'name=Model1' > filesystem/devo8/models/model1.ini \
&& cat model_template.ini >> filesystem/devo8/models/model1.ini
cp model_template.ini filesystem/devo8/models/default.ini
mkdir filesystem/devo8/language 2> /dev/null; \
../utils/extract_strings.pl -target devo8 -update
Access denied - .
export tx=devo8; \
number=2 ; while [ $number -le 30 ] ; do \
cp model_template.ini filesystem/$tx/models/model$number.ini; \
number=`expr $number + 1`; \
done
+ Checking string list length for devo8
../utils/check_string_size.pl -target devo8 -quiet
Access denied - .
true
17:33:50 Build Finished (took 11s.809ms)
09 Apr 2013 17:59 #8799 by PhracturedBlue
It looks like eclipse isn't running the perl scripts properly. Maybe it is specific to the xgettext call.
The xgettext call is as follows:
find . -name "*.[hc]" | xargs xgettext -o - --omit-header -k --keyword=_tr --keyword=_tr_noop --no-wrap
the lone '-' there says 'redirect to stdout' but perhaps it is being misinterpreted since the error messages seem to imply looking for a file called '-'. I really don't know enough about running eclipse on windows with mingw to be of help though
09 Apr 2013 18:48 - 09 Apr 2013 18:49 #8800 by RandMental
Hi PB, thanks for having a look. Interesting is that it use to work for a while. I don't know what changed on my setup and as RBE also said, he got it to work after having similar issues. It is not critical though - I run two local repositories, one to build under MinGW and one under eclipse to explore the source code.
I play with it more when I have time, if I get a solution I'll update the eclipse how-to document.
Last edit: 09 Apr 2013 18:49 by RandMental.
27 Jan 2015 16:37 #28107 by katrina
Probably the path path is long that's why you are getting access denied error, download Long Path Tool it helps in this situation.
Time to create page: 0.104 seconds
