PB's newgui
26 Jun 2013 08:23 #11384 by vlad_vy
Replied by vlad_vy on topic PB's newgui
OK, they contain the same layout settings, but I changed setting only for default layout template. I changed [gui-480x272] for default model ini, now all works fine.
26 Jun 2013 09:03 #11386 by vlad_vy
It's interestingly. I deleted from default model ini (and from all default modelX.ini files) all layout settings. If I load new model, layout is for [gui-480x272] in default template. If I change layout and then reset model, layout is for [gui-480x272] in default template.
All the same works for emu_devo8.
I think that default model ini (and all default modelX.ini files) can be without any layout settings.
Also, I found that default layout template has wrong trimm settings (0, 1, 2, 3). But model ini files have right trimm settings (1, 2, 3, 4).
26 Jun 2013 09:09 #11388 by FDR
Replied by FDR on topic PB's newgui
If it works that way, i.e. uses the default layout template when the layout section is missing from the model data, I agree, that the default model data could be without layout information.
That would simplify customizing the default layout...
26 Jun 2013 09:18 #11389 by Kdean
Replied by Kdean on topic PB's newgui
This is what i want to submit for a template. It is very basic but is setup to show all the important info for a regular heli.
I used big boxes to display the info for guys/girls with "older eyes" and makes things easy to see at a quick glance.
Toggle icons are layed out in the position they are on the transmitter (12s), and only show when switch is activated. The two boxes at the top can represent knob value, or in this case they display the main blade pitch % and gyro gain %. You can use the upper trims to fine tune your hover pitch or tail gyro gain in flight.
The mix switch is used to select between three different gyro gain values. (Mix2 is set below 0% to switch gyro into rate mode where you can check/set the tail blade pitch.
Flight mode switch is also displayed next to throttle % box. It displays throttle amounts with a 0% - 100% scale. Hold switch will show 0%.
5 bargraphs for whatever channels you need displayed. I might use these to show the side dial positions.
Top timer on the right shows the countdown timer. It is triggered with the hold0 and reset with trn1. The stopwatch is below it and is also started when hold is off. I find this setup useful when using the simulator. The countdown timer keeps things real and reminds me its time to land, and the stopwatch shows how much total time i've wasted sitting in front of the computer.
In this layout the clock is in a big box for older eyes, but in my advanced layout i will need that space. I also dont see the need for a date box, but... why not.
ISSUES:
24hr clock
The clock did drop a min while i was setting up, and gained 4 hours at some point as well. It might just be an EMU thing when its shutdown.
After exit and save when i had finnished all the mixing info, the emu stoped responding and had to force quit. Thankfully the mix info did not get lost.
Pics below.
26 Jun 2013 09:20 #11390 by Kdean
Another pic.
26 Jun 2013 09:22 #11391 by Kdean
Last one.
26 Jun 2013 10:10 - 26 Jun 2013 10:26 #11393 by vlad_vy
I tried place custom templates at 'layout' directory, but I can't find them at load template dialog, I see Default, Empty and models files, nothing more.
Is it possible to use custom layout templates???
SOLVED. Wrong filenames. I need use 8.3 filenames.
Last edit: 26 Jun 2013 10:26 by vlad_vy.
26 Jun 2013 10:21 - 26 Jun 2013 10:51 #11394 by FDR
It should, but beware of the 8.3 naming convention!
I could copy and rename the default, and it appeared in the list...
EDIT: You were faster... ;)
Last edit: 26 Jun 2013 10:51 by FDR.
26 Jun 2013 10:33 - 28 Jun 2013 09:39 #11395 by vlad_vy
vlad_vy wrote:
vlad_vy wrote: Without any specific idea, to fill screen only.
File Attachment:
File Name: model1_2013-06-25.ini
File Size:1 KB
File Attachment:
File Name: model2_2013-06-25.ini
File Size:2 KB
The same layouts as templates for Devo 12
File Attachment:
File Name: Devo12-6.ini
File Size:1 KB
File Attachment:
File Name: Devo12-4.ini
File Size:1 KB
Last edit: 28 Jun 2013 09:39 by vlad_vy.
26 Jun 2013 10:52 #11396 by Kdean
This advanced layout is for devo12 only. Showing all toggles and dial inputs with bargraphs.
Leaving alot of space for boxes on either side.
26 Jun 2013 10:54 #11397 by Kdean
I'll upload the ini. Files as soon as i learn how to.....
26 Jun 2013 11:07 #11398 by FDR
Just attach it below the message with the "Add File" button...
26 Jun 2013 11:40 #11399 by Kdean
Here is my full blown gui layout with telemetry.
It not that i dont know how, but rather i have to figure out a way to get in on a device that can access the internet. I do all my posting from my iphone, i have to use my daughters tablet to download the emu files to the hp mini that i work on. Its confusing at times, i just have to do things in reverse.
26 Jun 2013 11:45 - 26 Jun 2013 11:46 #11400 by vlad_vy
I think you can use iPhone as a modem for HP Mini.
www.goodgearguide.com.au/article/333696/...e_your_iphone_modem/
Last edit: 26 Jun 2013 11:46 by vlad_vy.
26 Jun 2013 12:07 #11402 by Kdean
For that i would need a data plan on my phone, which i dont have. The hp's wifi is not working for some reason, and its the only windows device i have to work on.
26 Jun 2013 13:25 #11409 by cropduster
Replied by cropduster on topic PB's newgui
Hey PB,
are you actually going to provide an installable release for those who don't want to bother about compiling the sources etc., or is it to early to deploy on real DEVO12s for flying?
Thanks,
Michael
26 Jun 2013 14:02 #11410 by PhracturedBlue
Replied by PhracturedBlue on topic PB's newgui
FDR wrote: If it works that way, i.e. uses the default layout template when the layout section is missing from the model data, I agree, that the default model data could be without layout information.
Right this was the intent, and the code does load the default layout if none is available. I just never removed the code from the template model.ini.
26 Jun 2013 14:05 #11411 by PhracturedBlue
cropduster wrote: Hey PB,
Thanks,
Michael
The nightly build available right now has this interface.
26 Jun 2013 14:08 - 26 Jun 2013 14:34 #11412 by vlad_vy
PhracturedBlue wrote: I've merged this into the trunk. the next nightlies will contain this gui.
Nightly build f2e037 has Devo8 interface (320x240).
Compiled build also has Devo8 interface (320x240) and not work for me. Something wrong with compiled library, all fonts are missing. Compiled firmware with night library works, but interface is 320x240.
Last edit: 26 Jun 2013 14:34 by vlad_vy.
26 Jun 2013 14:34 #11415 by PhracturedBlue
Are you talking about loading the dfu onto the Tx, or not being able to build the emulator?
Time to create page: 0.377 seconds
