PB's newgui
27 Jun 2013 15:47 - 27 Jun 2013 15:49 #11459 by vlad_vy
Replied by vlad_vy on topic PB's newgui
vlad_vy wrote: P.S. Compiled library not works for me, all fonts missing. I used compiled firmware, but lib file I got from Nightly Builds.
I do not know what it is, but this time I was able successfully to flash the compiled library. Now I have the custom skin.
Possible I have to flash lib file twice?
Last edit: 27 Jun 2013 15:49 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
27 Jun 2013 15:55 #11460 by rbe2012
Replied by rbe2012 on topic PB's newgui
I have flashed only once, it worked from the start.
27 Jun 2013 17:26 #11462 by Hexperience
Replied by Hexperience on topic PB's newgui
I had to use the nightly as well. I tried flashing it twice but still didn't work. Did you do a devo8 build at any time? I remember some time ago the devo12 build wouldn't work unless you have built the devo8 (or devo8 fs) first.
27 Jun 2013 17:33 - 27 Jun 2013 17:34 #11463 by Hexperience
By the way... LOVE IT!!
Great work everyone.
12 hour clock please! And not sure if it's possible, but as the seconds tick along, the font causes the whole text field to shift back and forth.
Cheers!
Last edit: 27 Jun 2013 17:34 by Hexperience.
27 Jun 2013 19:01 #11464 by PhracturedBlue
Replied by PhracturedBlue on topic PB's newgui
Hexperience wrote: And not sure if it's possible, but as the seconds tick along, the font causes the whole text field to shift back and forth.
This is hard to fix. If we do as Vlad asks, and add the time to the title, we could draw hrs,mins,secs separately and not have this effect, but the boxes are all drawn as a single objects, and the only solution would be to create non-proportional numbers for the boxes. I think that would be a net loss.
27 Jun 2013 19:04 #11465 by Kdean
Replied by Kdean on topic PB's newgui
The seconds are not important, can you remove them in the display.
  • rbe2012
  • rbe2012's Avatar
27 Jun 2013 21:09 #11469 by rbe2012
If you decide to remove the seconds I think the boxes could be smaller - actually 113 pixels, what seems only necessary for hh:mm:ss in big boxes.
27 Jun 2013 21:32 - 27 Jun 2013 21:35 #11471 by Hexperience
Actually putting it in the title bar is perfect. Just add it to the base page and it will show up "all theo time"
And if we lose the seconds updates on that part of the screen only need to happen once a minute.
Last edit: 27 Jun 2013 21:35 by Hexperience.
27 Jun 2013 21:59 #11472 by PhracturedBlue
We could move the boxes to 96px and still have room for the largest printable number '99999' (RPM can go to 5 digits). But I think I probably won't make this change. I've had requests from the sailplane folks to add hours to the timer, so shrinking the boxes would just limit future options.
I'll add the clock to the top-bar (hrs/mins only), but main page only...sorry Hex).
I'm not sure about dropping the seconds, but if no one wants them, it is easy enough to remove.
27 Jun 2013 22:17 #11473 by Kdean
I vote no seconds.
Clock in main screen bar only is fine. Stick it over by settings icon, but remember the other icon has to go there when no model icon is in the display.
27 Jun 2013 22:21 - 27 Jun 2013 22:24 #11474 by Hexperience
I was just thinking it can go on the page where you draw the <next> and <prev> icons and do the scroll bars. I can't even remember where that was now...
Displaying only hours and minutes is better. It's a clock, we have 4 other timers to use if we need to know how many seconds are passing.
And if it's not going to be too much trouble, I for one would like the 12 hour clock. I can only count to 12... ;)
Last edit: 27 Jun 2013 22:24 by Hexperience.
28 Jun 2013 02:12 - 28 Jun 2013 02:14 #11477 by Kdean
Are you guy running version 09db3fe nightly in the 12s?
Is this the version with the fs problem with wide screen?
Or is it the latest nightly with the fixes?
Last edit: 28 Jun 2013 02:14 by Kdean.
28 Jun 2013 02:20 #11478 by Pattaya01
Replied by Pattaya01 on topic PB's newgui
Maybe this makes life easier:
Instead of having 1 clock with 2 formats, have 2 clocks, 1 with 12Hr format, 1 with 24Hr format. Like having timer 1 and timer 2. I also think no need for seconds.
28 Jun 2013 03:48 #11479 by Pattaya01
I am ready to test it on my Devo12S, but I face some problems, please help:
1) I have opened the DFU tool and connect to my TX
2) Startup TX while holding TRN switch
3) Upgrade deviation-devo12-v3.0.0-9db3fe.dfu
Sofar, so good
Then, according the installation manual, I should:
4) Select "Library" and select devo12-lib.dfu
But after I selected this file, I cannot "Upgrade" This button is not active. I can only select "Upload".
So I get very confused. I tried upload, takes about 20 minutes and it changed the file on my PC.
What to do???
28 Jun 2013 03:52 - 28 Jun 2013 03:53 #11480 by PhracturedBlue
you selected the wrong file box in the dfuse tool on the library page. there is one box for 'uploading' and a different box for 'upgrading'.
Also, never just push buttons if you don't know what you are doing. If the instructions say to 'Upgrade' and NOT to 'Upload', then don't press the 'Upload' button anyway!
Last edit: 28 Jun 2013 03:53 by PhracturedBlue.
28 Jun 2013 03:57 #11481 by Pattaya01
PhracturedBlue wrote: you selected the wrong file box in the dfuse tool on the library page. there is one box for 'uploading' and a different box for 'upgrading'.
OK-OK. Thanks for pointing me in the right direction. Stupid me. Yes, I selected the wrong file box.... :blush:
28 Jun 2013 03:57 #11482 by Kdean
Is this version the fixed version? Or should i wait for the next nightly? I wanna start doing some in tx testing tonight....
28 Jun 2013 04:07 - 28 Jun 2013 04:07 #11483 by vlad_vy
You neen wait several hours, to next Nightly Build -> Submitted On:28 Jun 2013.
Last edit: 28 Jun 2013 04:07 by vlad_vy.
28 Jun 2013 04:11 #11484 by PhracturedBlue
Builds are uploaded nightly at ~2AM Pacific time (currently UTC-7)
28 Jun 2013 04:26 - 28 Jun 2013 04:28 #11485 by vlad_vy
PB, is it possible to use at 'Input monitor' screen not translatable text labels? As for AUX2, ... AUX7. For example, with russian interface it looks very strange.
Last edit: 28 Jun 2013 04:28 by vlad_vy.
Time to create page: 0.214 seconds
