PB's newgui
28 Jun 2013 13:59 - 28 Jun 2013 14:00 #11511 by vlad_vy
Replied by vlad_vy on topic PB's newgui
PB, my last steps:
1. Unpack source code archive into empty 'deviation' catalog
2. 'make TARGET=devo12'
3. Flash lib dfu
4. all fonts missing
5. 'make distclean'
6. 'make TARGET=devo12'
7. Flash lib dfu
8. All OK.
Next pass
2. 'make distclean'
3. 'make TARGET=devo12'
4. Flash lib dfu
5. all fonts missing
6. 'make distclean'
7. 'make TARGET=devo12'
8. Flash lib dfu
9. All OK.
lib dfu always has the same size 2 098 485.
Last edit: 28 Jun 2013 14:00 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
28 Jun 2013 14:00 #11512 by rbe2012
Replied by rbe2012 on topic PB's newgui
Pattaya01 wrote: ...2 observations:
1) There is a "Bleeberdebeep" every 20 or 30 seconds or so
I had this too - might be a too low battery warning level (Devo8 works with higher voltage). Standard for Devo12 should be 3.80V.
28 Jun 2013 14:30 #11513 by Pattaya01
Replied by Pattaya01 on topic PB's newgui
I noticed something, but is very minor issue:
When I touch the screen, the battery voltage indication drops about 0.1 Volt (100 mV). Is this real or is this a mistake?
The "Bleeberdebeep" I mentioned before was because of the default setting of the TX battery alarm. After reducing that to 3.8, is gone.
  • rbe2012
  • rbe2012's Avatar
28 Jun 2013 15:13 #11514 by rbe2012
I have a drop in the range of 0.03 to 0.04V - seems normal to me as I have seen it all the time.
28 Jun 2013 15:36 #11515 by Hexperience
Replied by Hexperience on topic PB's newgui
Yep, that voltage drop has been around since the beginning. I've been flying deviation on my 12s for 6 months now and never had a problem.
28 Jun 2013 16:23 #11519 by Hexperience
PB, is it possible to add more files in the layout folder? Will it scan for files that are there or only the default and blank?
28 Jun 2013 16:40 #11521 by PhracturedBlue
Replied by PhracturedBlue on topic PB's newgui
Hexperience wrote: PB, is it possible to add more files in the layout folder? Will it scan for files that are there or only the default and blank?
Yes it scans the directory.
28 Jun 2013 16:46 - 28 Jun 2013 16:49 #11522 by Hexperience
Awesome, thanks.
One last request from me... (for now)
I would love to see an empty text box object that we could add text to based on an input.
For example, a large box that I can enter text like GEAR, and have it fill in (or change) the text when I hit the gear switch.
Or HOLD etc.. what ever text we want. I know that it will be up to the user to make sure the text fits, but we're all big boys around here right? ;)
Maybe even we could select if we want the background color to be red?
Could be used for any custom text lable we want, but some ideas might be;
FLAPS
STUNT 1
ELEVON MIX ON <- might in a small box
Again.. whatever we want.
Last edit: 28 Jun 2013 16:49 by Hexperience.
28 Jun 2013 20:39 #11531 by Kdean
Replied by Kdean on topic PB's newgui
Ok, im about to flash to new nightly 8a4a0b. If you dont hear from me in a while, its because im haveing too much fun playing with my 12s.
29 Jun 2013 00:26 #11533 by Pattaya01
Hexperience wrote: Awesome, thanks.
Yep, that would be the same like custom toggles.
29 Jun 2013 01:25 #11534 by Pattaya01
Not sure if this is the right place to report this bug, but let's go:
I have some old receivers working on DSM2. When I change the protocol to DSM2, even though mode is Mode2, it changes to mode 1 and the channels are mixed up. During startup I get the message "Channel 1 not -100%" (or similar).
When I change back to Devo protocol, all is fine.
Looks like something is going wrong here.
29 Jun 2013 01:35 #11535 by PhracturedBlue
That isn't a bug. Deviation doesn't automatically redefine the channel outputs after changing the protocol. You need to change the channel assignments or read one of the templates.
29 Jun 2013 01:39 #11536 by PhracturedBlue
I am not planning to add the ability to show user specifIed text anytime soon. Sorry. Besides requiring a lot of ram to store the strings, it would require significant interface changes to make itreasonably useful. I have two items left in my list to do, then it'll be time to stabilize for the next release
29 Jun 2013 03:26 #11538 by Kdean
I just accidentally erased a bargraph again trying to edit it or scroll down to the next one. The delete button is still too close to things. Maybe we can make the delete buttons smaller, or add a cancel button......
I know you only have to layout the screen once, but if you want to edit your bargraphs to show a different ch for a special reason, you may end up haveing to place a new bargraph or replace the one you accidentaly deleted at the field.
Its much better being able to test the layout on the real thing. Im finding that its alot different than working the emu with a mouse and keyboard.
I've decided to do a complete model setup that will contain my advanced layout for 12s. It would be easy to delete the thing you dont need and keep things consistant between models. I'll try to post it later tonight.
Loving it.........
Great work to all those involved.
29 Jun 2013 03:30 #11539 by Pattaya01
I noticed on the mixer screen it does not mention the switches assigned in the complex mode. On the emulator it does.
29 Jun 2013 03:35 #11540 by Kdean
I only see switch assignment in mixer page when its Expo&DR. Thats emu and in tx.
29 Jun 2013 04:39 #11542 by Pattaya01
Kdean wrote: I only see switch assignment in mixer page when its Expo&DR. Thats emu and in tx.
Yes, you're right. Sorry for that. I do my best to find bugs, but cannot find them.... :silly:
30 Jun 2013 00:53 - 30 Jun 2013 01:35 #11601 by Pattaya01
Doesn't really looks like a bug, but I noticed this:
1) I have 4 toggles and move them around
2) I move toggle1 behind the "Model" by mistake
3) I click on model, toggle1 disappears behind the model
4) I select 1 of the other toggles and press "Enter"
5) I press OK
6) Toggle1 becomes visible above Model
But when I press on toggle1, model gets selected.
The only way to move toggle one from behind model is to move model away, move toggle1 to the place where it should be, move model back into place.
Not a very big deal, but maybe the toggle should become selectable after step 6).
Last edit: 30 Jun 2013 01:35 by Pattaya01.
30 Jun 2013 02:03 - 30 Jun 2013 02:15 #11607 by Pattaya01
PhracturedBlue wrote:
FDR wrote: After installing the development environment, you can compile your own customized library... ;)
There is a virtual machine already prepared:
www.deviationtx.com/forum/how-to/1200-vm...-compiling-deviation
Or you can wait a few more <insert time scale here> until my replacement for DFuse is ready. That will allow you to update the devo12 filesystem much like the devo8. Of course I have no idea when I'll get back to working on it.
Isn't it a much easier solution to create a folder named "Custom". Here, users can put their home made model icons, toggles, backgrounds, etc. This will take far less space as the media directory.
Last edit: 30 Jun 2013 02:15 by Pattaya01.
30 Jun 2013 10:53 - 30 Jun 2013 10:59 #11626 by vlad_vy
If touch main screen, to the right from battery voltage I can see remainder of 'V' letter. In case if voltage in time of touch has more wide numerals:
"4.03V 14:57" -> "4.15V/ 14:57"
Last edit: 30 Jun 2013 10:59 by vlad_vy.
Time to create page: 0.415 seconds
