Problems building
- IMback!
01 Jul 2013 19:56 #11685
by IMback!
Problems building was created by IMback!
I just tryed building deviation for the devo 7e (current PhracturedBlue repo) using arm-none-eabi toolchain (gcc v4.7.3) from arch aur. It errors out:
I assume this is due to the work currently going on the devo 6/8/12 gui? how can i get old sources (for deviaton 3.0)?
+ Building 'devo7e.elf'
objs/devo7e/pages.o:(.rodata.pages+0x120): undefined reference to `PAGE_DatalogInit'
objs/devo7e/pages.o:(.rodata.pages+0x124): undefined reference to `PAGE_DatalogEvent'
collect2: error: ld returned 1 exit status
make: *** [devo7e.elf] Error 1I assume this is due to the work currently going on the devo 6/8/12 gui? how can i get old sources (for deviaton 3.0)?
- sbstnp
01 Jul 2013 20:33 - 01 Jul 2013 20:34 #11686
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Problems building
The toolchain from ArchLinux AUR doesn't work. You should use summon-arm-toolchain script. Tried and tested by yours truly. It can eventually complete the build but the code just locks out/reboots the transmitter.
There's a virtual machine running arch in the How To section with everything installed:
deviationtx.com/forum/how-to/1200-vm-ded...-compiling-deviation
Devo 10 + 4in1
Last edit: 01 Jul 2013 20:34 by sbstnp.
01 Jul 2013 21:02 #11689
I got the same errors with my standard MinGW on Windows build environment (even with make distclean). Looks like a real bug.
Replied by rbe2012 on topic Problems building
IMback! wrote: ...It errors out:...
- sbstnp
02 Jul 2013 03:28 #11702
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Dataloggin isn't supposed to be available on the 7E, so any reference to those pages is a bug indeed.
Still, the heads up about the AUR toolchain still stands.
Devo 10 + 4in1
02 Jul 2013 03:43 #11703
Replied by PhracturedBlue on topic Problems building
I checked in a fix for the devo7e build. As mentioned. follow the REAdME instructions, or use one of the pre-built solutions on the forums. The arm toolchains are very touchy, and you woon't be able to get any help if you don't use one of the documented methods.
- Problems building
