Servo timing limits for Devo 10 needed please
18 Aug 2013 00:28 - 18 Aug 2013 00:29 #13021 by mono
May I please ask if anyone knowing this information could provide it to help me with a module project for Devo 10 as per this thread...
www.rcgroups.com/forums/showthread.php?t=1954078&pp=50
www.rcgroups.com/forums/showpost.php?p=25871532&postcount=365
The format of the info needed is...
min= xxxx μs
max= xxxx μs
center= xxxx μs
Thanks for any assistance. :)
Last edit: 18 Aug 2013 00:29 by mono.
18 Aug 2013 03:51 #13022 by sbstnp
On a new model with 100% travel I get:
max = 1840
center = 1500
min = 1160
If you increase the range you can go under 1000 and above 2000, if needed (like when using Multiwii).
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
18 Aug 2013 03:55 #13023 by Cesco
Do you post only the hex files or also the source of your project?
18 Aug 2013 05:00 - 18 Aug 2013 05:01 #13024 by mono
sbstnp wrote: On a new model with 100% travel I get:
max = 1840
center = 1500
min = 1160
thank you very much for that.
One of the contributors in the thread I linked to believes there may be a difference in the results between a standard devo 10 and one with deviation,
What do you think?
Cesco wrote: Do you post only the hex files or also the source of your project?
It is not my project, I'm just one of those taking part by building the module. There are hex files and circuits at the beginning of the thread but you need a different hex for other radios. So far there is ones for 9x and Dx6i. No source at this point.
The project's creator is helping me to make a module for a devo 10 so that it will run flysky/hubsan stuff without needing deviation on it.
I have deviation on my 6S but not on the 10.
Last edit: 18 Aug 2013 05:01 by mono.
18 Aug 2013 06:41 - 18 Aug 2013 06:41 #13025 by sbstnp
max = 1840
center = 1500
min = 1160
What do you think?
Probably. But I don't expect to be way off compared to the values above and I'm not flashing stock just to check, sorry :)
Devo 10 + 4in1
Spektrum Dx9
Last edit: 18 Aug 2013 06:41 by sbstnp.
18 Aug 2013 07:23 - 18 Aug 2013 07:26 #13026 by mono
No, of course not, I would never ask or expect that of anyone, it was just asking for your opinion to see if you might know.
The help you have provided (I see you helping many people on this and other forums) is greatly appreciated, thanks.
Last edit: 18 Aug 2013 07:26 by mono. Reason: typo
Time to create page: 0.060 seconds
