Servo timing limits for Devo 10 needed please
- mono
18 Aug 2013 00:28 - 18 Aug 2013 00:29 #13021
by mono
Servo timing limits for Devo 10 needed please was created by mono
May I please ask if anyone knowing this information could provide it to help me with a module project for Devo 10 as per this thread...
www.rcgroups.com/forums/showthread.php?t=1954078&pp=50
www.rcgroups.com/forums/showpost.php?p=25871532&postcount=365
The format of the info needed is...
min= xxxx μs
max= xxxx μs
center= xxxx μs
Thanks for any assistance.
min= xxxx μs
max= xxxx μs
center= xxxx μs
Last edit: 18 Aug 2013 00:29 by mono.
- sbstnp
18 Aug 2013 03:51 #13022
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Servo timing limits for Devo 10 needed please
On a new model with 100% travel I get:
max = 1840
center = 1500
min = 1160
If you increase the range you can go under 1000 and above 2000, if needed (like when using Multiwii).
max = 1840
center = 1500
min = 1160
Devo 10 + 4in1
- Cesco
18 Aug 2013 03:55 #13023
by Cesco
Replied by Cesco on topic Servo timing limits for Devo 10 needed please
Do you post only the hex files or also the source of your project?
- mono
18 Aug 2013 05:00 - 18 Aug 2013 05:01 #13024
by mono
thank you very much for that.
One of the contributors in the thread I linked to believes there may be a difference in the results between a standard devo 10 and one with deviation,
What do you think?
The project's creator is helping me to make a module for a devo 10 so that it will run flysky/hubsan stuff without needing deviation on it.
I have deviation on my 6S but not on the 10.
Replied by mono on topic Servo timing limits for Devo 10 needed please
sbstnp wrote: On a new model with 100% travel I get:
max = 1840
center = 1500
min = 1160
What do you think?
It is not my project, I'm just one of those taking part by building the module. There are hex files and circuits at the beginning of the thread but you need a different hex for other radios. So far there is ones for 9x and Dx6i. No source at this point.Cesco wrote: Do you post only the hex files or also the source of your project?
Last edit: 18 Aug 2013 05:01 by mono.
- sbstnp
18 Aug 2013 06:41 - 18 Aug 2013 06:41 #13025
by sbstnp
Probably. But I don't expect to be way off compared to the values above and I'm not flashing stock just to check, sorry
Devo 10 + 4in1
Spektrum Dx9
max = 1840
center = 1500
min = 1160
What do you think?
Devo 10 + 4in1
Last edit: 18 Aug 2013 06:41 by sbstnp.
- mono
18 Aug 2013 07:23 - 18 Aug 2013 07:26 #13026
by mono
No, of course not, I would never ask or expect that of anyone, it was just asking for your opinion to see if you might know.
The help you have provided (I see you helping many people on this and other forums) is greatly appreciated, thanks.
Last edit: 18 Aug 2013 07:26 by mono. Reason: typo
Time to create page: 0.043 seconds
- Servo timing limits for Devo 10 needed please
