publishing an intermediate release 3.1.0?
18 Oct 2013 06:45 #14748
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
#409 was fixed with my work yesterday.
18 Oct 2013 06:58 #14749
You don't need Rx for that. Set telemetry voltage sensors for boxes, for model with Devo protocol and for model with DSMX protocol. Then change model and you will see that box with sensor changed. If you reboot Tx, box with sensor will restore.
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
rbe2012 wrote: take a look in #402 but no way for testing due to a lack of Spektrum telemetry receivers here).
18 Oct 2013 07:18 #14750
Ok, I'll try.
- clearprop88
19 Oct 2013 20:03 - 19 Oct 2013 20:05 #14789
by clearprop88
Replied by clearprop88 on topic publishing an intermediate release 3.1.0?
@rbe2012
Thanks for looking at #352 (AR7200BX). I think I was the one who wrote that one up.
I have 2 BX's, and at the time I wrote that up I was having a problem with both of them while using my 8S, but no problems with my Spectrum DX8. My Devo 8S has been on the shelf ever since. The problem may have been resolved in the nightlies, but I haven't heard that #352 was actually addressed. I would really like to use my Devo 8S to fly with the BX's. I like the Devo 8S much better than the DX8.
Last edit: 19 Oct 2013 20:05 by clearprop88. Reason: correction
20 Oct 2013 09:41 #14793
Sorry clearprop88,
I expected to see a flyer yesterday who has a Blade 300x with ar7200bx, but he was sick and did not come. This was my only chance for the next few weeks.
- clearprop88
20 Oct 2013 15:25 #14811
by clearprop88
Whenever you get around to it is fine. I would like to hear your comments about it. Thanks.rbe2012 wrote: Sorry clearprop88,
- pulpfiction15
20 Oct 2013 17:30 #14812
by pulpfiction15
Replied by pulpfiction15 on topic publishing an intermediate release 3.1.0?
I am flying blade 300x, two 450x and a trex550 DFC all with a 7200 BX without problems, version 3.0 and now the nighly build (12Aug).
- richardclli
20 Oct 2013 17:56 - 20 Oct 2013 23:40 #14813
by richardclli
I just have a flight today using AR7200BX in my Align 250 DFC. I fly 10 batteries without encountering any instability issue, so I think the problem is gone or just not there.
I used the latest firmware 3.1.0 in AR7200BX.
Replied by richardclli on topic publishing an intermediate release 3.1.0?
rbe2012 wrote: Maybe I have a chance to confirm that #352 (AR7200BX) is no general problem this weekend.
Last edit: 20 Oct 2013 23:40 by richardclli.
21 Oct 2013 07:40 #14825
I can not reproduce this. I have the option in both emulators (if I enable the protocol with "enable-a7105=A13" in tx.ini) and in any combination the option is saved.
FDR wrote:
rbe2012 wrote:
There is one: "WLToys V9x9" can be on or off...FDR wrote: #419: Flysky protocol option always Off after reboot on Devo7e
I don't see any protocol options for Flysky at all...
Strange! It is there in the emu_devo10, but missing from the 8 and 12!
21 Oct 2013 10:40 #14828
Replied by FDR on topic publishing an intermediate release 3.1.0?
You are right, sorry!
The enable-a7105 was missing from those tx.ini's...
21 Oct 2013 12:15 - 22 Oct 2013 08:12 #14830
I have fixed some issues. Here is the actual list of open issues from PB:
Here is the list of bugs reported in PBs repo:
And here the list of issues fixed in the deviation-3.1 repo:
What next?
I will publish all versions in my repo ( download area ) so you can test it if you want.
| #32 | Nine-Eagles binding with non-telemetry module | won't fix actually |
| #56 | Model won't re-connect when Tx is rebooted. | PB said: this works as intended. Rebind is possible with fixed ID (Devo, DSM2, DSMx) - won't fix |
| #60 | Fixed ID is not the same assigned by Walkera radios | only a problem when sharing rx between WK2801 tx and deviation tx - won't fix |
| #195 | Virt channel as a source | Discussion did not lead to a result - won't fix |
| #334 | devo10-v3.0.0 rebooted | singular problem, PB has fixed, but no feedback - nothing to do |
| #352 | AR7200BX Compatibility Issue | After the latest testing this issue seems to be gone - nothing to do actually |
| #356 | Errors.txt is not generated on Devo12 | just for debugging - don't care actually |
| #370 | Devo 12 sliders | not sure if we should change the behavior - won't fix |
| #373 | Devo 7e Hangs going to menu | sounds like an incomplete installation, error not confirmed for actual version - won't fix |
| #374 | Devo 7e Reboots on moddel resett | not confirmed fro actual version - won't fix |
| #375 | DEVO 8s start bug | also not confirmed, in 3.0.0 - won't fix |
| #382 | Devo 12 reboot with telemetry | can't test this - won't fix |
| #386 | Dev08s Reset while using Flysky V911 protocol | unclear behavior, won't fix |
| #387 | devo10 hangs at bootup | probably defective hardware - won't fix |
| #388 | Standard Mixer GUI | Probably an issue due to incompatible model files (version changes) - won't fix |
| #419 | Flysky protocol option always Off after reboot on Devo7e | was not able to reproduce - wait until confirmed again |
| #420 | Fatal reboot on DEVO 8S and 2.1.1 deviation | won't fix 2.1 issues |
| #1 | PB #422: DEVO 10 - Rename virtual channels | bug | major | resolved |
| #2 | PB #421: Devo 10 German Language file causes crashes | bug | major | resolved |
| #3 | PB #409: Bigbox not fully implemented on Devo7/10 | bug | major | resolved |
| #4 | PB #413: emulator for Devo6 | enhancement | minor | resolved |
| #5 | PB #414: rework chantest_page | bug | minor | resolved |
| #6 | PB #423: Trim page doesn't save trim step changes | bug | major | resolved |
| #7 | PB #411: Italian language file truncated | bug | major | resolved |
| #8 | Bargraphs not working for Devo7e/10 | bug | major | resolved |
| #9 | Protocol options for Flysky | task | trivial | new |
| #10 | PB #402: Telemetry box changed after model change | bug | major | resolved |
| #11 | PB #360 + #389: Last model not saved | bug | major | resolved |
| #12 | PB #383: Touch screen position | bug | major | resolved |
| #13 | PB #404: toggle_select.c miscalculates scrollbar | bug | minor | resolved |
| #14 | PB #412: 320x240: ok/cancel on reorder page | bug | minor | resolved |
| #15 | PB #415: Wrong elements selected in listbox | bug | minor | resolved |
| #16 | PB #417: display.c can not handle header_time if no RTC found | bug | trivial | resolved |
| #17 | PB #381: Increase Skyartec protocol power output - default is now is 1mW | enhancement | minor | new |
| #18 | Force RF power output to minimum when PPMOUT selected | enhancement | minor | new |
| #19 | DEVO10 - Renamed virtual channels do not show in small-box and big-box | bug | major | resolved |
| #20 | No RF output after changing protocol (only when turning tx on) | bug | major | new |
| EDIT: Update 2013-10-22 | ||||
| #21 | Button monitor (russian version) | bug | major | resolved |
| #22 | Russian language update | enhancement | major | resolved |
| #23 | Protocol change and telemetry | bug | major | resolved |
| #24 | No channel reordering after protocol change | bug | major | resolved |
| #25 | Images with odd width are not drawn properly | bug | minor | resolved |
What next?
Last edit: 22 Oct 2013 08:12 by rbe2012.
21 Oct 2013 12:47 #14831
I have uploaded the files now.
- SadSack
21 Oct 2013 13:31 - 21 Oct 2013 13:32 #14832
by SadSack
Replied by SadSack on topic publishing an intermediate release 3.1.0?
LOL made me smile!
LOL made me smile!
Last edit: 21 Oct 2013 13:32 by SadSack.
21 Oct 2013 13:39 #14834
It's because I never looked into this part of code and it seems to me to need a huge effort - and I am not sure if it is worth this now. I think that PB is the only one who could read the error.txt and he seems to be still absend - so there is no use of the errors.txt at all.SadSack wrote: Errors.txt is not generated on Devo12
LOL made me smile!
- WheresWaldo
21 Oct 2013 16:52 - 21 Oct 2013 19:01 #14844
by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
Finally have my NAS server back up and running. Couldn't get CentOS to see my Areca card. Had to resort to building a Windows server. Just cloned deviation-3.1 and am building now. Will test on my Devo10 shortly. Have a few spare hours today as its my day off.
UPDATE: Been running this through the menus and can report so far that everything I have tried is working so far on the Devo 10!
Last edit: 21 Oct 2013 19:01 by WheresWaldo.
22 Oct 2013 04:37 #14858
Possibly it was discussed already. Is it possible to remap channels mixers automatically with protocol change or it will be complex task?
22 Oct 2013 05:50 - 22 Oct 2013 08:05 #14859
Last edit: 22 Oct 2013 08:05 by rbe2012.
22 Oct 2013 08:30 #14862
Thanks, RBE. On first glance all looks fine!!! Tested with two models, after changing protocol (DEVO, DSMX) channels mixers remapped ideally, no problems.
22 Oct 2013 08:43 #14863
Found one drawback only. Timers switch remains without change, CH3 or CH1.
I dont know if there is any need to change it.
22 Oct 2013 08:49 #14864
IMO yes.
The Ch3 could be used in a lot of places as source or switch. They should be all exchanged, if you want the same behaviour...
So yes, I think it is complex...
Time to create page: 0.331 seconds
- publishing an intermediate release 3.1.0?
