publishing an intermediate release 3.1.0?
  • rbe2012
  • rbe2012's Avatar Topic Author
18 Oct 2013 06:45 #14748 by rbe2012
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
#409 was fixed with my work yesterday.
18 Oct 2013 06:58 #14749 by vlad_vy
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
rbe2012 wrote: take a look in #402 but no way for testing due to a lack of Spektrum telemetry receivers here).
You don't need Rx for that. Set telemetry voltage sensors for boxes, for model with Devo protocol and for model with DSMX protocol. Then change model and you will see that box with sensor changed. If you reboot Tx, box with sensor will restore.
  • rbe2012
18 Oct 2013 07:18 #14750 by rbe2012
Ok, I'll try.
19 Oct 2013 20:03 - 19 Oct 2013 20:05 #14789 by clearprop88
Replied by clearprop88 on topic publishing an intermediate release 3.1.0?
@rbe2012
Thanks for looking at #352 (AR7200BX). I think I was the one who wrote that one up.
I have 2 BX's, and at the time I wrote that up I was having a problem with both of them while using my 8S, but no problems with my Spectrum DX8. My Devo 8S has been on the shelf ever since. The problem may have been resolved in the nightlies, but I haven't heard that #352 was actually addressed. I would really like to use my Devo 8S to fly with the BX's. I like the Devo 8S much better than the DX8.
Last edit: 19 Oct 2013 20:05 by clearprop88. Reason: correction
  • rbe2012
20 Oct 2013 09:41 #14793 by rbe2012
Sorry clearprop88,
I expected to see a flyer yesterday who has a Blade 300x with ar7200bx, but he was sick and did not come. This was my only chance for the next few weeks.
20 Oct 2013 15:25 #14811 by clearprop88
rbe2012 wrote: Sorry clearprop88,
Whenever you get around to it is fine. I would like to hear your comments about it. Thanks.
20 Oct 2013 17:30 #14812 by pulpfiction15
Replied by pulpfiction15 on topic publishing an intermediate release 3.1.0?
I am flying blade 300x, two 450x and a trex550 DFC all with a 7200 BX without problems, version 3.0 and now the nighly build (12Aug).
20 Oct 2013 17:56 - 20 Oct 2013 23:40 #14813 by richardclli
Replied by richardclli on topic publishing an intermediate release 3.1.0?
rbe2012 wrote: Maybe I have a chance to confirm that #352 (AR7200BX) is no general problem this weekend.
I just have a flight today using AR7200BX in my Align 250 DFC. I fly 10 batteries without encountering any instability issue, so I think the problem is gone or just not there.
I used the latest firmware 3.1.0 in AR7200BX.
Last edit: 20 Oct 2013 23:40 by richardclli.
  • rbe2012
21 Oct 2013 07:40 #14825 by rbe2012
FDR wrote:
rbe2012 wrote:
FDR wrote: #419: Flysky protocol option always Off after reboot on Devo7e
I don't see any protocol options for Flysky at all... :unsure:
There is one: "WLToys V9x9" can be on or off...
Strange! It is there in the emu_devo10, but missing from the 8 and 12!
I can not reproduce this. I have the option in both emulators (if I enable the protocol with "enable-a7105=A13" in tx.ini) and in any combination the option is saved.
21 Oct 2013 10:40 #14828 by FDR
You are right, sorry!
The enable-a7105 was missing from those tx.ini's...
  • rbe2012
21 Oct 2013 12:15 - 22 Oct 2013 08:12 #14830 by rbe2012
I have fixed some issues. Here is the actual list of open issues from PB:
Here is the list of bugs reported in PBs repo:
#32Nine-Eagles binding with non-telemetry modulewon't fix actually
#56Model won't re-connect when Tx is rebooted.PB said: this works as intended. Rebind is possible with fixed ID (Devo, DSM2, DSMx) - won't fix
#60Fixed ID is not the same assigned by Walkera radiosonly a problem when sharing rx between WK2801 tx and deviation tx - won't fix
#195Virt channel as a sourceDiscussion did not lead to a result - won't fix
#334devo10-v3.0.0 rebootedsingular problem, PB has fixed, but no feedback - nothing to do
#352AR7200BX Compatibility IssueAfter the latest testing this issue seems to be gone - nothing to do actually
#356Errors.txt is not generated on Devo12just for debugging - don't care actually
#370Devo 12 slidersnot sure if we should change the behavior - won't fix
#373Devo 7e Hangs going to menusounds like an incomplete installation, error not confirmed for actual version - won't fix
#374Devo 7e Reboots on moddel resettnot confirmed fro actual version - won't fix
#375DEVO 8s start bugalso not confirmed, in 3.0.0 - won't fix
#382Devo 12 reboot with telemetrycan't test this - won't fix
#386Dev08s Reset while using Flysky V911 protocolunclear behavior, won't fix
#387devo10 hangs at bootupprobably defective hardware - won't fix
#388Standard Mixer GUIProbably an issue due to incompatible model files (version changes) - won't fix
#419Flysky protocol option always Off after reboot on Devo7ewas not able to reproduce - wait until confirmed again
#420Fatal reboot on DEVO 8S and 2.1.1 deviationwon't fix 2.1 issues
And here the list of issues fixed in the deviation-3.1 repo:
#1PB #422: DEVO 10 - Rename virtual channelsbugmajorresolved
#2PB #421: Devo 10 German Language file causes crashesbugmajorresolved
#3PB #409: Bigbox not fully implemented on Devo7/10bugmajorresolved
#4PB #413: emulator for Devo6enhancementminorresolved
#5PB #414: rework chantest_pagebugminorresolved
#6PB #423: Trim page doesn't save trim step changesbugmajorresolved
#7PB #411: Italian language file truncatedbugmajorresolved
#8Bargraphs not working for Devo7e/10bugmajorresolved
#9Protocol options for Flyskytasktrivialnew
#10PB #402: Telemetry box changed after model changebugmajorresolved
#11PB #360 + #389: Last model not savedbugmajorresolved
#12PB #383: Touch screen positionbugmajorresolved
#13PB #404: toggle_select.c miscalculates scrollbarbugminorresolved
#14PB #412: 320x240: ok/cancel on reorder pagebugminorresolved
#15PB #415: Wrong elements selected in listboxbugminorresolved
#16PB #417: display.c can not handle header_time if no RTC foundbugtrivialresolved
#17PB #381: Increase Skyartec protocol power output - default is now is 1mWenhancementminornew
#18Force RF power output to minimum when PPMOUT selectedenhancementminornew
#19DEVO10 - Renamed virtual channels do not show in small-box and big-boxbugmajorresolved
#20No RF output after changing protocol (only when turning tx on)bugmajornew
EDIT: Update 2013-10-22
#21Button monitor (russian version)bugmajorresolved
#22Russian language updateenhancementmajorresolved
#23Protocol change and telemetrybugmajorresolved
#24No channel reordering after protocol changebugmajorresolved
#25Images with odd width are not drawn properlybugminorresolved
What next?
I will publish all versions in my repo ( download area ) so you can test it if you want.
Last edit: 22 Oct 2013 08:12 by rbe2012.
  • rbe2012
21 Oct 2013 12:47 #14831 by rbe2012
I have uploaded the files now.
21 Oct 2013 13:31 - 21 Oct 2013 13:32 #14832 by SadSack
Replied by SadSack on topic publishing an intermediate release 3.1.0?
LOL made me smile!
Last edit: 21 Oct 2013 13:32 by SadSack.
  • rbe2012
21 Oct 2013 13:39 #14834 by rbe2012
SadSack wrote: Errors.txt is not generated on Devo12
LOL made me smile!
It's because I never looked into this part of code and it seems to me to need a huge effort - and I am not sure if it is worth this now. I think that PB is the only one who could read the error.txt and he seems to be still absend - so there is no use of the errors.txt at all.
21 Oct 2013 16:52 - 21 Oct 2013 19:01 #14844 by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
Finally have my NAS server back up and running. Couldn't get CentOS to see my Areca card. Had to resort to building a Windows server. Just cloned deviation-3.1 and am building now. Will test on my Devo10 shortly. Have a few spare hours today as its my day off.
UPDATE: Been running this through the menus and can report so far that everything I have tried is working so far on the Devo 10!
Last edit: 21 Oct 2013 19:01 by WheresWaldo.
22 Oct 2013 04:37 #14858 by vlad_vy
Possibly it was discussed already. Is it possible to remap channels mixers automatically with protocol change or it will be complex task?
  • rbe2012
22 Oct 2013 05:50 - 22 Oct 2013 08:05 #14859 by rbe2012
It is probably complex, but I will take a look at it.
EDIT: I fixed it in my actual commit bff2b07
Last edit: 22 Oct 2013 08:05 by rbe2012.
22 Oct 2013 08:30 #14862 by vlad_vy
Thanks, RBE. On first glance all looks fine!!! Tested with two models, after changing protocol (DEVO, DSMX) channels mixers remapped ideally, no problems.
22 Oct 2013 08:43 #14863 by vlad_vy
Found one drawback only. Timers switch remains without change, CH3 or CH1.
I dont know if there is any need to change it.
22 Oct 2013 08:49 #14864 by FDR
IMO yes.
The Ch3 could be used in a lot of places as source or switch. They should be all exchanged, if you want the same behaviour...
So yes, I think it is complex... ;)
Time to create page: 0.216 seconds
