Documentation Discussion
31 Dec 2013 14:38 #17570 by WheresWaldo
Replied by WheresWaldo on topic Documentation Discussion
kreidler wrote: ...
- Section 2.3. file system: The BMP do have 96x96 pixels. Last line for Devo7e can be removed.
- Many of the images do not have a left-hand margin to the text.
Happy new year to all.
Yeah I fixed the second issue within my copy, it is just a single click on left to make it 0.10" It's only a few images that need a bit of tweaking, we can do that stuff after release so we don't cause any more grief for PB.
31 Dec 2013 16:00 #17574 by PhracturedBlue
Replied by PhracturedBlue on topic Documentation Discussion
Keidler, I can't take you last pull request. For some reason, you have spaces all over the place (like in the middle of words and before periods. I already spent a lot of time fixing that stuff, and I don't want to do it again. I did manually try to apply the relevant changes, but I may have missed some.
31 Dec 2013 17:33 #17586 by kreidler
Replied by kreidler on topic Documentation Discussion
Sorry vor any inconvenience. I cannot cross check for today anymore. I expect you have implemented the changes better than I did. So, back to party. :evil:
27 Jan 2014 11:28 - 27 Jan 2014 11:34 #19264 by linux-user
Replied by linux-user on topic Documentation Discussion
While trying to make a german translation of the DeviationManual I've been looking around what is already there :huh: .
I found RBE's deviation-modelconfig-manual < bitbucket.org/rbe2012/deviation-modelconfig-manual > which apparently hasn't found its way into the official documentation.
Should this be added as an addendum to the official documenation?
Maybe it needs an update to reflect 4.0.0
Last edit: 27 Jan 2014 11:34 by linux-user.
  • rbe2012
  • rbe2012's Avatar
27 Jan 2014 11:53 #19266 by rbe2012
Replied by rbe2012 on topic Documentation Discussion
The model-config manual was started with 3.0 an the main missing part are the mixer settings. But it might be a good base.
What I have done was to look into the methods which are reading ini-files (in .../config/) and examine what they can understand. Main changes are only for the gui and the hardware.ini.
29 Jan 2014 17:31 #19387 by kreidler
linux-user wrote: While trying to make a german translation of the DeviationManual I've been looking around what is already there :huh: .
Need help B) ?
29 Jan 2014 21:54 - 29 Jan 2014 21:55 #19394 by linux-user
Hi Kreidler,
What I've done so far:
As a starting point I've split the Deviation10UserManual into individual files for each chapter. So different people could contribute their work on a single chapter.
Just to get an idea how much work this would be, I began to translate the first few pages. At this stage there are still so many typos that I don't dare to share this.
I would leave the english pictures and translate only the text, putting the items from the menu in brackets i.e. QR (AIL).. HR (ELE) .. Kanal (Channel).
Next I would make a fork of PB's repository <bitbucket.org/PhracturedBlue/deviation-manual-bh> and see if we could find any volunteers.
Last edit: 29 Jan 2014 21:55 by linux-user.
29 Jan 2014 23:35 #19400 by PhracturedBlue
please don't use that repo. That is an old version of the document.
The latest docs are here:
10 Feb 2014 18:54 #20088 by kreidler
I just made a short list with the changes and additions already done in the firmware after release of 4.0.1 which should be observed for the next manual release:
Devo 10/7e only:
- USB page removed from main menu
- channel reorder (needs some new pictures)
- New mixer layout (needs some new pictures also) I filed a ticket because the channels descriptions are partly not fitting into the boxes
- small numbers on Channel monitor (Channel output -> channel numbers and values, Stick input -> values), Telemetry monitor (1,2,3,4), Telemetry config (1,2,...6), Trims steps./ Standard GUI: DR&Expo, throttle curves, pitch curves
- What about the x9d?
All manuals:
- custom switches in hardware.ini SWA SWB -> hardware.ini to USB system, additions to emulator keyboard, additional description (extra chapter?)
- Trim Page 'Edit' header (needs a new picture) filed a ticket because on Devo10 atm only
Please feel free to add things I have not seen yet.
16 Mar 2014 15:55 #21589 by Rkozak99
Replied by Rkozak99 on topic Checking pages 17-21
Is Thera manual for the Devo 10?
16 Mar 2014 16:15 #21590 by linux-user
Replied by linux-user on topic Checking pages 17-21
Rkozak99 wrote: Is Thera manual for the Devo 10?
What do you mean?
Manual for Devo10: deviationtx.com/user-manual/user-manual-7e-10
... and here in german :evil:
bitbucket.org/linux-user/deviation-manua...nual_de-beta3.05.pdf
Time to create page: 0.127 seconds
