7e layout editor issue
28 Dec 2013 09:10 - 28 Dec 2013 09:47 #17261 by HappyHarry
7e layout editor issue was created by HappyHarry
guys i can't get changes made in the layout editor to stick in my 7e, i can add the battery voltage and tx power to the screen (as these are no longer showing on the 7e as default) and position them where i want, and they show up no problem, but once i change model and come back, or turn the tx on and off the changes dissapear. this is with the latest firmware, built last night, with the three position switch patch applied.
also what do timer 255 and 256 represent? perhaps total tx on time and something else?
and it seems i can no longer add icons to represent throttle hold and fmode positions?
Last edit: 28 Dec 2013 09:47 by HappyHarry.
28 Dec 2013 11:59 - 28 Dec 2013 11:59 #17275 by kreidler
Replied by kreidler on topic 7e and 10 layout editor issue
created: https://bitbucket.org/PhracturedBlue/deviation/issue/455/new-battery-and-tx-power-not-saved-to
Until no change to these items will be done all is ok. New settings are not saved in the ini file.
Timer 255 and 256 are accessible trough main page config timer box only. Both settings are located before timer 1. I do not what they are for also.
Last edit: 28 Dec 2013 11:59 by kreidler.
28 Dec 2013 13:25 #17279 by RandMental
Replied by RandMental on topic 7e layout editor issue
We need to add them in their original positions in the templates and default.ini
I'll add this to the ticket
28 Dec 2013 13:31 #17280 by kreidler
Replied by kreidler on topic 7e layout editor issue
HappyHarry wrote: and it seems i can no longer add icons to represent throttle hold and fmode positions?
Cannot confirm with emu tests. Could you be more detailed please.
28 Dec 2013 15:44 #17298 by HappyHarry
Replied by HappyHarry on topic 7e layout editor issue
i'm sure i remember being able to add items on the screen to show the status of the throttle hold switch and the flight mode switch, but these are no longer options on the screen editor, there is an item called a toggle, but when i choose to add one and set it for hold or fmode nothing is shown on the actual home screen, though it is shown on the editor screen
  • rbe2012
  • rbe2012's Avatar
28 Dec 2013 15:47 #17300 by rbe2012
Replied by rbe2012 on topic 7e layout editor issue
HappyHarry,
did you configure the toggle? You must select an icon, otherwise you won't see anything.
28 Dec 2013 15:59 #17303 by HappyHarry
soory my mistake, i never realised you had to select the icon seperately, ignore my above post, and all is working now with pb's latest commit :)
thanks for the fast work again guys 8)
28 Dec 2013 16:42 #17311 by Daryoon
Replied by Daryoon on topic 7e layout editor issue
Looked at the trouble ticket and already saw that PB replied and fixed it.
31 Dec 2013 03:42 #17542 by yidc
Replied by yidc on topic 7e layout editor issue
happyharry,
I'm also a devo7e user. Do you mean there's a toggle option in screen editor? Or how do you add items on the screen to show the status of the throttle hold switch and the flight mode switch??
I cannot locate any option for this at all :pinch:
31 Dec 2013 04:31 #17544 by PhracturedBlue
Replied by PhracturedBlue on topic 7e layout editor issue
The devo7e does not support modifying the layoutof the main screen on the transmitter. It can be done in the emulator (using the devo10 emulator) or by hand in a text editor.
However, today I checked in an updated default for the devo7e and devo10 that adds 5 toggles to the main page. They default to disabled on the Devo7e, but you can go to the main page config and enable them. If you can't build from source, you'll need to wait for tomorrow's nightly to get the updates though.
31 Dec 2013 10:33 #17557 by Adriaan
Replied by Adriaan on topic 7e layout editor issue
I have a similar problem with my Devo 10. TX Power is no longer viewed, no matter what I do on the view-editor. Hope the next nightly will help :-)
31 Dec 2013 12:30 #17562 by sbstnp
Replied by sbstnp on topic 7e layout editor issue
Adriaan wrote: I have a similar problem with my Devo 10. TX Power is no longer viewed, no matter what I do on the view-editor. Hope the next nightly will help :-)
Works for me. Make sure you update the filesystem and check with a new model. You may need to manually add tx power and battery voltage for older models.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
31 Dec 2013 13:48 - 31 Dec 2013 13:51 #17568 by HappyHarry
guys if you can build the firmware yourself, and if you disable telemetry there is enough room for the layout editor, and it works fine on the transmitter :)
Last edit: 31 Dec 2013 13:51 by HappyHarry.
31 Dec 2013 15:46 #17573 by Adriaan
How can I update my filesystem on my Devo10? Just format and paste the data backupped before?
I can add tx power an battery voltage with the view editor, but i canot chose something. It give me the choice "delete" or "none". :-(
31 Dec 2013 16:07 #17575 by PhracturedBlue
Adriaan wrote: I can add tx power an battery voltage with the view editor, but i canot chose something. It give me the choice "delete" or "none". :-(
What would you expect to select? These are either there or not, they have no selection. Just add them and long-press 'ENT' then go and place them.
31 Dec 2013 16:27 #17577 by Adriaan
Don´t know what to expect, but even after long-pressing "ENT" an placing them, there are no values shown. Not even a "0.00"
31 Dec 2013 16:33 #17578 by PhracturedBlue
please copy your model.ini file from the transmitter and attach it here.
31 Dec 2013 16:52 - 31 Dec 2013 16:53 #17581 by Adriaan
My Inis,
Model 13 was new created today with battery and TX Power
Last edit: 31 Dec 2013 16:53 by Adriaan.
31 Dec 2013 16:56 #17582 by PhracturedBlue
Your model works fine for me.
What version of deviation are you using?
Main Menu->About Deviation
31 Dec 2013 17:06 #17583 by Adriaan
Its the nightly from today, when I open "About Deviation" there is ne version showed(see attachment)
Time to create page: 0.190 seconds
