devo 7e deviation 4.0.0 - 2 switch patch problem
- HappyHarry
02 Jan 2014 22:08 - 02 Jan 2014 22:10 #17784
by HappyHarry
Replied by HappyHarry on topic devo 7e deviation 4.0.0 - 2 switch patch problem
2 3way switches is not possible with the current deviation software.
the only working 2 x 3way switch mod that works was done by gale/galee, you must know this as those are his pics you have used above, and it will only work with his modified code which was based on deviation but has been changed well beyond being able to merge his changes back in, you can find his firmware on a chinese moddeling forum, but the gui is only available in the chinese language.
so with deviation as it currently stands you have to choose either 1 x 3way switch, or 2 x 2way switches.
Last edit: 02 Jan 2014 22:10 by HappyHarry.
- dianjing
03 Jan 2014 00:16 #17793
by dianjing
Replied by dianjing on topic devo 7e deviation 4.0.0 - 2 switch patch problem
i had used gale/galee firmware.
but his software is not supply Protocol v202
so i can not use 7e to Control my plane
- dianjing
03 Jan 2014 00:38 #17795
by dianjing
now i used 3 point switch.
use your “4.0 for 7e with 2 2way patch and extra toggle icon”
when i set the 3 point switch to the end position.the THR trim will go up.
can you help me to solve this problem. thank you
- dianjing
03 Jan 2014 00:40 #17796
by dianjing
Thank you HappyHarry
- HappyHarry
03 Jan 2014 01:22 - 03 Jan 2014 01:43 #17798
by HappyHarry
you can't use any of my patched builds of deviation with your current switch setup. your switch wiring setup is for gale's firmware only. to use deviation you will need to rewire your switches in the correct way as described in this thread >>
www.deviationtx.com/forum/how-to/1436-ad...tches-to-the-devo-7e
Last edit: 03 Jan 2014 01:43 by HappyHarry. Reason: added link
- dianjing
03 Jan 2014 07:00 #17820
by dianjing
thank you!!!
- robca
03 Jan 2014 16:06 #17846
by robca
Replied by robca on topic devo 7e deviation 4.0.0 - 2 switch patch problem
rbe2012 has all the needed info and said that, as soon as he has time and no higher priority, he might look into implementing the same logic Galee used to enable two 3-way switches in the Devo 7e.
Until then, there's nothing to enable the switches wired that way, unfortunately
And even rbe2012 never actually promised anything, but I hope he'll have time to look into this
- blackmoon
03 Jan 2014 16:59 - 03 Jan 2014 17:00 #17858
by blackmoon
Harry, I was under the impression that the 3-way patch would work with the 2 switches wired like galee pictures, but only one would be functional.
I'm lucky I read this before going in, because I was going to do the 2 switches modification.
So for now and if I understand it correctly, I can put the 2 switches in place but wire only one per the thread you linked.
I'm right ?
Thanks.
Replied by blackmoon on topic devo 7e deviation 4.0.0 - 2 switch patch problem
HappyHarry wrote: you can't use any of my patched builds of deviation with your current switch setup. your switch wiring setup is for gale's firmware only. to use deviation you will need to rewire your switches in the correct way as described in this thread >>
I'm right ?
Thanks.
Last edit: 03 Jan 2014 17:00 by blackmoon.
- HappyHarry
03 Jan 2014 17:36 - 03 Jan 2014 17:47 #17866
by HappyHarry
you can have both 3way switches in place but you are only able to use them as 2 x 2way switches, or you can only wire up one of them (this is what i have done)
if you are fitting 2 3way switches and following gales pictures you wont be able to put either of the switches into position 3 as you will activate the trims that the wire from the switch is connected to (as dianjing found out). if you are doing it this way the easiest option to avoid problems is to not connect the yellow and red wires to the switches, just put some heat shrink over the end of the wires to insulate them until such time as some kind sole like rbe2012 or someone else looks into working in/adding the relevant code to deviation and then you can hook them to the switches. doing that you can use the 2 2way build without issue.
otherwise only wire up one of the three way switches like shown in this post here >> www.deviationtx.com/forum/how-to/1436-ad...vo-7e?start=60#17760 and use the 3way build
Last edit: 03 Jan 2014 17:47 by HappyHarry.
03 Jan 2014 17:42 #17869
Replied by rbe2012 on topic devo 7e deviation 4.0.0 - 2 switch patch problem
Actually I am stuck because I get results I can not interpret (pulling each line down works, the reverse not although it should - both on Devo8 and Devo7e).
It might need some more time. Please be patient, I will have a solution sooner or later...
- HappyHarry
03 Jan 2014 17:56 #17871
by HappyHarry
i'm (and i'm sure everyone else is) just glad to hear your working on it rbe, 'when' isn't really an issue, just to know it's in the works is good enough imo
- blackmoon
03 Jan 2014 19:59 #17882
by blackmoon
Thanks for the explanation Harry
And thanks to your Rbe for taking the time to look at this, we understand that this isn't a priority and be glad if it's implemented one day.
For the time being one 3-way isn't bad at all
- dianjing
04 Jan 2014 08:36 - 04 Jan 2014 08:36 #17911
by dianjing
i am using this 2*2sw for my devo7e.
it's better than galle as this fireware can mix every chancle to others.
thank you a lot.
waiting your best fireware for 2*3sw .
thank you a lot.
Last edit: 04 Jan 2014 08:36 by dianjing.
Time to create page: 0.406 seconds
- devo 7e deviation 4.0.0 - 2 switch patch problem
