Feature proposal: Add option "sticky" to safety sw
05 Jan 2014 14:23 #17983 by linux-user
Hi to all, and thanks for the amazing firmware.
@PB: if you ever decide to accept donations let me know.
I know, it's possible to implement a "sticky throttlehold" with virtchannel like this:
[channel3]
safetysw=Virt2
safetyval=-100
[virtchan2]
template=complex
[mixer]
src=Virt2
dest=Virt2
usetrim=0
curvetype=min/max
points=0
[mixer]
src=Ch3
dest=Virt2
offset=-1
usetrim=0
muxtype=add
[mixer]
src=AIL
dest=Virt2
switch=HOLD1
usetrim=0
curvetype=fixed
Now I am thinking if it would be possible to implement that feature in deviation itself,
which would make it easier for the user to config.
The logic would be simple:
after safetysw has been flipped and switched back to normal.
- keep the channeloutput at safetyval until the result of all applied mixers = safetyval
There could be a new option like this:
[channel3]
safetysw=RUD DR1
safetyval=-100
safetysticky=yes
What do you think?
05 Jan 2014 14:34 #17985 by FDR
I wouldn't like it to work that way.
05 Jan 2014 14:42 #17986 by RandMental
I agree with FDR, I have Sticky TH on some smaller models, but for larger 600+ Helis en especially Nitro driven helis and planes you have a few engine cut options, ie. Cut to idle and Kill the engine.
I believe the current flexibility allows one to implement all these variants with relative ease.
05 Jan 2014 15:18 #17988 by linux-user
Ok, there are situations where you don't want "sticky TH"
That`s why I proposed it as an option, where you can have either:
[channel3]
safetysw=RUD DR1
safetyval=-100
safetysticky=yes
==== or as it is now =====
[channel3]
safetysw=RUD DR1
safetyval=-100
So it's still the user who decides which behavior he wants.
The only downside I can see is the risc of introducing bugs,
besides the development effort that might not be worth it.
05 Jan 2014 16:12 #17991 by PhracturedBlue
Replied by PhracturedBlue on topic Feature proposal: Add option "sticky" to safety sw
currently Deviation does not keep track of historical state, but you are right that it would be easy to implement in Deviation. As was brought up in another thread, the main problem with using a safety switch is that you cannot take the final output as an input to another mixer.
I don't have much opinion one way or another.
Time to create page: 0.085 seconds
