Cannot compile 2270+ build in Windows.
- WheresWaldo
14 May 2014 18:26 - 14 May 2014 18:28 #23231
by WheresWaldo
Cannot compile 2270+ build in Windows. was created by WheresWaldo
I just opened a bug report in PB's BitBucket repository. When trying to compile the latest changes in deviation, even after a "make distclean" You get the following two errors and the process stops dead:
This happens if you just do a make, or make release or make a specific target. Anyone else seeing this? Is there any way to display messages for debugging this? I am assuming it is a change to the makefile but I can't see that it has been changed in a long time (or at least that section hasn't).
+ Building 'devo8.elf'
ROM: 0x08004000 - 0x0802c840 = 162.06kB
RAM: 0x20000000 - 0x20004e68 = 19.60kB
+ Copying template files for devo8
xargs: xgettext: No such file or directory
+ Checking string list length for devo8
xargs: xgettext: No such file or directoryThis happens if you just do a make, or make release or make a specific target. Anyone else seeing this? Is there any way to display messages for debugging this? I am assuming it is a change to the makefile but I can't see that it has been changed in a long time (or at least that section hasn't).
Last edit: 14 May 2014 18:28 by WheresWaldo.
14 May 2014 19:19 #23232
Replied by FDR on topic Cannot compile 2270+ build in Windows.
I can't build either, but I've got different error:
$ make
+ Compiling 'target/devo8/backlight.c'
arm-none-eabi-gcc.exe: error: nano.specs: No such file or directory
make: *** [objs/devo8/backlight.o] Error 1- PhracturedBlue
14 May 2014 20:03 #23234
Replied by PhracturedBlue on topic Cannot compile 2270+ build in Windows.
FDR's problem seems to be that he isn't using the latest GCC. Compiling trunk requires grabbing the latest gcc from:
launchpad.net/gcc-arm-embedded
WheresWaldo's issues stem from xgettext not being in your path. I believe it should be part of a standard mingw installation. I find it in: C:\MinGW\bin\xgettext.exe
- WheresWaldo
15 May 2014 00:01 #23243
by WheresWaldo
Replied by WheresWaldo on topic Cannot compile 2270+ build in Windows.
Yep, my MinGW/Bin folder was corrupt and missing a lot of files, so I restored a backup and I am up and running.
27 May 2014 04:34 #23657
Solved: my path pointed to the old one...
- hank0817
20 Mar 2015 05:28 #29918
by hank0817
I had same error message,how to fix it?
Replied by hank0817 on topic Cannot compile 2270+ build in Windows.
FDR wrote: Solved: my path pointed to the old one...
20 Mar 2015 13:38 #29929
Hank, which issue do you have? There are multiple issues listed in this thread. Is the problem not finidng gcc? Have you properly setup the build environment?
Time to create page: 0.105 seconds
- Cannot compile 2270+ build in Windows.
