Cannot compile 2270+ build in Windows.
14 May 2014 18:26 - 14 May 2014 18:28 #23231 by WheresWaldo
Cannot compile 2270+ build in Windows. was created by WheresWaldo
I just opened a bug report in PB's BitBucket repository. When trying to compile the latest changes in deviation, even after a "make distclean" You get the following two errors and the process stops dead:
+ Building 'devo8.elf'
ROM: 0x08004000 - 0x0802c840 = 162.06kB
RAM: 0x20000000 - 0x20004e68 =  19.60kB
 + Copying template files for devo8
xargs: xgettext: No such file or directory
 + Checking string list length for devo8
This happens if you just do a make, or make release or make a specific target. Anyone else seeing this? Is there any way to display messages for debugging this? I am assuming it is a change to the makefile but I can't see that it has been changed in a long time (or at least that section hasn't).
Last edit: 14 May 2014 18:28 by WheresWaldo.
14 May 2014 19:19 #23232 by FDR
Replied by FDR on topic Cannot compile 2270+ build in Windows.
I can't build either, but I've got different error:
$ make
 + Compiling 'target/devo8/backlight.c'
arm-none-eabi-gcc.exe: error: nano.specs: No such file or directory
make: *** [objs/devo8/backlight.o] Error 1
14 May 2014 20:03 #23234 by PhracturedBlue
Replied by PhracturedBlue on topic Cannot compile 2270+ build in Windows.
FDR's problem seems to be that he isn't using the latest GCC. Compiling trunk requires grabbing the latest gcc from:
launchpad.net/gcc-arm-embedded
WheresWaldo's issues stem from xgettext not being in your path. I believe it should be part of a standard mingw installation. I find it in: C:\MinGW\bin\xgettext.exe
15 May 2014 00:01 #23243 by WheresWaldo
Replied by WheresWaldo on topic Cannot compile 2270+ build in Windows.
Yep, my MinGW/Bin folder was corrupt and missing a lot of files, so I restored a backup and I am up and running.
27 May 2014 04:34 #23657 by FDR
Solved: my path pointed to the old one...
20 Mar 2015 05:28 #29918 by hank0817
Replied by hank0817 on topic Cannot compile 2270+ build in Windows.
FDR wrote: Solved: my path pointed to the old one...
I had same error message,how to fix it?
20 Mar 2015 13:38 #29929 by PhracturedBlue
Hank, which issue do you have? There are multiple issues listed in this thread. Is the problem not finidng gcc? Have you properly setup the build environment?
Time to create page: 0.028 seconds
