Actual throttle/pitch curve on GUI
24 May 2014 08:15 #23563 by cropduster
Actual throttle/pitch curve on GUI was created by cropduster
Hi guys,
not sure if this has been discussed before, but it would be cool to actually see the selected throttle and pitch curve on the first screen, not just the channel/mixer screen. So if you pull the switch, then you can check if you have selected the correct flight mode.
You can of course always go into the mixer and check before you start, but sometimes, if you switch models, it is easier to check if you have it on the screen.
- Michael
Time to create page: 0.027 seconds
