A7105 wiring of GIO pins
01 Jul 2014 12:34 #24323 by Fernandez
A7105 wiring of GIO pins was created by Fernandez
Devo 7e + Latest Nightly + Flysky protocol
Can I wire the A7105 module?
RxEn - GIO2
TxEn - GIO1
Or should I use old wiring;
RxEn - Gnd
TxEn - 3v3
01 Jul 2014 13:13 #24325 by PhracturedBlue
Replied by PhracturedBlue on topic A7105 wiring of GIO pins
in the nightly builds, use the new wiring
01 Jul 2014 15:03 #24332 by Fernandez
Replied by Fernandez on topic A7105 wiring of GIO pins
Ok thanks I'll leave that way!
I was wondering if it was working, as humming is much less, so this mean much less power consumption from the module, more efficient.
Not measured range or Ma yet.
Currently seem that CC2500, draw most power.
01 Jul 2014 17:21 #24335 by D_an_W
Replied by D_an_W on topic A7105 wiring of GIO pins
Will the nightly builds not work with the "old" method above (I just finished soldering my A7105!)?
01 Jul 2014 17:42 #24336 by victzh
Replied by victzh on topic A7105 wiring of GIO pins
I suppose they will, if in slightly suboptimal manner. Some protocols with feedback would benefit from turning PA off / LNA on when receiving, which is implemented by nightly builds and new wiring.
I have A7105 soldered in an old manner and it works OK.
01 Jul 2014 17:50 #24337 by D_an_W
Thanks, it's not installed yet so I could change if it's best...
06 Jul 2014 00:18 - 06 Jul 2014 00:18 #24404 by TimChiaretto
Replied by TimChiaretto on topic A7105 wiring of GIO pins
I attached two files that I think show the way an XL7105 module is suppose to be wired if using the nightly downloads or any Deviation 4.0.1 or newer. What I'm looking for is verification that it right. And I hope that whoever created these files won't be upset by my modifying them.
Tim
Last edit: 06 Jul 2014 00:18 by TimChiaretto. Reason: Mispellings
06 Jul 2014 05:58 #24410 by D_an_W
I think for 4.0.1 you would use the old method, it's anything newer than that you would use the new method for (IE nightly builds).
The diagram is how I understand it needs to be done, I just have another issue preventing me using the nightly build so my module is yet to be installed.
06 Jul 2014 13:42 #24417 by PhracturedBlue
Tim, your image is correct.
These are the same instructions I provide in the current documentation here:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList
Dan is also correct in that this is only for the nightly builds. 4.0.1 must use the old wiring where TX_EN and RX_EN are tied off.
26 Jul 2014 03:26 - 26 Jul 2014 03:55 #24807 by wintermoot
Replied by wintermoot on topic A7105 wiring of GIO pins
As a regular dumb end user who has prep'd his A7105 with the old wiring for his devo 10, help me to acquire more context about this change. The intended application for mt A7105 is just common sport flying hubsan protocol:
-I don't know when to expect a new deviation non-nightly release. When would this change make it to the other channel for a major release?
-What differences would I observe on 4.0.1 with old wiring vs nightly with new wiring. The only reference I can find to this is related to noise/hum, but what does that mean to the end user?
I.E. If I complete the mod the old way on 4.0.1, would it be worth redoing it later. I don't mind fetching another module to try the other, but I want to understand the differences first.
Last edit: 26 Jul 2014 03:55 by wintermoot.
26 Jul 2014 14:20 #24809 by PhracturedBlue
The new wiring should have significantly lower power consumption. I have no idea when the next Deviation release will be, but 4.0.1 is very stable. With the nightlies you get no such guarantee.
21 Mar 2015 18:28 #30003 by wian
Replied by wian on topic A7105 wiring of GIO pins
Are the current nightlies working? I just changed the wiring of the 7105 module to the GIO pins and upgraded to the latest nightly (16 March), but I can't get my hubsan h107c to bind. It worked fine with the previous wiring and deviation 4.0.1
21 Mar 2015 19:47 #30008 by TomPeer
Replied by TomPeer on topic A7105 wiring of GIO pins
did you edit the hardware.ini file?
21 Mar 2015 23:04 #30018 by Durete
Replied by Durete on topic A7105 wiring of GIO pins
wian wrote: Are the current nightlies working? I just changed the wiring of the 7105 module to the GIO pins and upgraded to the latest nightly (16 March), but I can't get my hubsan h107c to bind. It worked fine with the previous wiring and deviation 4.0.1
I am using the latest nightly with my A7105 and GIO wiring without any problem.
I remember one user about 2 months ago, that never could use GIO pins. Probably faulty A7105 module. The module from these user worked without problems with the old style wiring (as your module).
Check this thread:
deviationtx.com/forum/6-general-discussi...7105-and-new-wriring
22 Mar 2015 09:52 #30033 by wian
Thank you very much for the suggestions! The good news is that it is working now, the bad news is, I don't know what fixed it.
I formatted my devo 7e, reflashed the 16 March nightly DFU, copied over all folders from the nightly, copied the hubsan models.ini and made only the following changes to hardware.ini:
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
But before testing, also I also resoldered VCC (wire was skewed, but seemed fine otherwise) and scratched between the GIO1 and GIO2 because there were some tiny specs of solder that might have been causing trouble.
Now it is working fine.
What I did before when it was not working is that I copied back known working files from from deviation 4.0.1 , e.g. tx.ini and hardware.ini and copied and pasted all settings from tx.ini to hardware.ini (including the settings above). I may have also copied known good hubsan4.mod to the protocol folder. I suspect copying these deviation 4.0.1 files to the devo 7e with nightly installed caused the problem, rather than the scratching or resoldering.
Anyway, thanks for the replies and I hope this is useful for someone running into similar problems.
11 Apr 2015 18:55 - 11 Apr 2015 19:21 #31048 by Waterbound
Replied by Waterbound on topic XL-A7105-D03 - Confused about wiring
Hi guys, I am running devo7e-v4.0.1-dd446f70 nightly and having issues getting the XL-a7105-d03 working.
I am confused as I see a few different wiring diagrams published, so I am unclear if I have wired correctly.
On this page, it indicates "*4.0.1 and earlier: Connect 8->GND and 9->3.3V. Leave 6 and 7 floating " (what does floating mean?)
Does this mean RXEN (8) gets connected to GND (3) and VCC (1) and TXEN (9) get connected together?
On the same page listed above it says "Connect 6->9 and 7->8 (*)"
So according to that do I connect 6-9 and 7-8?
Which is correct? Do I keep the loops between 6-9 and 7-8 as well as connect 8 to GND and 9 to 1?
Currently I have it wired like this and its not finding the module, edited hardware.ini and checked everything with dmm etc:
4.bp.blogspot.com/-xkOUPc1CsSA/VQBfn72G_...w/s1600/A7105-7E.jpg
Last edit: 11 Apr 2015 19:21 by Waterbound.
11 Apr 2015 21:42 #31059 by aMax
Replied by aMax on topic XL-A7105-D03 - Confused about wiring
11 Apr 2015 22:04 #31061 by Durete
I agree with aMax.
For nightly builds, much better the new style wiring (AKA 6-9, 7-8 bridges).
Low power consumption when not in use the A7105 module, and don't loose Telemetry under supported protocols (Hubsan protocol for ex.)
12 Apr 2015 13:36 #31101 by Waterbound
Replied by Waterbound on topic A7105 wiring of GIO pins
okay so I'm close, I also see SCK wired to ground, is that correct?
as far as wiring to the TX board (adding the loops back and grounding SCK, the Rx side is the same as this ?
thanks so much for your help guys! I have the NRF module working great, just want to get this a7105 working now :)
12 Apr 2015 14:32 - 12 Apr 2015 14:33 #31104 by Durete
No, SCK don't need to be wired to ground.
Your schematic at your first post is OK. You only need to change the bridges for RXEN and TXEN.
TXEN to GIO1(6 - 9) and RXEN to GIO2 (7 - 8 ), and be sure you configure your module at Hardware.ini to point TMS signal (a13)
Last edit: 12 Apr 2015 14:33 by Durete.
Time to create page: 0.126 seconds
