Telemetry RPM counter
- Gyori
30 Jul 2014 11:50 - 03 Sep 2014 12:10 #24904
by Gyori
Telemetry RPM counter was created by Gyori
Hello Everybody,
I just found that the RPM input of the Walkera telemetry module may has an 8bit counter that shows overflow over 255 edges. It means the highest RPM value 120x255=30600. Is this problem caused by the telemetry module (so, the module has an 8bit counter), or is it cased by the Tx with the Devieation FW 4.0.1 on it (so, the bottleneck is the Tx)?
Thanks for the help. Regards,
Istvan
Istvan
Last edit: 03 Sep 2014 12:10 by Gyori.
- Gyori
03 Sep 2014 12:14 #25479
by Gyori
Replied by Gyori on topic Telemetry RPM counter
Hello Everybody,
I also found that with my Walkera RPM sensor, it shows about 10% lower value than it is.
So instead of 3000 RPM the sensor measures 2750 RPM. I think I'm going to develop an other sensor and calibrate with my lab equipments.
Best regards,
Istvan
Best regards,
Istvan
- Thomas.Heiss
13 Dec 2014 15:28 #26929
by Thomas.Heiss
Replied by Thomas.Heiss on topic Telemetry RPM counter
telemetry.h has u16 variable, which means max 65635.
devo_cyrf6936.c:
Telemetry.p.devo.rpm[0] = packet[7] * 120; //In RPM
Telemetry.p.devo.rpm[1] = packet[9] * 120; //In RPM
To me it seems there is no 0xFF/u8 255 limit.
I changed head/default for DSM telemetry from u8 variables to u16 and now the flightlog fields correctly display up to 9999 instead of 255.
So I guess as you the 255 packet limit is already set from the devo telemetry hardware?
Greetings
Thomas
devo_cyrf6936.c:
Greetings
Thomas
- Gyori
14 Dec 2014 16:10 #26972
by Gyori
Thanks for the answer.
This is what I was afraid of.
The overfow caused int the telemerty module :-/
For the head speed it is ok (with the awesome 120RPM resolution)
But the motor RPM owerflows at 30600 RPM.
Not a big deal, I can do the math.
Thanks again.
Thanks again.
- Thomas.Heiss
17 Jun 2015 10:51 #34214
by Thomas.Heiss
Can we add the pinion and main gear ratio to a configure DeviationTX screen so the real head rpm is displayed in telemetry view as suggested in other threads?
Time to create page: 0.091 seconds
- Telemetry RPM counter
