I currently have no plans to support the Devo7.
- octagon
01 Sep 2014 00:12 #25443
by octagon
I currently have no plans to support the Devo7. was created by octagon
Yes, the "Devo7" is generally a red-headed step-child, but it works, despite its minimalistic interface.
Its MCU the STM32F100C8T6B which lacks built-in USB-support like the MCU in the DEVO10 and 8, but has USB support thru that other gizmo, and the RF module is the same as its better siblings.
With a web-app, like rc.fdr.hu/model.php a fancy transmitter GUI with touchy screen, is a moot point. Visualization on a lap-top or tablet, even at the field, should be superior.
Would it be difficult and time-consuming to adapt the code to fit this version of the MCU?
- john
01 Sep 2014 04:01 #25444
by john
Replied by john on topic I currently have no plans to support the Devo7.
i also hope someday Devo 7 supported protocol , although display not optimal, but
it work very stable and cheap .
01 Sep 2014 04:13 - 01 Sep 2014 04:14 #25446
Replied by FDR on topic I currently have no plans to support the Devo7.
There is already a client app for that:
www.ts-soft.de/Devo7/
You can modify and directly upgrade the models with that...
EDIT: ...but it only supports the DEVO protocol of course...
Last edit: 01 Sep 2014 04:14 by FDR.
- Arakon
01 Sep 2014 04:26 - 01 Sep 2014 04:27 #25447
by Arakon
Replied by Arakon on topic I currently have no plans to support the Devo7.
The lack of USB support is not an issue. The main issue is the fact that it has half the flash space (64kb instead of 128) and less than half the RAM (8kb instead of 20kb). Even the 7E with 128kb flash has to cut out features already because that's not enough flash. Not to mention that the chipset in the 7 runs only at 24 mhz, while the 7E runs at 72mhz.
Last edit: 01 Sep 2014 04:27 by Arakon.
- octagon
01 Sep 2014 16:11 - 01 Sep 2014 16:36 #25449
by octagon
Replied by octagon on topic I currently have no plans to support the Devo7.
I imagined the better display was the reason the larger memory and faster processor. Multi-protocol may be bitchy with that simplistic display.
Has anyone made an RF-switch for the multi-RF module setup? Only one protocol at a time, thus a single RF-signal is used? A single antenna should be OK as the same frequency is used (2.4GHz) for all of them?
Has anyone tried to use a ceramic patch antenna (RHCP) for the 2.4GHz TX?
The metal handle looks well insulated and could possibly also be used as an antenna, with a tuning circuit of course, for whatever frequency used.
Last edit: 01 Sep 2014 16:36 by octagon.
- octagon
01 Sep 2014 16:12 - 01 Sep 2014 16:25 #25450
by octagon
Thanks FDR !
Last edit: 01 Sep 2014 16:25 by octagon.
Time to create page: 0.056 seconds
- I currently have no plans to support the Devo7.
