Request for nightly Devo12 with NRF module
07 Dec 2014 07:22 #26833 by magic_marty
Request for nightly Devo12 with NRF module was created by magic_marty
I have recently discovered the nightly builds does not support the NRF module when installed in the Devo12 and would like some of pros to please take a look at it and see what is wrong with it...The nightly works with the NRF module fine in my devo8 but when installing the same module in my 12 it says "missing module" I rolled back to Deviation 4.0.1 firmware on my 12 and the module works fine so i know there is no issues with the connections to the devo12 ..it has to be something in the nightly builds firmware...not sure if anybody else has experienced this and resolved it but would love to know how to fix this issue...
Thank you...
<Marty>
09 Dec 2014 00:31 - 09 Dec 2014 00:32 #26860 by mikemacwillie
Replied by mikemacwillie on topic Request for nightly Devo12 with NRF module
Give this a try. It's a build of hexfet's repo that I've been using for few weeks successfully.
Last edit: 09 Dec 2014 00:32 by mikemacwillie.
09 Dec 2014 05:00 #26862 by magic_marty
Replied by magic_marty on topic Request for nightly Devo12 with NRF module
Wow , thank you! I will give it a try asap and report back my results..
09 Dec 2014 06:25 #26863 by magic_marty
Still says same thing when i enable the NRF module in the hardware file... :(
10 Dec 2014 00:37 #26868 by mikemacwillie
Are you using a multimod, or just the module straight in to your tx? Could you post your hardware.ini file?
10 Dec 2014 00:51 - 10 Dec 2014 04:44 #26869 by magic_marty
No just have the nrf module installed. I will post the hardware file later when i get in from work. No multimode only the cyrf and the nrf module installed.
Thanks.
EDIT: added hardware file...
Last edit: 10 Dec 2014 04:44 by magic_marty.
11 Dec 2014 01:33 #26879 by mikemacwillie
The only issue I can see is 'has_pa-cyrf6936'is set to 0. It should be commented out. This really shouldn't mess with the NRF module, bit I have only used the build above with the multimod.
4.0.1 doesn't do any module checks on startup, so the lack of an error message with that version doesn't necessarily mean that the issue isn't still there.
11 Dec 2014 04:41 #26882 by magic_marty
I actually have it commented out at this time and still says missing module so yes it doesn't seem to bother the NRF module...all i know is it is really weird that the nightly works perfect on my 8 with the NRF and no matter what i try it will mot work on my 12..:( the module works with deviation 4.0.1 non-nightly build but my cx-10 flies weird compared to the nightly on my devo8 ...its a bit jerky on the controls where as on the 8 it is really smooth running the nightly build..
11 Dec 2014 06:04 #26884 by mikemacwillie
Any chance there is a power supply issue to the module in the 12S? Might be worth measuring it at the module while transmitting.
11 Dec 2014 07:17 #26885 by magic_marty
Already checked it...3.3v at the vcc on the module pad..seems if it were a power issue the module would not work with deviation 4.0.1 and not work with the nightly..it really has me confused cause everything is hooked up correctly and i have double and triple checked multiple times with a voltmeter..
11 Dec 2014 16:59 #26893 by aMax
Certainly mikemacwillie means the current and not the voltage.
11 Dec 2014 17:02 - 11 Dec 2014 17:07 #26894 by magic_marty
So perhaps the the amperage is not high enough...is there any other way to power the module?
EDIT: Still makes no sense if it was a power issue seems the module would not work on deviation 4.0.1 ...unless the nightly is some how not powering the out puts on the PCB correctly?
Last edit: 11 Dec 2014 17:07 by magic_marty.
11 Dec 2014 17:17 - 11 Dec 2014 17:19 #26895 by aMax
I don´t know.
All I remember is, some time ago, a user had an issue with the
3.3V regulator on his 7e. The power supply was restricted by this
max 300mA device and he upgraded to a stronger one.
If there are some difference between the versions of Deviation you can check by the consumption of the whole tx.
Last edit: 11 Dec 2014 17:19 by aMax.
11 Dec 2014 17:31 #26896 by magic_marty
not sure what you mean by "consumption of the whole tx." ?
11 Dec 2014 17:35 #26897 by aMax
magic_marty wrote: So perhaps the the amperage is not high enough...is there any other way to power the module?
Did you hear of someone else having this issue with his 12(S)?
Maybe they do not use the nighly or have no NFR installed....
Who knows.
Do you have a different modul at hand e.g. a A7105? Then you can test the
A13/14 with that one. All you lack with the nightly is that these lines going activ to low.
Use your saleae and look if this happens at least once or never.
11 Dec 2014 17:41 #26898 by magic_marty
i have not heard of anybody else having this happen on there 12...i do have a couple of A7105 modules coming from BG and should be here next week i believe i don't have any models to bind them to but plan on installing them for possible future use..Even with no models to bind to i should still be able to tell if they work or give the missing module error like the NRF is doing..
11 Dec 2014 17:43 - 11 Dec 2014 17:45 #26899 by aMax
"not sure what you mean by "consumption of the whole tx." ? "
In which other method will be able to check differences with already soldered modules?
Last edit: 11 Dec 2014 17:45 by aMax.
11 Dec 2014 17:48 #26900 by magic_marty
don't know of any other way to check them..wonder if i could power the module with a outside source like a separate battery perhaps to test and see if it is a power issue?
11 Dec 2014 17:53 #26901 by aMax
magic_marty wrote: i have not heard of anybody else having this happen on there 12...i do have a couple of A7105 modules coming from BG and should be here next week i believe i don't have any models to bind them to but plan on installing them for possible future use..Even with no models to bind to i should still be able to tell if they work or give the missing module error like the NRF is doing..
You will have some problems with that one as the wiring differs.
Start with the old wiring method, it works on both versions.
But if you are going later on with the nighly, it is advised to use the "new" wiring.
11 Dec 2014 17:56 #26902 by magic_marty
Oh, i didn't know there was a old and new method for the wiring..I assume i have used the new method but will look and see if i can find some info on the old way of wiring it up.
Time to create page: 0.090 seconds
