Request for nightly Devo12 with NRF module
- aMax
11 Dec 2014 17:59 #26903
by aMax
Replied by aMax on topic Request for nightly Devo12 with NRF module
I mean the A7105-D03 not the nRF24L01...
- magic_marty
11 Dec 2014 18:03 #26904
by magic_marty
Oh ok...the A7105 i will hook up the same way i hooked up the NRF when i get them only on the devo8 i will use the TCK pin..not much worries of it working in the 8 but i have my doubts it is going to work in the 12 because of the issues it is having with the NRF module..
Replied by magic_marty on topic Request for nightly Devo12 with NRF module
aMax wrote: I mean the A7105-D03 not the nRF24L01...
- mikemacwillie
12 Dec 2014 02:37 #26909
by mikemacwillie
Replied by mikemacwillie on topic Request for nightly Devo12 with NRF module
The most up to date information for module wiring can be found on the bitbucket wiki.
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleList
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
If you click Ok on the error message, and try to use it... Does it work like it did in 4.0.1? I'm wondering if there's an intermittent issue at play here. Maybe you could post a picture of your installation and we could put a second set of eyes on it?
If you were interested in building a multimodule, I have an extra PCB that I'd happily send you. I have a fully loaded multimodule working in my 12S with the previously attached firmware build.
- magic_marty
12 Dec 2014 04:43 #26910
by magic_marty
When the missing module pops up on powering up the 12 and i click on "ok" it just power cycles itself and tries to start up again and displays the same error again over and over...some pictures of the install can be found here in this thread...
www.deviationtx.com/forum/3-feedback-que...imitstart=0&start=20
- magic_marty
13 Dec 2014 09:58 #26924
by magic_marty
Nobody has any other ideas for me to try? This is really annoying that the module works in the 8 and not the 12..
13 Dec 2014 17:05 #26931
Replied by hexfet on topic Request for nightly Devo12 with NRF module
Do you have a scope or analyzer to look at the SPI signals? The cpu not receiving data from the nRF could explain your symptoms.
Though I'd only expect the resets if the startup model is configured with certain nRF protocols. Try setting current_model in tx.ini to point to a model set to devo protocol, if it's not already.
- aMax
13 Dec 2014 18:29 #26932
by aMax
The CSN (A13/A14) does not get activ low with his nightly.
If it does only once or never, that´s what he must test with the analyzer.
- magic_marty
13 Dec 2014 22:21 #26936
by magic_marty
sorry for the late reply i had to replace the mother board in my laptop cause i accidentally burnt out the usb ports the other day...i will see about hooking up the analyzer soon and see but i have no idea what i am looking for or how to set up the analyzer ...but will try
Time to create page: 0.044 seconds
- Request for nightly Devo12 with NRF module
