Devation for mobile devices
01 Apr 2015 08:57 - 01 Apr 2015 09:29 #30607 by linux-user
Replied by linux-user on topic Devation for mobile devices
PhracturedBlue wrote: It seems like at a minimum I need a test page to show current channel values, or else it will be difficult to figue out how to map the PPM channels to the protocol channels.
Hi PB,
I would like something like the Deviation "channel-Monitor" to show the actual protocol output.
With tapping on one of the channel-bars there should pop up some sort of selection menu for the corresponding input channels.
Here another example how Spirit-FBL App does similar task:
Last edit: 01 Apr 2015 09:29 by linux-user. Reason: added 2. screenshot
01 Apr 2015 13:54 #30613 by mwm
Replied by mwm on topic Devation for mobile devices
Only vaguely related, but if were're going to be getting support for a bluetooth module, how about support for bluetooth hid as an output protocol?
03 Apr 2015 19:54 #30763 by PhracturedBlue
Replied by PhracturedBlue on topic Devation for mobile devices
I've updated the software again.
It now has channel naming support (like Deviation) and will remap channels if the protocol is changed.
I also added channel-values to the channel map page. The channels values only update if you are connected, but that can be tested in the web-version too.
Note that you can drag the 'PPM' entries on the channel reordering page to reassign channel mapping
I think I'm about done with the software for now (except for any bugs). I am actively using it with the UniversalTx board, and it seems to meet the basic configuration needs.
I will eventually add a display and telemetry support, but that'll need to wait for another time.
If anyone is interested, here is the Android .apk. Without access to a UniversalTx, it is less functional than the web version (you can't actually connect to anything), but if you're curious on how it looks on a smaller screen, feel free to try it out:
www.dropbox.com/s/ul55qbjuc7bgo8m/DeviationMobile-0.5.apk?dl=0
03 Apr 2015 20:42 #30768 by SadSack
Replied by SadSack on topic Devation for mobile devices
Very nice indeed.
For me little darker would be nice...still all in good time I guess.
Very nice work.
04 Apr 2015 16:09 #30789 by linux-user
PhracturedBlue wrote: www.dropbox.com/s/ul55qbjuc7bgo8m/DeviationMobile-0.5.apk?dl=0
Hi, I did a short test with the .apk
PhracturedBlue wrote: Note that you can drag the 'PPM' entries on the channel reordering page to reassign channel mapping
I like the "drag and drop" idea, although without your note, I wouldn't have figured it out.
The channel mapping is only looking pretty in landscape mode.
I didn't expect that to work too :P
Question:
Would we need some adjustment to the PPM like in deviation? (Center PW etc.)
PhracturedBlue wrote: I think I'm about done with the software for now (except for any bugs).
- "Rename Model" doesn't work
- TX power doesn't save (stays at 150mW)
04 Apr 2015 16:35 #30791 by PhracturedBlue
I had already implemented the PPM PW settings, just not in the version on the web. I placed it with channel ordering (because when adjusting it you likely want to see the channel values), which is probably not very intuitive.
I am aware that the channel display doesn't look very good in portrait mode on mobile. I will likely go back to a 2-column display, and move the channel value under the channel name.
The other 2 issues you listed have been fixed (and the apk updated). Thanks for the feedback.
04 Apr 2015 17:43 #30794 by linux-user
PhracturedBlue wrote: I placed it with channel ordering (because when adjusting it you likely want to see the channel values), which is probably not very intuitive.
Oh, that's exactly the place I'd expected it.
Maybe better visible on top of the page
PhracturedBlue wrote: I will likely go back to a 2-column display, and move the channel value under the channel name.
Agreed. And maybe add the Channel-values (in %) as well.
Inspiring example = "Deviation channel monitor"
07 Apr 2015 01:09 #30857 by PhracturedBlue
I updated the channel monitor display
07 Apr 2015 07:30 #30867 by linux-user
Excellent.
Is there a reason you've chosen a "0% to 100%" scale?
Deviation uses everywhere "-100% to +100%"
07 Apr 2015 07:44 #30868 by Fernandez
Replied by Fernandez on topic Devation for mobile devices
mili seconds
07 Apr 2015 12:52 #30871 by PhracturedBlue
@linux-user: I've fixed it. Just a bug
@Fernandez: I'm not sure what values are in msec?
07 Apr 2015 14:58 #30875 by Fernandez
1500ms= neutral
1000ms= -100% min
2000ms= 100% max.
07 Apr 2015 19:06 #30885 by blackmoon
Replied by blackmoon on topic Devation for mobile devices
Just tried the web app, and what can I say except... that you never cease to amaze me, you are really porting this project to the next level, once again thank you for your hard work and commitment.
13 Nov 2015 09:57 #40003 by cyberbillp
Replied by cyberbillp on topic Devation for mobile devices
I wonder if you couldn't use the usb port vs Bluetooth?
What do they call those things, otp cables?
Time to create page: 0.181 seconds
