Help ! the "Bad/missing protocol modules!"
08 Jun 2015 23:59 - 09 Jun 2015 02:46 #33670 by supermk2
Hello everyone ?
I am looking the source code of Deviation 4.0.1(on this site: Deviation Releases > Deviation 4.0.1).
I installed a tortoisehg.
I got Rev2096(Description: Added tag v4.0.1 for changeset 9a642a12446d) from repository(bitbucket.org/PhracturedBlue/deviation).
And, I got devo7e.dfu file from this code. (I'm a devo7e user.)
I installed new devo7e.dfu file to my devo7e.
But, I got error message from my devo7e.
The error message is "Bad/missing protocol modules!".
So, I did that overwriting protocol folder on devo7e.
(this is describe on the "Deviation10UserManual".)
But, The error message does not disappear.
I don't know my problem.
I think that Rev2096 is different to Deviation 4.0.1(on this site: Deviation Releases > Deviation 4.0.1).
Actually, devo7e.dfu(build by me) vs. deviation-devo7e-v4.0.1.dfu(download from release in this homepage)
These files are not same on equivalent check tool (WinMerge).
Could you tell me about my problem ?
Thank you.
Last edit: 09 Jun 2015 02:46 by supermk2.
09 Jun 2015 00:23 #33671 by RedSleds
Replied by RedSleds on topic Help ! the "Bad/missing protocol modules!"
Did you install additional RF modules in your 7E?
09 Jun 2015 00:47 #33674 by supermk2
Replied by supermk2 on topic Help ! the "Bad/missing protocol modules!"
No, I din't install additional RF module in my 7E.
The error occurred in DEVO protocol.
In Error State,
If I replace deviation-devo7e-v4.0.1.dfu file(from Release site), the error is disappear.
So, I think that my source code is different to deviation-devo7e-v4.0.1.dfu file(from this site).
I need a source code about deviation-devo7e-v4.0.1.dfu file(from Release site).
thank you.
09 Jun 2015 03:00 #33681 by mwm
When you update the DFU file, you have to install the files in the objs/devo7e/protocol folder as well. Those go in the protocol directory on the Tx's USB drive. Even if you build from the sources for 4.0.1, the protocol modules aren't guaranteed to work with the ones in the distribution. You may be able to do that if you install the exact same toolchain and libraries as were used to build the distribution, but still no guarantees. I can't tell you what those were, so just build the modules and install the new ones.
Note that current development is taking place in the deviationTx/deviation bitbucket repository. You can check that out, then check out v4.0.1 to get the 4.0.1 sources. Depending on what you're doing, you may want to use the tip of the default branch instead.
Time to create page: 0.091 seconds
