Extra inputs for Devo Tx's
05 Sep 2015 00:01 #37452 by Deal57
Replied by Deal57 on topic Extra inputs for Devo Tx's
I finally completed the last modification to my external controls. The current configuration is 2 potentiometers, 1 6-position switch, 2 x 3-way switches, 1 2-way switch. The latest addition is a panel with six individual momentary switches and six LED indicators.
This panel, seen here in my prototype, was built using just SIX digital pins on the Arduino Pro Mini! The "Charlieplexing" approach took me some time to wrap my head around, but it is very functional and particularly useful since i'm already using diodes. This lets me use a short 6-conductor cable from the Arduino (or enclosure) to the switch panel, presumably allowing me to position it better on my GCS (if I ever get there!). The pots and switches run without regard to this new panel, and in Devo you can continue to mix as desired.
I've set the LEDs to come on based on the mode selected. For the momentary switches, I capture the switch pressed and set the mode value, which corresponds to a particular number of milliseconds in the PPM stream. Since the switch sets a mode, and the LEDs take action based on that mode at the same time the PPM stream is built, it seems like monitoring the PPM stream would be redundant. In any case, I've tried this with an APM flight controller and it works great.
All that being said, the functionality is terrific; the real problem now is how to package it and make it useful.
At this point I just want to find the "right" enclosure. I am thinking of a box with a USB jack, a 6-pin connector of some sort and possibly a battery or charging port. but I guess it depends on what I find. I guess it is time for that 3-D printer?
Happy flying!
05 Sep 2015 00:31 #37453 by mwm
Replied by mwm on topic Extra inputs for Devo Tx's
How about a nice picade? :)
www.adafruit.com/products/2707
05 Sep 2015 01:36 #37455 by Epyon
Replied by Epyon on topic Extra inputs for Devo Tx's
Nice work Deal57.
Still revamping my 7e. I swapped to a Taranis 6-way switch like you. Kind of a fidgety lil POS don't you think? I really dislike the jump to low position between most switchings. Gotta work some debounce into my code.
Currently at three potentiometers, 6-way "switch", three 3-ways, one 2-way, and two momentary buttons run through the Arduino. Then two 3-ways, two momentary buttons and the standard two 2-ways hooked to the 7e itself. Heh. :cheer:
File Attachment:
Also got a 128x32 OLED working.
The audio board plan is stalled, as mine arrived DOA. Definitely still on the agenda down the road.
Still waiting on an I2C voltage current sensor which I'll stuff, along with a real time clock module and possibly a 9DOF module into the unused battery bay of my FPV monitor. Good times, good times.
08 Sep 2015 11:31 - 08 Sep 2015 12:56 #37567 by davidwyl
Replied by davidwyl on topic Extra inputs for Devo Tx's
Deal57 wrote: I finally completed the last modification to my external controls. The current configuration is 2 potentiometers, 1 6-position switch, 2 x 3-way switches, 1 2-way switch. The latest addition is a panel with six individual momentary switches and six LED indicators.
Happy flying!
1. my plan is to add 2 pot & two 3ways switch, any modification needed to this code?
(i have no experience arduino programming)
2. will this code (version 2.5) work on arduino nano?
Last edit: 08 Sep 2015 12:56 by davidwyl.
08 Sep 2015 13:06 #37569 by Deal57
I presume that you mean that you'll be adding the switches and pots using the Arduino. The code that we're using will work, you just have to use the correct pins on the Arduino. Obviously there is more in the code than you need, but I don't think the extra non-functioning code will affect your controls. PLEASE test first. I left some commented code (lines start with "//") that turn on the serial port and print back the values reported by each switch/pot; just uncomment them and use the Serial Monitor function in the IDE tools.
The Arduino code is very simple to learn and with a bit of practice you'l be programming it yourself. The Arduino site has a wealth of examples and references, as well as some really great projects. I've programmed stuff for years, so for Arduino I started by doing a few exercises in the Learning menu and things made sense pretty quickly.
08 Sep 2015 14:23 #37570 by davidwyl
Deal57 wrote: I presume that you mean that you'll be adding the switches and pots using the Arduino. The code that we're using will work, you just have to use the correct pins on the Arduino. Obviously there is more in the code than you need, but I don't think the extra non-functioning code will affect your controls. PLEASE test first. I left some commented code (lines start with "//") that turn on the serial port and print back the values reported by each switch/pot; just uncomment them and use the Serial Monitor function in the IDE tools.
Will load v2.5 code into Arduino nano.
2pot connect to A1 & A2.
2x3ways connect to D6-D7 & D8-D9.
Correct?
Did u add capacitor to the vin & pot 5v?
09 Sep 2015 02:55 #37578 by Deal57
Correct?
Those are the correct connections. I did not use a capacitor as I am using a battery in an external box and I cannot track down specifics to help me understand the problem I am solving. It's probably a good idea.
09 Sep 2015 04:29 #37579 by Epyon
davidwyl wrote: Will load v2.5 code into Arduino nano.
Correct?
You can strip out a lot of Ian's original code, such as the dual rate stuff. Having inputs, especially analogs, active with no input can sometimes make everything go wonky.
For 2 pots and 2 3-ways, here's about all you'll need.
// Devo 7e PPM input
// For use with Arduino Nano V3.0
// Based on sketch by Ian Johnston
// Analog pin assignments
int AI_Pin_A1 = 2;    // potentiometer #1 pin
int AI_Pin_A2 = 3;    // potentiometer #2 pin
int AI_Raw_A1;        // Analog In raw var - 0->1023....
int AI_Raw_A2;
int A1_uS = 750;      // potentiometer #1 us
int A2_uS = 750;      // potentiometer #2 us
int sw1_uS = 750;     // 3-way switch #1 us
int sw2_uS = 750;     // 3-way switch #2 us
int Fixed_uS = 300;       // PPM frame fixed LOW phase
int pulseMin = 750;       // pulse minimum width minus start in uS
int pulseMax = 1700;      // pulse maximum width in uS
// Digital pin assignments
int outPinPPM = 10;     // PPM out
int inPinD2 = 2;        // 3-way switch #1 pin for position 1. Positions 1 and 3 combine for middle position.
int inPinD3 = 3;        // 3-way switch #1 pin for position 3
int inPinD4 = 4;        // 3-way switch #2 pin for position 1
int inPinD5 = 5;        // 3-way switch #2 pin for position 3
ISR(TIMER1_COMPA_vect) {
    ppmoutput(); // Jump to ppmoutput subroutine
void setup() {
  pinMode(outPinPPM, OUTPUT);   // sets the digital pin as output
  pinMode(inPinD2, INPUT);      // sets the digital pin as input
  digitalWrite(inPinD2, HIGH);  // turn on pull-up resistor
  pinMode(inPinD3, INPUT);
  digitalWrite(inPinD3, HIGH);
  pinMode(inPinD4, INPUT);
  digitalWrite(inPinD4, HIGH);
  pinMode(inPinD5, INPUT);
  digitalWrite(inPinD5, HIGH);
   // Setup timer
  TCCR1A = B00110001; // Compare register B used in mode '3'
  TCCR1B = B00010010; // WGM13 and CS11 set to 1
  TCCR1C = B00000000; // All set to 0
  TIMSK1 = B00000010; // Interrupt on compare B
  TIFR1  = B00000010; // Interrupt on compare B
  OCR1A = 22000; // 22mS PPM output refresh
  OCR1B = 1000;
void ppmoutput() { // PPM output sub routine
 // Channel 1 - Analog 1
  digitalWrite(outPinPPM, LOW);
  delayMicroseconds(Fixed_uS);    // Hold
  digitalWrite(outPinPPM, HIGH);
  delayMicroseconds(A1_uS);  // Hold for A1_uS microseconds
 // Channel 2 - Analog 2
  delayMicroseconds(A2_uS); // Hold for A2_uS microseconds
// Channel 3 - 3-way switch #1
  delayMicroseconds(sw1_uS);     // Hold for sw1_uS microseconds
// Channel 4 - 3-way switch #2
  delayMicroseconds(sw2_uS);     // Hold for sw2_uS microseconds
// Synchro pulse
  digitalWrite(outPinPPM, HIGH);  // Start Synchro pulse
void loop() { // Main loop
 // Read analog pins
   AI_Raw_A1 = analogRead(AI_Pin_A1);
   AI_Raw_A2 = analogRead(AI_Pin_A2);
 // Map analog inputs to PPM rates for each of the channels
   A1_uS = AI_Raw_A1 + pulseMin;
   A2_uS = AI_Raw_A2 + pulseMin;
 // Potentiometer limits
  if (A1_uS <= 750) A1_uS = 750;     // Min
  if (A1_uS >= 1625) A1_uS = 1625;   // Max
  if (A2_uS <= 750) A2_uS = 750;
  if (A2_uS >= 1625) A2_uS = 1625;
// 3-way switch #1
  if (digitalRead(inPinD2) == 0) {
           sw1_uS = 750;
  if ((digitalRead(inPinD2) == 1) && (digitalRead(inPinD3) == 1)) {
           sw1_uS = 1190;                 // Center us, may need to adjust this
  if (digitalRead(inPinD3) == 0) {
           sw1_uS = 1625;
// 3-way switch #2
  if (digitalRead(inPinD4) == 0) {
           sw2_uS = 750;
  if ((digitalRead(inPinD4) == 1) && (digitalRead(inPinD5) == 1)) {
           sw2_uS = 1190;                 // Center us, may need to adjust this
  if (digitalRead(inPinD5) == 0) {
           sw2_uS = 1625;
122 lines of code.
Compared to 194 in Ian's, and 545 in my current...............
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#include <TimerFreeTone.h>
#define TONE_PIN 13
int AI_Pin_A1 = 2;
int AI_Pin_A2 = 3;
int AI_Pin_A3 = 6;
int AI_Pin_A4 = 7;
int AI_Raw_A2;
int AI_Raw_A3;
int AI_Raw_A4;
int A1_uS = 750;      // potentiometer - right shoulder
int A2_uS = 750;      // potentiometer - right front
int A3_uS = 750;      // potentiometer - left front
int A4_uS = 750;      // 6-way switch
int sw1_uS = 750;     // 3-way switch #1 - right side
int sw2_uS = 750;     // 2-way switch - left side
int sw3_uS = 750;     // 3-way switch #2 - left side
int sw4_uS = 750;     // 2 right-side momentary buttons
int Model = 1;         // Model#
int BoosterOff = 1;   // For blink
int LEDpin0 = 0;        // Blue LED 1
int LEDpin1 = 1;        // Blue LED 2
int inPinD3 = 3;
int inPinD4 = 4;        // 2-way switch
int inPinD6 = 6;        // 3-way switch #2
int inPinD7 = 7;
int inPinD8 = 8;        // bottom right-side momentary button
int inPinD9 = 9;        // top right-side momentary button
int inPinD11 = 11;      // Booster high power
int inPinD12 = 12;      // Booster low power
int BoosterPin = 5;     // booster trigger
boolean pBeep1 = false;
boolean pBeep2 = false;
boolean pBeep3 = false;
boolean fBeep1 = false;
boolean fBeep2 = false;
boolean fBeep3 = false;
boolean fBeep4 = false;
boolean fBeep5 = false;
boolean fBeep6 = false;
boolean Beep1 = false;
boolean Beep2 = false;
boolean Beep3 = false;
boolean Beep4 = false;
boolean Beep5 = false;
boolean Beep6 = false;
boolean Beep7 = false;
boolean Beep8 = false;
boolean Beep9 = false;
boolean Beep10 = false;
boolean Beep11 = false;
String Battery = (" ");  // OLED text display variables
String Current = (" ");
String Alert = (" ");
String Booster = (" ");
String fMode1 = (" ");
String fMode2 = (" ");
String fMode3 = (" ");
String fMode4 = (" ");
String fMode5 = (" ");
String fMode6 = (" ");
const unsigned char PROGMEM Deviation [] = {
0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x18, 0x80, 0x00, 0x1C, 0x0C, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x1B, 0x00, 0x00, 0x1C, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x1C, 0x0B, 0x80, 0x00, 0x00, 0x80, 0x00,
0x00, 0x03, 0x80, 0x00, 0x01, 0x00, 0x0D, 0x00, 0x00, 0x1C, 0x05, 0x80, 0x00, 0x00, 0x80, 0x00,
0x00, 0x03, 0x80, 0x00, 0x02, 0x1E, 0x00, 0x00, 0xE0, 0x1F, 0xF0, 0x00, 0x00, 0x01, 0x80, 0x00,
0x00, 0x03, 0x80, 0x00, 0x06, 0x3F, 0x00, 0x01, 0xF8, 0x1F, 0x80, 0x00, 0x00, 0x01, 0x87, 0x00,
0x00, 0x03, 0x80, 0x7C, 0x0E, 0x63, 0x9F, 0xE3, 0x3C, 0xFC, 0x0F, 0xF0, 0x7C, 0x03, 0x8F, 0x80,
0x01, 0xFB, 0x00, 0xCE, 0x3C, 0xFD, 0x9F, 0x02, 0x1C, 0xD8, 0x0F, 0x80, 0xDE, 0x0F, 0x99, 0xC0,
0x03, 0xFF, 0x01, 0x87, 0x7C, 0xD5, 0xC6, 0x06, 0x1C, 0x18, 0x07, 0x01, 0xB7, 0x01, 0xB0, 0xE0,
0x07, 0x8F, 0x03, 0x03, 0xFC, 0xE5, 0xC6, 0x07, 0x9C, 0x18, 0x07, 0x03, 0x53, 0x81, 0xE0, 0x70,
0x0F, 0x07, 0x03, 0x63, 0x9C, 0xFD, 0xC6, 0x0F, 0xDC, 0x18, 0x07, 0x03, 0x79, 0x81, 0xC0, 0x70,
0x1E, 0x03, 0x07, 0xF1, 0x8E, 0x79, 0xC6, 0x0F, 0xDC, 0x18, 0x07, 0x06, 0x79, 0xC1, 0xC0, 0x78,
0x1E, 0x03, 0x07, 0xB1, 0x8E, 0x31, 0xC6, 0x0E, 0xDC, 0x18, 0x03, 0x0E, 0x78, 0xC1, 0xC0, 0x38,
0x3C, 0x03, 0x0F, 0xB3, 0x06, 0x01, 0xC6, 0x06, 0x9C, 0x18, 0x03, 0x0E, 0x70, 0xE1, 0x80, 0x38,
0x3C, 0x03, 0x0E, 0xE6, 0x07, 0x01, 0x86, 0x03, 0x1C, 0x30, 0x03, 0x0E, 0x00, 0xE1, 0x80, 0x38,
0x3C, 0x03, 0x0E, 0x7C, 0x07, 0x01, 0x06, 0x00, 0x18, 0x30, 0x03, 0x0E, 0x00, 0xE1, 0x80, 0x38,
0x3C, 0x03, 0x0E, 0x00, 0x03, 0x03, 0x06, 0x00, 0x18, 0x30, 0x03, 0x0E, 0x00, 0xE1, 0x80, 0x38,
0x3C, 0x3B, 0x0E, 0x00, 0x03, 0x02, 0x06, 0x00, 0x30, 0x30, 0x03, 0x0E, 0x00, 0xE1, 0x80, 0x38,
0x3C, 0xFF, 0x0E, 0x0E, 0x03, 0x86, 0x06, 0x07, 0xF0, 0x33, 0x83, 0x0E, 0x00, 0xC1, 0x80, 0x30,
0x3E, 0xF7, 0x0E, 0x1F, 0x01, 0x84, 0x06, 0x0F, 0x20, 0x36, 0xC3, 0x06, 0x00, 0xC1, 0x80, 0x30,
0x1E, 0x97, 0x07, 0x13, 0x01, 0x8C, 0x06, 0x1E, 0x20, 0x37, 0xC3, 0x06, 0x01, 0x81, 0x87, 0x20,
0x0F, 0xF7, 0x03, 0x1D, 0x00, 0x98, 0x06, 0x1E, 0x60, 0x36, 0xC3, 0x03, 0x01, 0x81, 0x8D, 0x20,
0x07, 0x07, 0x03, 0x9D, 0x00, 0xD0, 0x06, 0x1E, 0x40, 0x30, 0xC3, 0x03, 0x83, 0x01, 0x8F, 0x40,
0x03, 0xFB, 0x01, 0xC3, 0x00, 0xF0, 0x06, 0x1F, 0xC0, 0x10, 0xC3, 0x01, 0xC6, 0x01, 0x8C, 0xC0,
0x01, 0xF1, 0x80, 0xFE, 0x00, 0x60, 0x07, 0xCF, 0x40, 0x0F, 0x83, 0xC0, 0x7E, 0x07, 0xC7, 0x80,
0x00, 0x00, 0x80, 0x3C, 0x00, 0x40, 0x1F, 0xC0, 0x40, 0x07, 0x0F, 0xC0, 0x3C, 0x07, 0x83, 0x00
void setRotation(uint8_t rotation);
void setup() {
  pinMode(LEDpin0, OUTPUT);
  pinMode(LEDpin1, OUTPUT);
  pinMode(BoosterPin, OUTPUT);  // sets digital pin as output for booster trigger
  pinMode(inPinD6, INPUT);
  digitalWrite(inPinD6, HIGH);
  pinMode(inPinD7, INPUT);
  digitalWrite(inPinD7, HIGH);
  pinMode(inPinD8, INPUT);
  digitalWrite(inPinD8, HIGH);
  pinMode(inPinD9, INPUT);
  digitalWrite(inPinD9, HIGH);
  pinMode(inPinD11, INPUT);
  digitalWrite(inPinD11, HIGH);
  pinMode(inPinD12, INPUT);
  digitalWrite(inPinD12, HIGH);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize OLED with the I2C addr 0x3C
  display.setRotation(2);
  // Splash screen
  display.clearDisplay();
  display.drawBitmap(0, 0,  Deviation, 128, 32, 1);
  display.display();
  delay(2000);
 // Model select
 while ((digitalRead(inPinD8) == 1) && (digitalRead(inPinD9) == 1)) {
   TimerFreeTone(TONE_PIN, 2900, 100);
   display.setTextSize(2);
   display.setTextColor(WHITE);
   display.setCursor(0,0);
   display.println("Choose    model");
   display.display();
 if (digitalRead(inPinD8) == 0) {
   TimerFreeTone(TONE_PIN, 3000, 100);
   display.println("JUPITER X3");
   display.display();
   Model = 1;
   delay(2000);
 if (digitalRead(inPinD9) == 0) {
   display.println("M250-C30");
   display.display();
   Model = 2;
   delay(2000);
if (Model == 1) {
  fMode1 = ("2D MODE");
  fMode2 = ("Cartesian");
  fMode3 = ("Polar");
  fMode4 = ("Loiter");
  fMode5 = ("3D MODE");
  fMode6 = ("  R T H  ");
if (Model == 2) {
  fMode1 = ("Rates/PIDs");
  fMode2 = ("Stability1");
  fMode3 = ("Stability2");
  fMode4 = ("Rate Mode1");
  fMode5 = ("Rate Mode2");
  fMode6 = ("Acrobatic");
   // Setup timer
  OCR1B = 1000;
 // Channel 3 - Analog 3
  delayMicroseconds(A3_uS); // Hold for A3_uS microseconds
 // Channel 4 - Analog 4
  delayMicroseconds(A4_uS); // Hold for A4_uS microseconds
// Channel 5 - 3-way switch #1
// Channel 6 - 3-way switch #2
// Channel 7 - 3-way switch #3
  delayMicroseconds(sw3_uS);     // Hold for sw3_uS microseconds
// Channel 8 - Right-side momentary buttons
  delayMicroseconds(sw4_uS);     // Hold for sw4_uS microseconds
// Synchro pulse
 // Read analog pins
   AI_Raw_A3 = analogRead(AI_Pin_A3);
   AI_Raw_A4 = analogRead(AI_Pin_A4);
   A3_uS = AI_Raw_A3 + pulseMin;
   A4_uS = AI_Raw_A4 + pulseMin;
  if (A3_uS <= 750) A3_uS = 750;
  if (A3_uS >= 1625) A3_uS = 1625;
// Potentiometer center beeps
  if ((A1_uS >= 1160) && (A1_uS <= 1220)) {
    if (pBeep1 == false)
            TimerFreeTone(TONE_PIN, 3100, 30);
            pBeep1 = true;
  } else {
           pBeep1 = false;
  if ((A2_uS >= 1160) && (A2_uS <= 1220)) {
    if (pBeep2 == false)
            pBeep2 = true;
  } else {
           pBeep2 = false;
  if ((A3_uS >= 1160) && (A3_uS <= 1220)) {
    if (pBeep3 == false)
            pBeep3 = true;
  } else {
           pBeep3 = false;
// 6-way switch analog corrections & beeps
  if ((A4_uS >= 750) && (A4_uS <= 900)) {
    A4_uS = 750;
    Alert = fMode1;
    Battery = ("BAT 100%");
    if (fBeep1 == false)
            TimerFreeTone(TONE_PIN, 2450, 100);
            fBeep1 = true;
  } else {
           fBeep1 = false;
  if ((A4_uS >= 920) && (A4_uS <=980)) {
    A4_uS = 910;
    Alert = fMode2;
    Battery = ("BAT 90%");
    if (fBeep2 == false)
            fBeep2 = true;
  } else {
           fBeep2 = false;
  if ((A4_uS >= 995) && (A4_uS <= 1020)) {
    A4_uS = 1120;
    Alert = fMode3;
    Battery = ("BAT 80%");
    if (fBeep3 == false)
            fBeep3 = true;
  } else {
           fBeep3 = false;
  if ((A4_uS >= 1075) && (A4_uS <= 1110)) {
    A4_uS = 1330;
    Alert = fMode4;
    Battery = ("BAT 70%");
    if (fBeep4 == false)
            fBeep4 = true;
  } else {
           fBeep4 = false;
  if ((A4_uS >= 1220) && (A4_uS <= 1300)) {
   A4_uS = 1380;
   Alert = fMode5;
   Battery = ("BAT 60%");
   if (fBeep5 == false)
            fBeep5 = true;
  } else {
           fBeep5 = false;
  if (A4_uS >= 1500) {
    A4_uS = 1625;
    Alert = fMode6;
    Battery = ("BAT 50%");
            if (fBeep6 == false)
             fBeep6 = true;
  } else {
           fBeep6 = false;
// 3-way switch #1
           sw1_uS = 750;
           if (Beep1 == false)
            TimerFreeTone(TONE_PIN, 2450, 50);
            Beep1 = true;
            Current = ("0.50A");
 } else {
           Beep1 = false;
           sw1_uS = 1190;
           if (Beep2 == false)
            TimerFreeTone(TONE_PIN, 2250, 50);
            Beep2 = true;
            Current = ("0.75A");
 } else {
           Beep2 = false;
           sw1_uS = 1625;
           if (Beep3 == false)
            Beep3 = true;
            Current = ("0.85A");
 } else {
           Beep3 = false;
// 2-way switch
           sw2_uS = 750;
           if (Beep4 == false)
            Beep4 = true;
 } else {
           Beep4 = false;
  if (digitalRead(inPinD4) == 1) {
           sw2_uS = 1625;
           if (Beep5 == false)
            TimerFreeTone(TONE_PIN, 2200, 50);
            Beep5 = true;
 } else {
           Beep5 = false;
// 3-way switch #2
  if (digitalRead(inPinD6) == 0) {
           sw3_uS = 1190;
           if (Beep6 == false)
            Beep6 = true;
 } else {
           Beep6 = false;
  if ((digitalRead(inPinD6) == 1) && (digitalRead(inPinD7) == 1)) {
           sw3_uS = 750;
           if (Beep7 == false)
            Beep7 = true;
 } else {
           Beep7 = false;
  if (digitalRead(inPinD7) == 0) {
           sw3_uS = 1625;
           if (Beep8 == false)
            TimerFreeTone(TONE_PIN, 2750, 50);
            Beep8 = true;
 } else {
           Beep8 = false;
// Right-side momentary buttons
  while (digitalRead(inPinD8) == 0) {
           sw4_uS = 750;
            TimerFreeTone(TONE_PIN, 3200, 100);
  if ((digitalRead(inPinD8) == 1) && (digitalRead(inPinD9) == 1)) {
           sw4_uS = 1190;
  while (digitalRead(inPinD9) == 0) {
           sw4_uS = 1625;
// Booster state/3-way switch #3
  if (digitalRead(inPinD11) == 0) {
    digitalWrite(BoosterPin, HIGH);  // turn booster on HIGH power
    digitalWrite(LEDpin0, HIGH);
    digitalWrite(LEDpin1, HIGH);
    Booster = ("HIGH");
           if (Beep9 == false)
            TimerFreeTone(TONE_PIN, 2950, 100);
            Beep9 = true;
 } else {
           Beep9 = false;
  if ((digitalRead(inPinD11) == 1) && (digitalRead(inPinD12) == 1)) {
    digitalWrite(BoosterPin, HIGH);  // turn booster on LOW power
    Booster = (" LOW");
           if (Beep10 == false)
            TimerFreeTone(TONE_PIN, 2550, 100);
            Beep10 = true;
 } else {
           Beep10 = false;
  if (digitalRead(inPinD12) == 0) {
    digitalWrite(BoosterPin, LOW);  // turn booster off
    digitalWrite(LEDpin0, LOW);
    digitalWrite(LEDpin1, LOW);
   if (BoosterOff == 1) {           // Blink
      Booster = (" OFF");
      BoosterOff = 0;
   } else {
      Booster = (" ");
      BoosterOff = 1;
           if (Beep11 == false)
            TimerFreeTone(TONE_PIN, 2000, 100);
            Beep11 = true;
 } else {
           Beep11 = false;
  display.drawLine(128, 21, 0, 21, WHITE);
  display.drawLine(52, 32, 52, 22, WHITE);
  display.drawLine(89, 32, 89, 22, WHITE);
  display.drawLine(92, 32, 92, 30, WHITE);
  display.drawLine(94, 32, 94, 28, WHITE);
  display.drawLine(96, 32, 96, 26, WHITE);
  display.drawLine(98, 32, 98, 24, WHITE);
  display.setTextSize(1);
  display.setCursor(0,24);
  display.println(Battery);
  display.setCursor(56,24);
  display.println(Current);
  display.setCursor(103,24);
  display.println(Booster);
  display.println(Alert);
  display.display();
09 Sep 2015 05:50 - 09 Sep 2015 05:56 #37580 by davidwyl
Epyon wrote: You can strip out a lot of Ian's original code, such as the dual rate stuff. Having inputs, especially analogs, active with no input can sometimes make everything go wonky.
int AI_Raw_A2;
void setup() {
   // Setup timer
  OCR1B = 1000;
// Synchro pulse
 // Read analog pins
// 3-way switch #1
           sw1_uS = 750;
           sw1_uS = 1625;
// 3-way switch #2
           sw2_uS = 750;
           sw2_uS = 1625;
122 lines of code.
thanks a lot @Epyon.
if i read the code correctly :
pot 1 ---- A1 & 5v & GND
pot2 ----A2 & 5v & GND
3way#1 ---- D2 & D3 & GND
3way#2 ----D4 & D5 & GND
ppm out ---- D10
is the connect correct??
Last edit: 09 Sep 2015 05:56 by davidwyl.
09 Sep 2015 06:19 - 09 Sep 2015 09:48 #37582 by Epyon
davidwyl wrote: thanks a lot @Epyon.
ppm out ---- D10
Your pots would connect to A2 & A3 as coded, but you can change it to whatever you want. Just change
to
int AI_Pin_A1 = 1; // potentiometer #1 pin
int AI_Pin_A2 = 2; // potentiometer #2 pin
I wouldn't use pins A4 or A5 in case you want an I2C device down the road.
Also, just for clarity, the Arduino's pins would be A0 through A7 right to left as pictured.
*EDIT
I didn't actually answer your question :oops:
Yes, your drawing is correct.
Thinking on it some more, I would hook your pots to pins A6 & A7 since they can only be used as analog.
So
int AI_Pin_A1 = 6; // potentiometer #1 pin
int AI_Pin_A2 = 7; // potentiometer #2 pin
Last edit: 09 Sep 2015 09:48 by Epyon.
10 Sep 2015 01:42 #37616 by davidwyl
Epyon wrote: Also, just for clarity, the Arduino's pins would be A0 through A7 right to left as pictured.
*EDIT
So
Ya u r right a0 -a7 is from right to left. Didn't s
Look at the board while I drow that ugly pic :D.
OK, so I will connect pot to pin 6,7.
Btw, will this code work on arduino mini also Without any modifications?
I got arduino mini & arduino nano, still haven't decide which I will use for my devo 7e.
10 Sep 2015 03:44 - 10 Sep 2015 03:45 #37618 by Deal57
I used the Arduino Pro Mini. As long as you're doing the software in IDE it should work. These boards do have some slight differences but as long as you match up the right pins and functions, there's nothing that affects what we're doing. Until you get it really loaded up, I guess!
Last edit: 10 Sep 2015 03:45 by Deal57.
10 Sep 2015 03:51 #37620 by Epyon
davidwyl wrote: Btw, will this code work on arduino mini also Without any modifications?
Should work just fine on a Mini. IIRC, the Mini doesn't have pins for A4-A7, just solder pads? Regardless, will work fine.
10 Sep 2015 14:56 #37631 by davidwyl
I still playing With my arduino mini & nano.
Will play around with the pot & 3ways Switch soon.
I plan to power arduino from devo 7e main board...Do I need an on/off switch for arduino? Any disadvantage to leave it permanently connected?
(currently I'm using 2s lipo battery to power my devo 7e)
Thanks @deal57 & @epyon for all the help.
Really appreciate it...
10 Sep 2015 16:17 #37632 by Epyon
davidwyl wrote: I still playing With my arduino mini & nano.
Epyon wrote: You can get switched 5v from here..........
The pad to the left is full battery voltage, so be careful!
11 Sep 2015 00:31 - 11 Sep 2015 00:33 #37649 by davidwyl
Im aware that 5v spot but didn't know the spot next to it is full battery Voltage, thanks for pointing that out.
Is that 5v from devo 7e regulated?
Do I need an on/off switch for arduino? (I won't be using ppm input for certain model that I fly)
Last edit: 11 Sep 2015 00:33 by davidwyl.
11 Sep 2015 06:30 #37651 by Epyon
Yep, regulated 5v.
Shouldn't need a switch. You can just disable PPM in certain models.
Only disadvantage would be battery life. I've never worried about that, running a 6500mah LiPo strapped to the back.
11 Sep 2015 08:19 #37653 by davidwyl
Connected 3ways switch to arduino, can see it in my devo but the value -109, 0, 109 in stick input menu... Is that ok?
The 3ways Switch added to the devo 7e main board labeled as swA0, swA1, swA2 so I can easily assign the switch to dualrate /complex mode. But 3ways switch added using arduino through ppm only show ppm with -100,0,100 value.
Is it possible to use the 3ways switch from ppm as a dual rate switch?
(For example: position 1- 100%, position 2- 70%,Position 3- 50%)
11 Sep 2015 09:15 - 11 Sep 2015 09:29 #37655 by Epyon
davidwyl wrote: Connected 3ways switch to arduino, can see it in my devo but the value -109, 0, 109 in stick input menu... Is that ok?
That's perfectly fine.
davidwyl wrote: Is it possible to use the 3ways switch from ppm as a dual rate switch?
Yes, you'll need to use virtual channels.
OR, since you're only using 4 of the possible 8 PPM channels, you can change the code so the 3-way switches shows up like 6 separate 2-ways.
int AI_Raw_A2;
int sw1_uS = 750;     // 3-way switch #1 position 1 us
int sw2_uS = 750;     // 3-way switch #1 position 2 us
int sw3_uS = 750;     // 3-way switch #1 position 3 us
int sw4_uS = 750;     // 3-way switch #2 position 1 us
int sw5_uS = 750;     // 3-way switch #2 position 2 us
int sw6_uS = 750;     // 3-way switch #2 position 3 us
void setup() {
   // Setup timer
  OCR1B = 1000;
// Channel 3 - 3-way switch #1 Position 1
// Channel 4 - 3-way switch #1 Position 2
// Channel 5 - 3-way switch #1 Position 3
// Channel 6 - 3-way switch #2 Position 1
// Channel 7 - 3-way switch #2 Position 2
  delayMicroseconds(sw5_uS);     // Hold for sw5_uS microseconds
// Channel 8 - 3-way switch #2 Position 3
  delayMicroseconds(sw6_uS);     // Hold for sw6_uS microseconds
// Synchro pulse
 // Read analog pins
// 3-way switch #1
  // Position 1
           sw1_uS = 750;
  } else {
           sw1_uS = 1625;
  // Position 2
           sw2_uS = 750;
  } else {
           sw2_uS = 1625;
  // Position 3
           sw3_uS = 750;
  } else {
           sw3_uS = 1625;
// 3-way switch #2
  // Position 1
           sw4_uS = 750;
  } else {
           sw4_uS = 1625;
  // Position 2
           sw5_uS = 750;
  } else {
           sw5_uS = 1625;
  // Position 3
           sw6_uS = 750;
  } else {
           sw6_uS = 1625;
Last edit: 11 Sep 2015 09:29 by Epyon.
11 Sep 2015 10:20 - 11 Sep 2015 10:21 #37656 by davidwyl
Epyon wrote: Yes, you'll need to use virtual channels.
thanks for the code :) but i cant seem to compile it.
here is the error i got.
"collect2.exe: error: ld returned 5 exit status
Error compiling."
BTW can u explain how to use virtual channels to use that 3ways switch to control dual rate?
thanks
Last edit: 11 Sep 2015 10:21 by davidwyl.
Time to create page: 0.986 seconds
