Connecting Transmitter to PC for remote control
- Scumbag
05 Jul 2015 22:22 #35139
by Scumbag
Connecting Transmitter to PC for remote control was created by Scumbag
Hi there,
my plan is to connect my devo 10 with deviationtx to my pc and use it as a transmitter.
my aim is to control my quadcopter with mouse and keyboard.
I'd like to use the wsad keys for pitch and roll, my mouse for yaw and the mouse wheel for throttle
Has anyone tried something like this before? and what is the best way to get startet?
Thanks (ps. Sry if this is the wrong forum section)
- RoGuE_StreaK
05 Jul 2015 23:25 #35141
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Connecting Transmitter to PC for remote control
Personally I don't think the actual control system will work for a quad; your keyboard will only be hard 100% throws, whereas a tx stick control has variable outputs, meaning you can give a little roll or a lot of roll. Unless you had a software system that incremented the amount of throw over time, eg. start at 10% and increase by 10% every 0.2seconds the key is held down (or something along those lines). Also I reckon your mouse wheel will get a hell of a workout and you'll get a cramped scroll-finger, as you typically need to be continuosly adjusting throttle to keep things steady for hovering (if there's no altitude-hold).
Interface-wise, I'm guessing it would have to be PPM-out from the computer, possibly through the audio output? I honestly don't know if the USB connection can operate in both directions for controls.
- Arakon
06 Jul 2015 04:25 #35144
by Arakon
Replied by Arakon on topic Connecting Transmitter to PC for remote control
Yeah.. this is a recipe for disaster. If the copter is flying towards your face, you don't want to have to hammer a key 50x to make it stop.
06 Jul 2015 12:40 #35160
Replied by mwm on topic Connecting Transmitter to PC for remote control
Note that this has been done - though not with deviation that I know of. Read about it on rcgroups:
www.rcgroups.com/forums/showthread.php?t=1207253
. The idea should work fine on deviation, though.
As noted, simple keyboard control is a bad idea. Getting into the keyboard and responding to holding down keys would work better.
Personally, I was interested in recording a flight and then playing it back, just for grins. But I've found more productive things to work on since then.
- aMax
06 Jul 2015 14:02 - 06 Jul 2015 14:07 #35164
by aMax
Replied by aMax on topic Connecting Transmitter to PC for remote control
In the end, found it again.. Devo and Deviation.
PC > DEVO8 > Minicp... & USB HID (Logitech G940)..
PPM signal from soundcard to tx. Input via USB controller.
Last edit: 06 Jul 2015 14:07 by aMax.
Time to create page: 0.038 seconds
- Connecting Transmitter to PC for remote control
