Deviation for Devo F4?
- LucaG
14 Apr 2017 14:21 #61458
by LucaG
Replied by LucaG on topic Deviation for Devo F4?
Thanks for the reply SirDomsen!
I do not know how to install Arduino and how to program it! I'll do a search and study a little! Can you direct me to the discussion on the 7e?
But I think, the true DevoF4 update or change the memory chip (are pending delivery). This will allow the installation of additional modules that will enhance the DevoF4.
However it remains a 4-channel radio ...... this is a contradiction!
A radio with FPV should have, at a minimum, 6 channels!
I wonder if it's worth upgrading the memory and then not use the potential of additional modules.
It is expected to implement additional channels?
The 4M firmware will enter the Nightly Builds?
Thank you
Thank you
- SirDomsen
14 Apr 2017 16:24 #61463
by SirDomsen
Replied by SirDomsen on topic Deviation for Devo F4?
Deviation always has the same amount of channels. You just lack switches. But you could use every trim switch as a switch for example. Means Stock F4 has the same 12 channels on devo/dsm protocol as every other Deviated TX
- LucaG
14 Apr 2017 16:41 #61464
by LucaG
Can you tell me if the pattern in the image is correct?
Thank you
Thank you
- LucaG
14 Apr 2017 18:12 #61467
by LucaG
Can someone tell me if the pattern in the image is correct?
Thank you
Thank you
- SirDomsen
14 Apr 2017 18:32 #61468
by SirDomsen
I don't know really - If that info is based on Epitaph's traces I assume yes. But I'd rather do the normal switch mod than soldering directly to the MCU. See
this post
for further information. I also put a link into the DevoF4 section in the Wiki.
- LucaG
14 Apr 2017 18:50 #61470
by LucaG
In the diagram I place even AIL DR0; AIL DR1.
If Epitaph can confirm with certainty, better!
I await comments. Thank you
MIX0; MIX1; MIX2; it is unclear to me. Suggestions?
HOLD0; HOLD1; it is unclear to me. Suggestions?
Thank you
Thank you
- LucaG
14 Apr 2017 19:00 #61473
by LucaG
Deviation has 12 channels in software.
But in hardware, in DevoF4, how do I connect two potentiometers for a 5th and a 6th channel?
There are PINs that have been assigned a 5th and a 6th channel on which to place the potentiometers?
I am sure that in DevoF4-4M version is imperative to have this!
Thank you.
Thank you.
- LucaG
14 Apr 2017 19:09 #61474
by LucaG
I mean, before using pins on the processor, it would be much better than Devention would add two or three new channels, associating its pin.
Why, no two more channels, it is useless to invest additional modules of this transmitter.
I think Epitaph of my opinion as others!
Thank you
Thank you
- SirDomsen
14 Apr 2017 19:19 #61475
by SirDomsen
You could try to wire pots according to F7's wiring scheme - but not sure if it works. I used the arduino for my pots which works quite well.
Btw: Don't mess up channels with inputs
A channel (could be analog or digital, depending on the protocol) is what the tx sends to your RC model. An input is like the gimbals, pots or switches - which can be assigned to a channel. Because the F4 in stock form lacks switches, you can configure the trim switches to act like a physical switch. Read the manual to get how to.
- djtrance
18 Apr 2017 10:32 #61543
by djtrance
Replied by djtrance on topic Deviation for Devo F4?
I want to use de devo 4#1 in the devo F7. someone know how to connect it?
18 Apr 2017 10:40 #61544
Replied by vlad_vy on topic Deviation for Devo F4?
The 4in1 module can be connected by usual way, in place the original module. Two wires will connect to TMS and TCK and usual problem with third wire. It looks like it can be connected to A2 (pin 16 MCU).
Look at:
www.deviationtx.com/forum/7-development/...dule?start=940#55157
and (A2, pin16 marked by red)
www.deviationtx.com/forum/builds/6861-ul...ilds?start=160#61392
Look at:
- LucaG
18 Apr 2017 11:05 #61545
by LucaG
Helo vlad_vy!
When the F4-4M firmware will enter in the Nightly Builds?
18 Apr 2017 12:10 - 18 Apr 2017 12:13 #61547
I don't know. The last time I tried to place a pull request with DevoF12E-4MB it was not accepted. Probably too few users of 4MB builds, or something else.
You can get latest 4MB builds at the end of the topic:
www.deviationtx.com/forum/builds/6861-ul...-devof12e-4mb-builds
Last edit: 18 Apr 2017 12:13 by vlad_vy.
- LucaG
18 Apr 2017 12:47 #61549
by LucaG
vlad_vy many thanks for the answer.
Obviously I believe it is fundamental to introduce the 4M version in the Nightly Builds.
All development Deviation is based on the ability to add modules to the radio, and without greater memory HAS NO SENSE TO INVEST in F4!
How to say it makes no sense Devention in F4!
I exploit your great availability to ask for help.
I discovered this silpstream.com/89/deviationtx-build-environment-and-tools/
There are videos that guide in the installation of development tools and do some simple things like create a firmware or an emulator?
can you help me?
Thank you so much
can you help me?
Thank you so much
- Moeder
18 Apr 2017 12:54 #61550
by Moeder
Replied by Moeder on topic Deviation for Devo F4?
As I mentioned in the F12e thread, if we go ahead and integrate victzh flash chip detection code, I will immediately support adding FxE-extramem (or similar) builds
- LucaG
20 Apr 2017 13:44 #61611
by LucaG
Your idea, Moeder, seems perfect to me.
Unfortunately I'm not a programmer and I can not help you.
- LucaG
27 Apr 2017 17:53 #61823
by LucaG
I need devo F4 firmware where channels 5,6,7 are active as in F7.
I'm going to do some tests to connect the MCU pins to the potentiometers.
Any programmer can help me?
Thank you
Thank you
- MaxQrc
29 Apr 2017 14:25 #61848
by MaxQrc
Replied by MaxQrc on topic Deviation for Devo F4?
Hi I am new here. I have a Devo f4 and I wonder if it is already possible to deviate the f4 or if it has been unsuccessful so far? Can one add a nRF24L01 module to control all those Chinese quads? That would be awesome!
- SirDomsen
29 Apr 2017 16:25 #61850
by SirDomsen
I highly recommend that you read through the whole thread. Many necessary information for doing great things with your F4
- Arnold
30 Apr 2017 04:35 #61861
by Arnold
I agree with SirDomsen about reading the thread. Yes, it's a lot to read, but it's packed with helpful information you can use. Better to take it all in one big bite than to nibble at the info you seek, in my opinion.
See the Wiki also ... Find a link to it in the sidebar on the left side of this page.
Replied by Arnold on topic Deviation for Devo F4?
Yes.MaxQrc wrote: ... possible to deviate the f4 ...
Yes.... Can one add a nRF24L01 ...
Time to create page: 0.242 seconds
- Deviation for Devo F4?
