Radiolink AT9 as a platform for Deviation?
28 Dec 2015 06:23 - 21 Mar 2016 09:10 #41190 by vlad_vy
Can Radiolink AT9 be a platform for Deviation?
At first glance:
MCU STM32F103VET6
RF module (bus = SPI)
CC2533F96 96-KB Flash, 6-KB RAM
RFX2401C
chip 8 pin = unknown
quartz 32.000 Mhz
Last edit: 21 Mar 2016 09:10 by vlad_vy.
04 Feb 2016 20:58 #42587 by victzh
Replied by victzh on topic Radiolink AT9 as a platform fot Deviation?
Do you have it?
09 Feb 2016 04:40 #42822 by vlad_vy
Replied by vlad_vy on topic Radiolink AT9 as a platform fot Deviation?
Yes. I can disassemble it for tracing connections and parts on other side of the board.
09 Feb 2016 14:32 #42841 by victzh
I ordered it, so it will come sooner or later (1-2 months from China - you know), but I'd be interested on what's inside. The most important are - MCU (you already reported it), flash ROM - does it have it at all? it may be that unknown 8 pin chip you mentioned, what's written on it? - display - what type of the display?
09 Feb 2016 15:56 #42844 by vlad_vy
8 pin chip at RF module has not any marking
1) MCU: STM32F103VET6
2) quartz: 8.000 Mhz
3) 128K-bit SPI SERIAL ELECTRICALLY ERASABLE PROM: IS25C128A-2GLI
4) DC-DC converter: MC34063A
5) LCD Display: FPC-SJ28N-19VOF
09 Feb 2016 17:35 #42851 by victzh
RF module is not that important, you said it has CC2533 - it's a combo of RF front end and 8051 MCU, so hardly useful anyways.
What's discouraging is the amount of flash - only 16KBytes of serial flash. How large is model memory? By any chance can it use external SD cards?
09 Feb 2016 17:43 #42852 by victzh
Also, can you make hi-res photos for the board(s), please?
09 Feb 2016 18:06 - 09 Feb 2016 18:11 #42856 by vlad_vy
There are 15 models memory. Tx has not any slot for SD card.
Last edit: 09 Feb 2016 18:11 by vlad_vy.
09 Feb 2016 18:08 #42857 by victzh
Then I'm afraid the SPI chip needs to be replaced by more capacious. It should not be that hard, easier than power mod for Devo 7E for instance.
13 Mar 2016 09:06 #44495 by victzh
Got my AT9 today, spent some time studying it. The board quality is very high, the overall design is also very well thought out. You can't miss sockets plugging in the controls - they all of different size. Using DC-DC converter is a brilliant idea - the device is very insensitive to power voltage and does not spend energy in linear regulator.
Device locks out its menus after short inactivity so that you accidentally would not change something important.
The screen is always lit - it should be very low energy consuming one to afford this, but it's very convenient.
It seems to be using unencoded DFUs, they just took examples from DfuSe Demo - which is good!
Couple drawbacks:
1. Low I2C memory - 128kbit is nothing for Deviation filesystem.
2. Antenna is soldered to the board, you need to desolder it to remove the board completely.
3. Many switches, pots, buttons are soldered directly to the board - one good fall - you crack the board. It is a less of drawback, but allowed them to save a lot on assembly cost.
Main problems Deviating it:
1. Flash memory - should be upgraded. Fortunately, the chip is large enough for many people to do this, it's not Devo 7E power limit upgrade.
2. Screen - they used something unnamed, it should be decoded. Visually it very similar to this one: www.aliexpress.com/store/product/2-8-inc...443_32482363327.html , but not necessarily the same.
3. Controls - instead of Devo's 6 buttons this one has two buttons - Enter and Back, and rotary encoder with a button. Need to develop another control procedure for UI.
4. What to do with original radio module. It's 802.15.4/ZigBee, I doubt it can be re-purposed for something useful for more traditional protocols. So it can be replaced with universal module or something like this.
13 Mar 2016 12:30 #44501 by dc59
If AT9 or AT10 could be deviated it would be a great news,I like that color OLED screen! :lol:
13 Mar 2016 20:54 #44520 by victzh
It's a long way yet. As far as I understand, it's not an OLED, it's just bright LCD with LED background.
14 Mar 2016 00:14 - 14 Mar 2016 00:14 #44532 by dc59
victzh wrote: It's a long way yet. As far as I understand, it's not an OLED, it's just bright LCD with LED background.
You are right, it's a LCD not an OLED.
China RC forum gave me wrong information , sorry.
If it's an LCD, it could difficult to use under sunlight, am I right? just like DEVO 8S. :(
Last edit: 14 Mar 2016 00:14 by dc59.
14 Mar 2016 01:56 #44533 by victzh
I'll check as soon as we have a sunny day - not this week probably.
14 Mar 2016 03:50 #44537 by dc59
victzh wrote: I'll check as soon as we have a sunny day - not this week probably.
Thanks a lot. :cheer:
17 Mar 2016 04:44 #44692 by victzh
@vlad_vy, can you make detailed photos of the both sides of the main board? I got "lucky" - I have black board, no way to make a photo. Very nice, very useless for tracing.
27 Mar 2016 11:43 #45261 by vlad_vy
Replied by vlad_vy on topic Radiolink AT9 as a platform for Deviation?
Images of face and back sides of the main board.
cloud.mail.ru/public/7Sed/A53dyr11z
27 Mar 2016 17:58 #45279 by victzh
Replied by victzh on topic Radiolink AT9 as a platform for Deviation?
Thanks a lot, it helps immensely!
08 Apr 2016 20:21 #46125 by adri62
Replied by adri62 on topic Radiolink AT9 as a platform for Deviation?
hello i also got this radio i purchased to put a DIY dsmx module in like i did in my flysky but the board is different and soldered as you know.
my question is: do you know where the signal to the board is (ppm)
thank you
18 Apr 2016 22:09 #46760 by anasm2010
Replied by anasm2010 on topic Radiolink AT9 as a platform for Deviation?
hello
i hope more people will be interested and will help on the deviation of the at9.
In my side im working in a mod to control the H8mini quadcopter using a NRF24L01 over the trainer port. I will share when I end B)
Time to create page: 0.272 seconds
