- ako
20 Oct 2016 17:43 #55222
by ako
Hmm... what about the antenna track from the solder point of the bare module to the UFL connector? Doesn't it affect the signal quality?
One could consider cutting the trace and soldering a UFL connector directly to the three points at the bare module. Is the stock antenna cable long enough to reach that point? I don't want to open my Devo 10 to check it.
I would consider buying this new module for my Devo 10 and removing the bare 4in1 and using that one in my AT9 when everything is ready.
Replied by ako on topic 3in1 / 4in1 RF module
epilot wrote: The module is available on Banggood now.
4in1 module
- victzh
20 Oct 2016 22:01 #55231
by victzh
Replied by victzh on topic 3in1 / 4in1 RF module
That is my concern as well. To be 50Ohm trace the board on which the module mounted should be 4 layer one. Or for this thickness it should be coplanar wave guide - which is does not seem to be - for this type of transmission line it should be surrounded by ground from the both ends. if stock antenna is long enough it is definitely better to move U.FL closer to the module output.
But people report reasonable power output from the module, so maybe we don't understand something.
- HappyHarry
20 Oct 2016 22:16 #55233
by HappyHarry
Replied by HappyHarry on topic 3in1 / 4in1 RF module
i was also worried about the transmission line so i modified it, pictures of the modification are in this post here >>
www.deviationtx.com/forum/how-to/5955-7e...1?limitstart=0#49844
- victzh
20 Oct 2016 22:28 #55234
by victzh
You know what, on your photo it looks like a legit coplanar waveguide, my only concern is it crosses the module footprint a bit. It explains why the other people report reasonable results. For 1.6mm (59mil material thickness) FR4 and 6mil gap between the guide and ground plane it width will be around 50mil or 1.27mm - which seems to be what it is.
- BirdBarber
- Hummingbird Assassin
20 Oct 2016 22:59 - 20 Oct 2016 23:01 #55236
by BirdBarber
Replied by BirdBarber on topic 3in1 / 4in1 RF module
I range tested low power DSMX on a Devo 10 4-in-1 and a 7E with range mod and got nearly identical results at the same power. I think that this implies that there isn't a 4-In-1 antenna trace issue, at least at low power DSMX. Here are the details:
www.deviationtx.com/forum/7-development/...dule?start=780#52692
Last edit: 20 Oct 2016 23:01 by BirdBarber.
- ds864
21 Oct 2016 09:34 #55245
by ds864
Replied by ds864 on topic 3in1 / 4in1 RF module
After all that I've decided to install two separate modules the NRF24L01 & A7105 (links below). These two modules look fairly simple to fit and only cost me £9.50. I also get to reduce the amount of risk involved in doing the mod. My only issue is having 3 antenni. I have seen some people just curl it up inside the Devo case so I may try that first unless anyone has a better idea?
Whilst I'm at it I'm going to cut off the top of the existing aerial and put on a screw fitting too. I may even be tempted to go for the range mod if I can get the shield off. I also have some 3 position switches coming for the ultimate Devo 7e.
NRF24L01 : www.aliexpress.com/item/2-4G-NRF24L01-PA....13010608.0.0.5UhMdP
A7105: www.aliexpress.com/item/A7105-RFIC-500m-....13010608.0.0.UrHGw3
- C0ckpitvue 777
22 Oct 2016 19:09 #55278
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic 3in1 / 4in1 RF module
Is this 4in1 compatible with the 7e w/out the wire soldered to the mcu?And are there any major issues with just using the original 7e chip instead of the upgrade for more space like in the ultimate version?In other words is this 4in1 w/out major issues to go straight in the 7e.
- C0ckpitvue 777
22 Oct 2016 19:10 #55279
by C0ckpitvue 777
All fb is greatly appreciated.
- epilot
22 Oct 2016 20:02 #55281
by epilot
Replied by epilot on topic 3in1 / 4in1 RF module
You still have to solder to the MCU if you want to use all four modules.
- HappyHarry
22 Oct 2016 21:26 #55284
by HappyHarry
the 4in1 will work fine in the stock 7e, it doesn't require an upgraded mcu in the transmitter to work. also as epilot said if you wish to use all 4 rf chips you need to solder to the mcu, but if you only wish to use 3 of the rf chips you can avoid that
- C0ckpitvue 777
22 Oct 2016 22:56 #55288
by C0ckpitvue 777
Thank you.
- C0ckpitvue 777
22 Oct 2016 22:58 #55289
by C0ckpitvue 777
Thank you,can I pick which chip gets excluded.
- HappyHarry
22 Oct 2016 23:05 - 22 Oct 2016 23:06 #55290
by HappyHarry
your welcome bud:)
I think you have to use the cyrf (I could be wrong though), but of the other three you can choose which one not to use
from what I've read recently regarding this subject it looks like it has been implimented correctly, size and ohm'age, no sharp turns/edges etc, if I had this knowledge back then I don't think I would have bothered modifying it as I did. live and learn as the saying goes
C0ckpitvue 777 wrote: Thank you,can I pick which chip gets excluded.
your welcome bud:)
victzh wrote: You know what, on your photo it looks like a legit coplanar waveguide, my only concern is it crosses the module footprint a bit. It explains why the other people report reasonable results. For 1.6mm (59mil material thickness) FR4 and 6mil gap between the guide and ground plane it width will be around 50mil or 1.27mm - which seems to be what it is.
Last edit: 22 Oct 2016 23:06 by HappyHarry.
- Fernandez
23 Oct 2016 07:33 #55299
by Fernandez
Replied by Fernandez on topic 3in1 / 4in1 RF module
An open RF trace without any shielding cover around is always very poor design, RFI wise. Certainly there is some loss in the trace even if it is properly designed to be 50ohms.Personally I would solder my Coax directly to the output of module close as possible, removing the solder bridge between module and main pcb.
Anyone have some pictures from the latest 4in1 pcb of Banggood, so what under the cover?
Is it now using the genuine, NRF + type
- dado099
23 Oct 2016 13:16 #55307
by dado099
Replied by dado099 on topic 3in1 / 4in1 RF module
Yes you can exclude the chip you want, specifiyng the correct address line in hardware.iniC0ckpitvue 777 wrote: Thank you,can I pick which chip gets excluded.
- C0ckpitvue 777
23 Oct 2016 19:07 #55313
by C0ckpitvue 777
Thank you.
- trawlins
24 Oct 2016 19:08 #55354
by trawlins
Replied by trawlins on topic 3in1 / 4in1 RF module
So on my Devo 8s I still have to soldier to the MCU?
Having difficulty finding info specific to Devo 8/8s.
- Arnold
25 Oct 2016 00:09 #55359
by Arnold
Replied by Arnold on topic 3in1 / 4in1 RF module
Yes.trawlins wrote: So on my Devo 8s I still have to soldier to the MCU?
See Vlad's post #55157Having difficulty finding info specific to Devo 8/8s.
- Cereal_Killer
30 Oct 2016 20:18 #55532
by Cereal_Killer
Replied by Cereal_Killer on topic 3in1 / 4in1 RF module
Hello, as im doing this for someone else i want to be perfectly sure the 3-in-1 modules PA_EN and LNA_EN pins are both left floating? Not connected to any pins at all?
Ive got it running and have bound to all different protocol receivers i have access to test but i just want to be 1000% sure since im shipping it off to him tomorrow
- NotFastEnuf
31 Oct 2016 11:57 #55552
by NotFastEnuf
Replied by NotFastEnuf on topic 3in1 / 4in1 RF module
I've had my devo 8 a long time. Long enough to remember putting in the 8s module so that I could get telemetry. Does the new 4 in 1 module have all the same telemetry functionality that our origional modules have?
Time to create page: 0.395 seconds
- Devo 12s 3in1 / 4in1 RF module neat installation.
