- D_an_W
29 Jun 2016 20:09 #51190
by D_an_W
Replied by D_an_W on topic 3in1 / 4in1 RF module
They are not widely available yet, this was supplied as a favour from someone in China.
- TheMadCADer
30 Jun 2016 16:33 #51219
by TheMadCADer
Replied by TheMadCADer on topic 3in1 / 4in1 RF module
My 4in1 should be here today, can't wait
- D_an_W
30 Jun 2016 17:03 #51221
by D_an_W
I just ordered the HK K110 to test it with!
- HappyHarry
30 Jun 2016 18:11 #51222
by HappyHarry
Replied by HappyHarry on topic 3in1 / 4in1 RF module
nice one on the sucesfull swap dan, and it's a great little heli, I'm sure you'll like it
- Fer
30 Jun 2016 23:11 #51229
by Fer
If we continoue like this, i think i will never make up my mind. This 4in1 looks even more promising than everything else till now. I think i will only purchase the DEVO 10 for the time being and keep reading this thread (although i only understand what you are talking about half of the time). Thank you for the info.
Replied by Fer on topic 3in1 / 4in1 RF module
D_an_W wrote: They are not widely available yet, this was supplied as a favour from someone in China.
- D_an_W
01 Jul 2016 05:11 #51236
by D_an_W
- Fer
01 Jul 2016 06:08 #51237
by Fer
I didn't mean anything bad about you or anyone else. Just that sometimes the conversation is so technical that i can't keep up with all the terms and info.
- bigicedog
02 Jul 2016 21:51 #51263
by bigicedog
Replied by bigicedog on topic 3in1 / 4in1 RF module
ok i got a new devo 7e in today im thinking about trying again with the 3 in 1 but ill just play it safe with my other a7015 (maybe)
- compman2
03 Jul 2016 11:47 #51275
by compman2
Replied by compman2 on topic 3in1 / 4in1 RF module
I have a 7e that has an MCU upgrade (ultimate 7e). I have been struggling to get any additional RF module to work with it. I have tried single nrf and a7105 as well as a 3 in 1. I have tried powering the modules externally, always get module not found. The range modded internal module has worked the whole time
I purchased another 7e and just installed the 3 in 1 module yesterday it worked like a champ. I then transferred it back to the ultimate 7e and it didn't work so back to the stock 7e and it works fine. Is it a fair deduction to assume that the mcu installation on the ultimate 7e has issues? I haven't been able to get any module to respond on the TMS(a13) or TCK(a14) pins. I was thinking about trying to connect to the processor again with my ST-Link just to see if there is functionality on those two pins. This last trial with the 3 in 1 I didn't try using an external power source.
I have a spare mcu that I could use to replace the mcu on the ultimate 7e. What are the chances an mcu replacement would resolve the issue.
- HappyHarry
03 Jul 2016 13:24 #51277
by HappyHarry
i'd check for good connectivity on all of the existing mcu pins first, as that might be the only issue
- BLeaCH
04 Jul 2016 05:05 #51285
by BLeaCH
Replied by BLeaCH on topic 3in1 / 4in1 RF module
Hi, the thing that is not widely available yet, it's the 4in1 Module or the devo 10 adapter board?
thanks in advance for your anwser
- D_an_W
04 Jul 2016 05:12 #51286
by D_an_W
It's kind of both, the 4-in-1 replaces the original board and just requires three additional wires connecting for switching protocol (It also one requires one aerial).
- ahlod
04 Jul 2016 11:57 #51290
by ahlod
Replied by ahlod on topic 3in1 / 4in1 RF module
First of all I want to thank this wonderful community, I was a lurker since last year and finally purchased 7e 4 months ago. After months of using it with my scisky I decided to follow this thread and bought the 3 in 1 instead since the 4in1 has some issues before, and I thought it would be an overkill for me to use 4in1. I was up for the challege and I finally started the range mod and module installation today. It was a freaking 5 hrs work including devo setup and model setup!!!
The range mod was hard but the soldering pin 13 was insanely brutal! I was using a magnifying lens and its still hard to see. Good thing I got multimeter to check for continuity and possible unwanted connections.
After the surgery all is working including the range mod. I also upgraded to v5 deviation. Very proud of my self lols.
What I think is very very usefull before doing this:
1. Kapton tape
2. Multimeter with continuity tester
3. Thinnest soldering lead
4. Magnifying glass
5. Lots of patience
This is the module I bought: goo.gl/hXeC2U
-Happykid
1. Kapton tape
4. Magnifying glass
5. Lots of patience
-Happykid
- HappyHarry
04 Jul 2016 13:53 #51292
by HappyHarry
congrats on the succesful conversion bud
- kahuna001
04 Jul 2016 14:35 #51294
by kahuna001
Replied by kahuna001 on topic 3in1 / 4in1 RF module
Now you need to upgrade the CPU to 256k
- ahlod
05 Jul 2016 03:53 - 05 Jul 2016 03:53 #51303
by ahlod
thanks man
Next will will be the 2 switches. now looking for items in china lol
HappyHarry wrote: congrats on the succesful conversion bud
thanks man
Last edit: 05 Jul 2016 03:53 by ahlod. Reason: grammar
- ahlod
05 Jul 2016 04:10 #51304
by ahlod
I will have to add this on my list hahaha.
kahuna001 wrote: Now you need to upgrade the CPU to 256k
- sonicserve
05 Jul 2016 04:29 #51306
by sonicserve
Replied by sonicserve on topic 3in1 / 4in1 RF module
Did you have 4in1 installed? Does it work as expected?
I contacted the seller a few days ago and he said it is available for shipping.
TheMadCADer wrote: My 4in1 should be here today, can't wait
- TheMadCADer
05 Jul 2016 18:41 - 05 Jul 2016 18:42 #51325
by TheMadCADer
It works perfectly with everything I've tried binding it with so far (Hubsan H107D, Syma X5C, DSM2/DSMX full range receivers and satellites of various brands).
Edit: If you are getting one directly from Ren, you may have to use Bhiner if you are in the USA, because Ren can only accept Alipay.
Last edit: 05 Jul 2016 18:42 by TheMadCADer.
- D_an_W
05 Jul 2016 19:35 #51328
by D_an_W
Tested mine with Hubsan quads, Blade Nano CP S, Walkera Super CP, EYE One Xtreme (Lemon RX) and a borrowed Syma X8C. I have a XK K110 on the way too
Time to create page: 0.478 seconds
- Devo 12s 3in1 / 4in1 RF module neat installation.
