Build failed in Linux after cloning from github
13 Apr 2016 13:29 #46422 by richardclli
Failed in build with errors:
: No such file or directory
When I looked into the problem, I figure out that many scripts is edited with windows line breaks, which cause the some perl scripts failed to run in Linux. Not sure if this need to be fixed or not.
13 Apr 2016 14:04 #46425 by richardclli
Replied by richardclli on topic Build failed in Linux after cloning from github
I think it is caused by the way I work on deviation ^.^, checking out using windows and building with Linux.
I solved it finally by turning off the auto crlf function
git config --global core.autocrlf true
Time to create page: 0.024 seconds
