Difficulty linking in floating point functions
- theseankelly
20 Jun 2016 16:40 #50863
by theseankelly
Difficulty linking in floating point functions was created by theseankelly
Hey Forum
I'm working on a protocol and adding some telemetry which requires floating point arithmetic to convert a VBat value. I'm taking an existing protocol (cflie, but it doesn't really matter which...) and I've added code to the effect of:
Which produces linker errors complaining about the floating point lib functions being used (mult, and float to int):
I've spent a ton of time googling this sort of issue and best I can tell, it means I'm not linking in libgcc properly OR I need to be using gcc instead of ld for my linking (because apparently ld is notoriously bad at paths). However, no definitive solutions yet, and I've tried a variety of things. Converting the LD call to a CC call in the target/common/devo/Makefile.inc led me down a rabbit trail that I ultimately gave up on, but maybe that's the right way to go.
Anyway -- I imagine someone has got to have needed floats and tackled this problem before. Any ideas on the easiest solution -- preferably something that's portable and doesn't require a hard path to libgcc.a?
Sean
// Bytes 6, 7, 8, and 9 are the Vbat in float
float vBat;
memcpy(&vBat, &packet[5], sizeof(float));
Telemetry.value[TELEM_DSM_FLOG_VOLT1] = (s32)(vBat*10);
TELEMETRY_SetUpdated(TELEM_DSM_FLOG_VOLT1);Which produces linker errors complaining about the floating point lib functions being used (mult, and float to int):
+ Compiling 'protocol/cflie_nrf24l01.c' as module
+ Building 'objs/devo7e/cflie_nrf24l01.bin'
objs/devo7e/cflie_nrf24l01.o_: In function `cflie_callback':
cflie_nrf24l01.c:(.text.cflie_callback+0x11a): undefined reference to `__aeabi_fmul'
cflie_nrf24l01.c:(.text.cflie_callback+0x11e): undefined reference to `__aeabi_f2iz'I've spent a ton of time googling this sort of issue and best I can tell, it means I'm not linking in libgcc properly OR I need to be using gcc instead of ld for my linking (because apparently ld is notoriously bad at paths). However, no definitive solutions yet, and I've tried a variety of things. Converting the LD call to a CC call in the target/common/devo/Makefile.inc led me down a rabbit trail that I ultimately gave up on, but maybe that's the right way to go.
Sean
- theseankelly
20 Jun 2016 20:08 #50866
by theseankelly
Replied by theseankelly on topic Difficulty linking in floating point functions
Sure enough explicitly adding the path to libgcc.a works:
But this doesn't really seem safe for a broad audience.
-L /usr/lib/gcc/arm-none-eabi/5.3.1/armv7-m/ -lgccBut this doesn't really seem safe for a broad audience.
20 Jun 2016 22:30 #50880
Replied by PhracturedBlue on topic Difficulty linking in floating point functions
why do you need floating point? we do everything using integer code and that is what you should use as well. floating point is not well supported by the cortexM architecture, and should be avoided.
- theseankelly
20 Jun 2016 22:34 #50881
by theseankelly
Perfect. I wasn't crazy about pulling in a whole lib just to multiply a float by 10, so this settles it.
As to why: The Crazyflie 2.0 exposes VBat as a float. It's trivial to extend the crazyflie F/W to expose a second telem variable for VBat in 1/10th volt units like other telemetry systems. Given your statement, it's a no brainer to go this route instead.
20 Jun 2016 22:40 - 20 Jun 2016 22:41 #50882
I think there should already be routines that will convert a float to a int (i.e turn a float voltage into integer milli-volts), and if not, they're not hard to write. They may only work with BCD though.
Last edit: 20 Jun 2016 22:41 by PhracturedBlue.
Time to create page: 0.040 seconds
- Difficulty linking in floating point functions
