Devo 12S Builds 4.x and 5.0.0. No Media Folders
- bjr981s
21 Nov 2016 09:17 #56132
by bjr981s
Devo 12S Builds 4.x and 5.0.0. No Media Folders was created by bjr981s
I have been trying to update Toggle Buttons and the advice relates to the Media Folder.
Version 4.0.0 4.0.1 and 5.0.0 do not have media folders in the Zip download for the Devo 12. I have manually created a media folder and added a toggle3.bmp but it does nothing.
Is this a bug in the 12S build? Why no media folder for the 12 and 12S?
Cheers
Cheers
21 Nov 2016 09:52 #56134
Replied by vlad_vy on topic Devo 12S Builds 4.x and 5.0.0. No Media Folders
It's Devo12 memory chips limitation. "Media" folder integrated into library file. You can use "mymedia" folder for custom "toggle3.bmp", "sound.ini" and "config.ini" files.
You can use script to build custom library file:
www.deviationtx.com/forum/custom-skins/2...themers?limitstart=0
- bjr981s
21 Nov 2016 10:55 #56138
by bjr981s
Replied by bjr981s on topic Devo 12S Builds 4.x and 5.0.0. No Media Folders
Thanks mate, built my first library. it works a treat.
Only issue was to use Command Prompt (DOS) to activate the build as the path name needs to be set with DOS.
Cheers
Cheers
Time to create page: 0.167 seconds
- Devo 12S Builds 4.x and 5.0.0. No Media Folders
