Devo 12S Builds 4.x and 5.0.0. No Media Folders
21 Nov 2016 09:17 #56132 by bjr981s
I have been trying to update Toggle Buttons and the advice relates to the Media Folder.
Version 4.0.0 4.0.1 and 5.0.0 do not have media folders in the Zip download for the Devo 12. I have manually created a media folder and added a toggle3.bmp but it does nothing.
Is this a bug in the 12S build? Why no media folder for the 12 and 12S?
Cheers
21 Nov 2016 09:52 #56134 by vlad_vy
It's Devo12 memory chips limitation. "Media" folder integrated into library file. You can use "mymedia" folder for custom "toggle3.bmp", "sound.ini" and "config.ini" files.
You can use script to build custom library file:
www.deviationtx.com/forum/custom-skins/2...themers?limitstart=0
21 Nov 2016 10:55 #56138 by bjr981s
Thanks mate, built my first library. it works a treat.
Only issue was to use Command Prompt (DOS) to activate the build as the path name needs to be set with DOS.
Cheers
Time to create page: 0.061 seconds
