Version 5.0.0 bug - No src=none file write.
21 Nov 2016 09:32 #56133 by bjr981s
Tried reporting this via the bug tracker but my account will not let me log on?
If you create a mix with a source of None. Like a fixed output switch.
Everything works fine until you read the model file and reimport to another slot or radio.
The problem is, the mix with a src = none when saved to the Models folder saves with an entry that src = AIL
This subsequently messes up the mix and has AIL input and AIL trim included in the mix.
The code should write back src = None.
You can fix this by redacting the src = AIL line.
Cheers
How do I get access to the bug tracker?
Time to create page: 0.065 seconds
