Deviation on STM32F103RBT6 development board?
22 Feb 2017 01:24 #59433 by hyperlogos
I have a Devo 7e running Deviation, and I'm very happy with it for what it is. I have done the diode mod, add 3in1 mod, and the 2x3 switch mod. I also have a HK-T6A with a USBASP-based PPM to HID encoder in it :) But I want to make something custom, lighter, with better gimbals.
Would it be reasonable to get Deviation running on a STM32F103RBT6 development board? rc.fdr.hu/devo.php#devo7e says that's the same kind of STM32 used in the Devo 7e. Dev boards with color touch screens are available on eBay for $25. The display code would I imagine have to be rewritten for the ADS7843 instead of NT7538, since the display controller differs. The unit comes with a 2.8 inch 320x240 display with a touch overlay.
I am not averse to adding an I2C ADC if necessary... and if code space permits...
Would it be smarter to not bother, and just to target a better CPU? I see that there was an effort to do that previously, but it stalled. I imagine it would be easier to use an already-supported STM32, though
22 Feb 2017 18:09 #59471 by FDR
Wow, somebody still uses that page! :ohmy:
This case I should refresh the info on it... ;)
I wouldn't bother with that MCU, but would use at least the one of the 8, 10, 12E...
22 Feb 2017 18:43 #59473 by hyperlogos
Replied by hyperlogos on topic Deviation on STM32F103RBT6 development board?
Google brings people to all pages, if their search terms are specific enough :)
Packages with STM32F103VCT6 board+LCD (QVGA touch) begin at $40, which is not too awful. But the STM32F103RBT6 can be had with a display for $25, which is a lot more inspiring. On the other hand, maybe there's not enough room in the RBT6 to run a fancy display anyway. Is it just not realistic do it with the RBT6?
22 Feb 2017 19:10 - 22 Feb 2017 19:10 #59477 by robocog
Replied by robocog on topic Deviation on STM32F103RBT6 development board?
I have just ordered a dev board with a STM32F103RBT6
and another with a STM32F103RCT6
Hoping I can get at least one of those working well enough to transplant into a TX I want to Deviate
Neither come with screens - but they were only £6 and £8 each
I'm not a programmer or a hardware guy to any real level..but willing to tinker and learn as I go
Will report back when they arrive
Regards
Rob
Last edit: 22 Feb 2017 19:10 by robocog.
24 Feb 2017 00:33 #59546 by hyperlogos
I'm thinking about pulling the trigger on one of these Sainsmart STM32F103VCT6 boards with 3.2" touch TFT display.
The display controller is SSD1289 and the touch IC is XPT2046. Controlling the display seems to be fairly well-explored territory. Likewise for the touch controller.
www.sainsmart.com/sainsmart-stm32-stm32f...serial-jtag-swd.html
www.ebay.com/itm/STM32-STM32F103VCT6-Boa...9:g:21YAAMXQwKdRejdm
www.amazon.com/SainSmart-STM32-STM32F103...ywords=STM32F103VCT6
www.hotmcu.com/32-touch-screen-tft-lcd-w...-interface-p-36.html
www.solomon-systech.com/en/product/displ...-controller/ssd1289/
www.gpegint.com/files/library/files/supp...r%20IC%20SSD1289.pdf
github.com/notro/fbtft/wiki/SSD1289
ldm-systems.ru/f/doc/catalog/HY-TFT-2,8/XPT2046.pdf
Please stop me now if there's some obvious reason why I am unlikely to be able to implement on this :)
24 Feb 2017 01:48 #59548 by mwm
Deviation uses libopencm3 for a hardware abstraction layer. When you say the display/touch controllers are "well explored", have you verified that that was done with libopencm3, and not some other HAL - for instance, any of the official HAL's from STM? I don't see it in my copy of libopencm3.
24 Feb 2017 03:19 - 24 Feb 2017 05:16 #59550 by hyperlogos
No, I sure can't verify that. As far as I know nobody has done it with libopencm3. Besides Arduino-specific stuff, what I came up with was
github.com/LonelyWolf/stm32/tree/master/SSD1289
and
libstock.mikroe.com/projects/view/1837/s...display-library-demo
Having looked at the latter example code side by side with the Deviation code (I am currently examining deviation-master\src\target\devo10\lcd.c, pardon my backslashes but I'm on wintendo right now, vs. SSD1289.c) the differences seem quite translatable. Deviation has LCD_Init(), the lib has TFT_Init(). Deviation uses rcc_peripheral_enable_clock() and gpio_set_mode() (are these libopencm3 functions? edit: yes they are.) while the lib uses GPIO_Clk_Enable() and GPIO_Config(). This code was designed for STM32F103RCT6; the STM32F103VCT6 has more GPIOs. I am optimistic about being able to get LCD working.
I haven't looked at touch yet, but the LCD looks totally doable. Not quite copy and paste, but doable.
Last edit: 24 Feb 2017 05:16 by hyperlogos.
24 Feb 2017 14:09 - 24 Feb 2017 14:30 #59561 by hyperlogos
Replied by hyperlogos on topic I believe this is the actual original board
www.hotmcu.com/hyministm32v-dev-board-32...-p-5.html?cPath=1_20
most relevant there is the schematics.
dev board: www.haoyuelectronics.com//Attachment/HY-...Y-MiniSTM32V_SCH.pdf
lcd board: www.haoyuelectronics.com//Attachment/HY-...STM32V/HY32D_SCH.pdf
Now the question becomes, are there enough of the right kinds of pins free, or at least employed on a useful bus upon which we can piggyback. Stop me if I'm wrong, but from the board schematic it appears that the following pins are free:
PA0-PA3
PB8-PB15 (includes available I2C and SPI)
PC0-PC7 (includes ADCs)
PE0-PE6
This sounds like enough free pins to implement the radio (That's SPI, right?) and plenty of inputs. Am I on track?
Last edit: 24 Feb 2017 14:30 by hyperlogos.
12 Mar 2017 01:10 #60139 by hyperlogos
I finally got the hardware. I am working on the lcd driver support.
More comments in the deviation source code would not have gone amiss.
What does LCD_DrawStart do? LCD_DrawStop? LCD_DrawPixel?
I get LCD_Init and LCD_DrawPixelXY, those have names that make sense. But everything I do with the panel is either initializing or drawing, so the other functions are not as self-explanatory.
I can probably figure it out but some help would be appreciated as it would save time.
Time to create page: 0.037 seconds
