Settings in deviation to allow EZUHF on DSC Jack
- Desode
11 May 2017 03:44 #62226
by Desode
Settings in deviation to allow EZUHF on DSC Jack was created by Desode
Hello ,
I want to start by saying my apologies if this is on these forums some place and I am sure it is but I haven't been able to find it yet.
What settings in the software do I need to use in order to get a signal out of the DSC jack to my EZUHF TX?
I have been using a old Devo 7 for my EZUHF stuff, but I recently got a Devo 8s and the sticks are just so much better that I can never use the Devo 7 (Not 7e) again! It must be burned at the stake! LOL
I plugged in the EZUHF to the Devo 8s (deviation 5.0) and could not get it to work on one of my other aircraft that has EZUHF on it.
Do I need to set the protocol and other settings to get it to work?
Thank you all so very much for your time and your help.
Sincerely, Dez
Sincerely, Dez
11 May 2017 04:28 #62227
Replied by vlad_vy on topic Settings in deviation to allow EZUHF on DSC Jack
To get PPM out you need select the PPM protocol for your model. PPM protocol has several options for tuning PPM out.
- Desode
11 May 2017 04:44 - 11 May 2017 04:44 #62228
by Desode
Since I have all my EZUHF aircraft already set up and working with the Devo 7,,, if I want to start to control those same aircraft with the Devo 8s then when I would create a model for them in the Devo 8S, and I would select the protocol in the deviation software to just devo? and that is all I have to do to send ppm out the DSC jack then?
That is kind of what I am asking,,
What protocol he Craptastic Devo 7 use? Would that be just the devo protocol in the software? or one of the walkera protocols?
I am assuming that if I knew that and my EZUHF system is already set to it from the Devo 7 , then I can just dial up the same protocal on the 8s and plug into the EZUHF Transmitter and I should be good to go?
Thanks , Dez
Replied by Desode on topic Settings in deviation to allow EZUHF on DSC Jack
vlad_vy wrote: To get PPM out you need select the PPM protocol for your model. PPM protocol has several options for tuning PPM out.
Thanks , Dez
Last edit: 11 May 2017 04:44 by Desode.
11 May 2017 04:59 - 11 May 2017 05:00 #62229
Any external RF module controled by PPM protocol, so you need select PPM protocol for your model to control EZUHF system. In most cases it will work with default PPM options.
Last edit: 11 May 2017 05:00 by vlad_vy.
- Desode
11 May 2017 05:03 #62230
by Desode
Ah, Ok,,, that makes sense, So when I make my model in the 8S I select the protocol at PPM!
That makes sense.
I will give that a try vlad,, Thank you so much! Fingers crossed! LOL
By the way I love this 8, The sticks are like butter!
vlad_vy wrote: Any external RF module controled by PPM protocol, so you need select PPM protocol for your model to control EZUHF system. In most cases it will work with default PPM options.
That makes sense.
- Desode
21 May 2017 16:30 #62472
by Desode
Vlad vy, I just wanted to let you know that this was the fix I needed.
As soon as I set the protocol to PPM it worked right away with the external UHF module.
Thank's very much!
Now I am preparing to install my 4 in 1 module,, I believe the 8s uses the same steps as the 10 or 12e?
That makes sense.
Thank's very much!
- Wene001
31 Jul 2017 06:17 - 31 Jul 2017 06:23 #63645
by Wene001
Replied by Wene001 on topic Settings in deviation to allow EZUHF on DSC Jack
You have to solder one CSN line to a processor pin ( I prefer B3) on the 8s
The other two are soldered to TMS and TCK @ the pin header
www.deviationtx.com/wiki/modulelist/4-in-1_module
Last edit: 31 Jul 2017 06:23 by Wene001.
- Desode
31 Jul 2017 06:31 #63646
by Desode
I didn't have to do anything,, Just did what Vlad said above and it was good to go with all of my EZUHF craft.
I have 6 UHF aircraft and they l work wonderfully with 8S and the deviation software,
Sincerely, Dez
Wene001 wrote: You have to solder one CSN line to a processor pin ( I prefer B3) on the 8s
Sincerely, Dez
- Wene001
01 Aug 2017 15:43 #63666
by Wene001
my post is about installing the 4in1 in your devo8s
Time to create page: 0.062 seconds
- Settings in deviation to allow EZUHF on DSC Jack
